Input on Nichicon PL(M)
  • crosswinds
    • Oct 2016
    • 30
    • Europe
    Hello!
    So, i was just opening up an older Logic analyzer, and discovered that its build with above mentioned caps..
    I had MUCH problem with PF(M) caps before. Are these as bad or should i let them be?
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: Input on Nichicon PL(M)
    First, that is the Nichicon PL series. The "(M)" means +/-20% tolerance. IIRC, Nichicon introduced the PL series around 1988 or 1989. So if those are 20 or 25 years old, it might be a good idea to replace them anyway. I'll leave to others to say whether they've seen relatively early failures with the PL series, as I wasn't working hands on with electrolytic capacitor very much about 1991-2005. Nichicon's PM series is the RoHS version of the PL series. If you replace the PL series capacitors I recommend using PM series or PJ series parts, assuming they are available.
    PeteS in CA
    • jazzie366
      • May 2016
      • 304
      Originally posted by crosswinds
      Hello!
      If I'm not mistaken, the PL series is the one that the electrolyte eats the rubber bung away and leaks it out on the circuit board. I have some that are still on the tape, they haven't leaked but I can't say they won't leak either.
      My recommendation is the following:
      Panasonic FC
      Rubycon ZLS
      Suncon (Sanyo) WE-WG series, these are what Sanyo WG's were, they are still being made, but by the OEM now.
      Nichicon UPM or UHE
      Elna RVD
      Any one of those should work for a PSU.
      Popcorn.
      • crosswinds
        • Oct 2016
        • 30
        • Europe
        This is for a Tektronix TLA704 logic analyzer, and its not for the PSU.
        It is for the acquisition-modules.
        They have:
        x15 35v 150uF Nichicon PL(M) (Safe to replace with Panasonic FR?
        x7 16v 470uf Nichicon PY(M) (Safe to replace with Panasonic FC?)
        • PeteS in CA
          • Aug 2005
          • 3581
          I don't see a PY series on Nichicon's present online catalog. If Panasonic is what is reasonably available to you, go with the FC series for the PL and PY series capacitors. It's about two generations newer and lower in impedance than PL. FR is a different electrolyte technology, of a type that might not have been in use when that logic analyzer was produced. It's much lower impedance, which is not automatically a good thing. Panasonic FC (and the nearly identical impedance PW from Nichicon and LXZ from Nippon Chemicon) is about as modern and low in impedance as I would go.
          On the side, Nichicon PM, PS, PJ, and PW series are of a different electrolyte technology than the HE series. About the only P* type I would consider interchangeable as output capacitors with the HE series without risking stability issues is the PA series.
          PeteS in CA
          • mockingbird
            • Dec 2008
            • 5484
            It says:
            "Smaller case size than PF Series"
            "Lower impedance at high frequency range"
            • Capacitor Connoisseur
              • Dec 2020
              • 3
              I recently confirmed that the PL series leaks electrolyte from the seal. I could not find conclusive evidence online, but discovered this when repairing an engine control unit. The date on the capacitor is the 15th week of 1994. It is not leaking too bad, at least so far. If you look closely at the photo you can see the electrolyte on the bottom seal.
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                Welcome to Badcaps and thanks for the information!
                • DrewPhillips
                  Capacitor Diarrhea - Nichicon PL Series
                  by DrewPhillips
                  Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                  The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                  03-02-2025, 10:18 PM
                • chth96
                  Is there datasheet for nichicon LXJ series?
                  by chth96
                  I want to calculate capacitor ESR referring to below guide.
                  https://forum.digikey.com/t/calculat...-from-tan/2633
                  I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
                  I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
                  Is there anyone who still has old nichicon datasheet which has information of LXJ series?
                  11-20-2022, 08:11 AM
                • chth96
                  Is there any datasheet for nichicon RT(M) series?
                  by chth96
                  A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
                  https://www.badcaps.net/forum/troubl...e-been-blew-up
                  and I finally fixed​ this retro game console by soldering varistor and glass fuse.
                  But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
                  I have spare console...
                  11-28-2023, 03:36 AM
                  ASUS Pro Series D310MT-0G32500650 Pro Series G3250 Specification for Upgrade or Repair
                  This specification for the ASUS Pro Series D310MT-0G32500650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D310MT-0G32500650 boardview and Pro Series D310MT-0G32500650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-12-2024, 03:28 PM
                  ASUS Pro Series D320SF-I564000134 Pro Series i5-6400 Specification for Upgrade or Repair
                  This specification for the ASUS Pro Series D320SF-I564000134 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF-I564000134 boardview and Pro Series D320SF-I564000134 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
