Need some 12000uf 80v capacitors
  • AsRock
    • Mar 2016
    • 21
    • US
    Hello i am after some 12000uf 80v caps, the Samxon's ( LP ) in my NAD T753 are totally messed up one rattles and the other seems to be bulging.
    Pin spacing is 3/8ths
    It's ripple current that's making it harder to find, temp 20c-45c=1.37, 65c=1.25, 75c=1.75 and 85c 1.0
    Max height 2 inches 2\8ths
    I have been in touch with NAD and they want $20 per cap + $20 shipping for the same caps, kinda hoping to find some better more respected caps for that.
    Thank You, if you need to know any other specs of the Samxon caps let me know.
  • srhofmann
    • Aug 2016
    • 135
    • usa
    Re: Need some 12000uf 80v capacitors
    Are they snap-in or screw terminals? What about the diameter?
    Those ripple current numbers aren't really that great. You can always use a cap that has higher ripple current rating.
    Try something like this....
    http://www.digikey.com/products/en/c...0&pageSize=250
    • petehall347
      • Jan 2015
      • 4435
      i like epcos capacitors for audio power supplies
      • AsRock
        • Mar 2016
        • 21
        • US
        Yeah i have seen those, was hoping to find some thing better.
        • Mint Waxed
          • Aug 2016
          • 35
          Try Mouser Electronics in Texas. They have a huge stock and fast shipping.
          http://www.mouser.com/Search/Refine....000+uf+80+volt
          • jazzie366
            • May 2016
            • 304
            If you want some high end caps, get some Supertech 2T series caps. Well known in the audio world as a very good high end cap. Only manufacturer allowed to manufacture them as well, they are DNM's caps, just Supertech makes them. Highly recommended.
            Also, LP is a standard series, no wonder they failed. They have a not so high ripple as well especially for their size, 6.83 amps is kinda small for that size. If I check with the 2T caps, they're rated at 8 amps of ripple at 10000uF.
            Here's a couple other choices though:
            Rubycon MXR:
            http://www.ebay.com/itm/1-Piece-1200...4AAOSwh-1W3zId
            Reputable eBay seller, very good chance these aren't fake.
            HOWEVER: Can't find ripple of the above caps, Rubycon doesn't list it :L
            And the cheaper option:
            http://www.ebay.com/itm/80v12000uf-8...YAAOSwvg9XaL0z
            Those cheapy's are rated for a fuckton of ripple though, 10.83A of ripple.
            Popcorn.
            • dragon3x
              by dragon3x
              power on.
              Here are some examples :
              switching supply area).
              than 6.3 V.)
              03-21-2025, 02:46 PM
              After all of...
              07-13-2024, 08:14 PM
            • Cama
              Solar Inverter - SMH-II - 2 missing capacitors
              by Cama
              I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
              My model is : EASUN SMH-II 7 KW
              Mother Board : P/N 18947-002401250250
              Maybe the EASUN SMH-II 4.2 KW have the same capacitors
              Thank you...
              09-12-2025, 02:50 AM
            • chth96
              Is it no harm to replace with capacitor without ripple current rating?
              by chth96
              When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
              Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
              But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
              Rubycon YK DataSheet (b...
              04-19-2024, 05:19 AM
            • Ady2017
              Are there any datasheets available for Elna RJG capacitors?
              by Ady2017
              I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
              05-25-2025, 02:19 PM
