I've got a videocard that had a capacitor knocked off of it. Is it possible to solder a new cap on in it's place? It is one of those caps that has a plastic base soldered to the board. The entire thing came off the board. How do you solder the plastic base without melting it?
Replacing surface-mount snap in caps
Re: Replacing surface-mount snap in caps
180uFMann-Made Global Warming.
- Dr Seuss
Okay, just saw it's a solid polymer. Which means that it's probably 180uf 16v. Here's what I found from UCC
http://search.digikey.com/scripts/Dk...=565-3078-2-NDLudicrous gibs!
Oops, minimum order on the above is 400
I'll use this, and have to order 5-
http://search.digikey.com/scripts/Dk...=565-3078-6-ND
Pity, I only need one.Ludicrous gibs!
