Finding low-ESR 400V capacitors
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: Finding low-ESR 400V capacitors
    I can't give anything like an evolutionary history of electrolytic capacitors, as I'm too young (I don't say that often!). I read some late 50s TV repair magazines, in which they were regarded as royal PITAs (Pains In The Ass), due to inconsistent quality and frequent-friers being semi-custom multi-section, multi-value parts. The latter aspect meant difficulty keeping suitable replacement parts on hand.
    Fast-forward to my days at DeVry (early-mid 70s),and about the farthest profs went beyond, "Assume an ideal capacitor ..." was to mention that electrolytics and tantalums are polarized.
    By the time I started at Boschert, my first job working with switching power supplies, in 1980, low ESR capacitors and "Computer Grade" (beer can sized screw terminal) capacitors had been on the market for quite a while. Switching power supplies need output capacitors the can handle high ripple (AC) current without overheating, thus, low ESR as it was then called. United Chemicon RX and RZ series, Nichicon PA and PB series, and Sprague 672D and 674D series were the best available at the time (I didn't see Marcon, Rubycon, or Panasonic at that time).
    Since then "low impedance" became the common usage, and impedances of series have fallen steadily. Going back to the, "Assume an ideal capacitor ..." line, the impedance of a part at a given frequency is the vector sum of the part's capacitive reactance, inductive reactance, and resistance (reactance is for AC what resistance is for DC, but changes with frequency). In the case of a real-world capacitor, it's the vector some of the capacitive reactance, and the parasitic inductive reactance (ESL) and resistance (ESR) due to the wire leads, swaging the leads onto the foils, the foils, and the electrolyte (in an electrolytic capacitor, the dielectric is an aluminum oxide layer on the anode foil; the electrolyte is a very very low resistance conductor).
    As frequency increases, inductive reactance increases, and capacitive reactance decreases. At 100KHZ, the capacitive reactance of a 2200uF capacitor is ~.72 milliohms. In the vector sum, capacitive and inductive reactance subtract. The inductive reactance at 100KHz is probably higher that than the capacitive reactance, so the impedance of the 2200uF capacitor is close to the vector sum of the ESR and the inductive reactance of the ESL.
    Back in the late 70s and early 80, switch frequencies were in the 20KHz-30KHz. Since inductive reactance is proportional to the frequency, multiplying the frequency by 5 or 10 multiplied the inductive reactance by the same factor. So ESL was less relevant back 1980ish.
    Some the others here can be more precise about the time-frame that I am, but somewhere around 2000 computer MB started including VRMs that stepped the 12V or 5V from the PSU down to the voltage needed by the processor or memory. These started as little plug-in boards, but soon were integrated into the MBs. Nowadays there are server MBs that just take 12V power, and have all the integrated DC-DC converters necessary to generate the various voltages needed by the MB.
    PeteS in CA
    • PeteS in CA
      • Aug 2005
      • 3581
      Originally posted by Behemot
      There is the typical 60-100 kHz in active (boost) PFC.
      Most of the better HV caps are of long-life type, so the ESR is lower than of standard but still higher than of low-ESR. Also putting too low ESR caps into such old device is usually worse than better.
      The snap-in types used for 50/60 Hz filtering and as output caps for PFC stages are not designed for low impedance. But they are designed to handle high ripple current, which requires being fairly low impedance (so they don't fry themselves dry). I think many/most PFC stages also have a film capacitor in parallel with the big snap-in electrolytic.
      PeteS in CA
      • Behemot
        • 4845
        • CZ
        I meant more like the D16-D18 leaded, not snap-in. The leaded ones go all the way up to 12000 hours @temperature and ripple so I think they are lower ESR than comparable snap-in caps.
        • PeteS in CA
          • Aug 2005
          • 3581
          Could be. The PSUs I dig into these days may be too high power to use 16 mm and 18 mm diameter leaded parts. I see lots of snap-ins at PFC outputs.
          Those super long life parts may also be optimized for long life in CFLs and ballasts, where cooling may be poor.
          PeteS in CA
          • Stefan Payne
            • 1267
            That started with the Pentium Processors, the P54C. First ones had linear regulators...
            But then there was Cyrix who had a higher power consumption and thus linar regulators wasn't enough.
            And by the time the Triton II Boards came around (and also the P55C), switch mode VRMs became more and more common. Because those CPUs were the first with a split I/O and Core Voltage...
            The older Triton I Boards (i430FX) had the VRM connector you mentioned...
            • Perry Babin
              samwha capacitors 10uf 200v/250v
              by Perry Babin
              The attached capacitors are used in the output filters of class D amplifiers and hold up well but when they fail, replacements are difficult to find. I've tried the various options on eBay and crossover caps and none survived. Mouser, Digi-key... don't stock many bi-polar electrolytic caps. The only thing that I found survived (never a failure) was the Mouser E2106 (part number 667-ECQ-E2106JF) and the same from Digi-key. They look different but survive. Does anyone know a readily available drop-in replacement electrolytic? The dimensions are approximately 16mm x 25mm....
              04-03-2024, 05:46 AM
            • dragon3x
              by dragon3x
              power on.
              Here are some examples :
              switching supply area).
              than 6.3 V.)
              03-21-2025, 02:46 PM
            • chth96
              How Can I test PWM DM0365R?
              by chth96
              Hello
              I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
              So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
              I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
              I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
              06-18-2025, 04:14 PM
            • JohnsonJ
              Allen&Heath XONE92 DJ mixer repair
              by JohnsonJ
              Hello everyone.
              I'm having issues with my DJ mixer, and after taking it apart and checking everything out, it seems that I need to replace 2 rotary potentiometers for the filter, and that the PSU has some caps burned. Hopefully these 2 fixes will solve my issues.
              The potentiometers I will just replace (hopefully the repairman I spoke with will indeed send me the spares, in case he doesn't, I'll update here if we can find a suitable replacement), but for the PSU caps I'd kindly ask you forum members, if anyone could help guide me in the right direction. I'm having difficulty...
              12-12-2020, 11:19 AM
            • slybunda
              AA and AAA battery charger capacitors?
              by slybunda
              hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
              it has inside:
              2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
              2 x 470uf 16v LZ105c branded as G.Luxon
              not heard of these brands are they any good?
              iv attached photos of the charger and the board inside for an idea on the type of...
              12-24-2023, 04:41 AM
