So a company I had tried to make a deal with about a year ago just contacted me again to try again and make a deal with, only difference is the price is extremely low.
They are offering me 2200uF 25V 105C capacitors for $0.05 a piece....
Most companies are about 0.15 each for the same, factory direct.
I'm tempted obviously, and they hint a lot at that they make capacitors for CapXon... so I guess that's a sorta plus?
Also, they have paperwork that they show fro ROHS, CE(???), and ISO:9001 and 14001. So that's a plus as well.
I'm not sure what to do as if they are the OEM for capxon and their caps aren't the most shit, but are quite cheap, maybe it's not the worst idea to just run them under the manufacturer spec and I should have no problems?
Not sure what to do, tell me what you guys think.
story, "Oh poor you, making little to nothing off of recaps because that's all the business you get" No, I could easily go the route of all the other techs in the area and just put in whatever was cheapest on eBay that month. Or do what I'm at least trying to do, is to find a 5/10 cap that isn't the best, nor is it the worst, but will do it's job well if loaded lightly or within spec.
Half of the computer problems is caused by bad contacts
