Why not tanatalum caps or a hybrid recap?
  • chaos
    • Dec 2008
    Boards are obviously originally made w/ crummy Al electrolytic caps for cost reasons. But when recapping the labor is going to be more than the entire initial board cost.
    So, when recapping, why not use tantalum caps? Those aluminum electrolytics aren't even allowed in avionics. You generally won't be able to use equally high values but you won't need them either due to the lower ESR, better RF performance, and the vastly better lifetime values of the Ta caps.
    The only problem I can see is that a couple of the caps may affect the control loops of low voltage regulators or just in general might not be bypass caps, and therefore a big change in value might cause problems. This could be tested by identifying the supply rails and checking resistance, or perhaps by just guessing that the widely repeated value is the bypass cap value.
    A hybrid approach would be possible, too. Minimize exposure to the various Al electrolytic failure modes by using a combination of extra-big Al electrolytic recaps plus some (most likely smaller) tantalum replacements.
    Many people have objected to originally mfr'ing these boards with life-limited caps. Even the very best ones are still woefully inferior to solid caps. I must say I've never recapped a board but I've designed many...
  • Harvey
    • Apr 2007
    • 264
    Re: Why not tanatalum caps or a hybrid recap?
    Where can I get 2200uf tantalum caps?
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Right here:
      http://www.mouser.com/Search/Refine....293+4294459839
      If your motherboard only needs 10 it will still cost you over $57.00 after shipping.
      ~ And the ESR isn't any lower than a good solid polymer that costs around ~80% less.
      -> .0055
      Electolytics aren't used in avionics because the air pressure changes will burst them.
      Tantalum caps aren't used on motherboards because they can't handle much ripple and handling ripple is what capacitors on a motherboard ARE FOR.
      Mann-Made Global Warming.
      - Dr Seuss
      • gdement
        • Jan 2007
        • 690
        I have a Slot-2 HP motherboard which is mostly tantalums as far as I could tell. The only electrolytics are on the removable VRM's, which I assume are only the input caps. Everything soldered on the board near components look like tantalums.
        If I could ever get it out of the case I'd post a picture of it, but it's practically impossible to remove so that probably won't happen.
        I've also noticed some old video and network cards use tantalums. But I don't think I've seen them on anything built in the current decade. I suppose polymers are a better alternative today.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          i remember a slot a athlon board that used nothing but tantalums.
          seems gateway used these boards.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Yeah,
            Old boards before ripple wasn't a big deal yet.
            Back when FC or PW (or Tayeh) was good enough for Vcore.
            There are three different kinds of tantalums.
            They tried they type you (probably) saw for a while but being as the wet electrolyte is acid and they leak now and then they quickly fell out of favor.
            - Dr Seuss
              by momaka
              03-15-2023, 10:17 PM
            • Perry Babin
              How do organic polymer caps compare to liquid electrolytic for reliability
              by Perry Babin
              I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
              If not organic polymer, what would be the caps that could take the most abuse?
              08-18-2025, 04:04 PM
              Lenovo ThinkPad X1 Yoga + Hybrid Dock (40AF0135AU) Hybrid (2-in-1) X Specification for Upgrade or Repair
              This specification for the Lenovo ThinkPad X1 Yoga + Hybrid Dock (40AF0135AU) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga + Hybrid Dock (40AF0135AU) boardview and X1 Yoga + Hybrid Dock (40AF0135AU) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
              09-06-2024, 11:32 AM
              Lenovo ThinkPad X390 Yoga + Hybrid Dock Hybrid (2-in-1) X Specification for Upgrade or Repair
              This specification for the Lenovo ThinkPad X390 Yoga + Hybrid Dock Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X390 Yoga + Hybrid Dock boardview and X390 Yoga + Hybrid Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
              09-06-2024, 09:00 AM
              09-06-2024, 08:41 AM
