GX280 Issues - capacitors look ok though
  • roger8wilco
    • Jan 2009
    I got a GX280 off ebay a year or so ago.. From the symptoms, it sounded liks a PSU replacement but when I got it, it wasnt the problem.
    When I try to turn on, it goes on for a few seconds, fan a full power, and then shuts off for a few seconds. Then it repeats it over and over. Sometimes it'll stop repeating and turn on, not POST, and just stay with on with the fan at full power. Typically after this happens and I turn it off, it will actually boot up.
    I havent had it recently happen, but it has been known to shut off randomly (usually when its idle like overnight when not in use).
    I took a look inside and see no bad capacitors, no bulging, leaking, etc. A number of caps are RubyCons (i think, but pretty sure) so I think they may have been replaced, at least 5-8 of them..
    Another note, related or not, it wont take more RAM... if i put more in, I get bad memory beeps when it boots up.
    Any ideas? Does it sound like it could be the caps?
  • Solder Boy
    • Nov 2006
    • 178
    Re: GX280 Issues - capacitors look ok though
    You will need an ESR meter to determine which are the bad caps on the motherboard if you can't see any obvious ones that are bulged. I'd also check the voltage on the CMOS battery, if it's below 2.9 volts replace it.
    As far as the RAM issue goes, check the RAM using Memtest86, it might be bad.
    From what you have described, it does sound like a bad cap problem especially since you say it does POST.
    Good luck!
    www.bcrelectronics.ca
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Some GX280 got defective Nichicon HN or HM series caps.
      Date codes (on the caps) will be between 2001 and 2004.
      H0133 would be week 33 in 2001
      H0433 would be week 33 in 2004
      [I have no idea what the 'H' is. Sometimes it's another letter.]
      Other GX280 (especially the Small Form Factors) suffer from heat issues due to too little airflow and that will even kill good caps eventually.
      Mann-Made Global Warming.
      - Dr Seuss
      • dragon3x
        by dragon3x
        power on.
        Here are some examples :
        switching supply area).
        than 6.3 V.)
        03-21-2025, 02:46 PM
      • slybunda
        AA and AAA battery charger capacitors?
        by slybunda
        hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
        it has inside:
        2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
        2 x 470uf 16v LZ105c branded as G.Luxon
        not heard of these brands are they any good?
        iv attached photos of the charger and the board inside for an idea on the type of...
        12-24-2023, 04:41 AM
        After all of...
        07-13-2024, 08:14 PM
      • Cama
        Solar Inverter - SMH-II - 2 missing capacitors
        by Cama
        I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
        My model is : EASUN SMH-II 7 KW
        Mother Board : P/N 18947-002401250250
        Maybe the EASUN SMH-II 4.2 KW have the same capacitors
        Thank you...
        09-12-2025, 02:50 AM
      • Ady2017
        Are there any datasheets available for Elna RJG capacitors?
        by Ady2017
        I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
        05-25-2025, 02:19 PM
