Could anybody please tell me what this component is that I need to replace? it says 1R0 Q35.
Identifying component
Tags: None
Re: Identifying component
1 uh coil or inductor i think.Last edited by vinceroger69; 02-23-2017, 09:58 AM. -
"Q35" would probably be the date or lot code.PeteS in CA
****************************Comment
It's a coil for sure is it off a graphics card by any chance as they are common on them?Comment
Hello! I am looking for help with identifying this tcon chip on KOORUI 24E4 monitor.
Driver board number: pn238ct01-3-xc-2
Other IC on the driver board: NT71265MFG-001
08-22-2025, 01:01 PM -
Good morning, I would appreciate help identifying resistors responsible probably for volume down / volume up buttons that I accidently knocked off while replacing fan connector. I enclose picture with location. Thank you for help in advance.1 Photo07-19-2025, 01:49 AM
by omaarI need help identifying this IC and, if possible, the value of the capacitors next to it. It is part of the HDMI circuit of an EVGA RTX 2060 GPU. It suffered a short circuit, leaving the graphics card without video and the TV without image....2 Photos06-06-2025, 07:48 PM
Subject: Help Identifying IC on 820-02020 (MacBook Pro A2338 M1, 2020) — C02045500 / EKQ8LL1A
I'm working on a MacBook Pro A2338 M1 (2020) with logic board 820-02020.
The machine has a power issue — not powering on, and I'm trying to trace the fault.
While inspecting the board, I found a cluster of components
This area looks damaged or burned — there are about 4–5 components that seem affected
I've attached a close-up photo of the chip and its surrounding area (see... -
by m1ch43lzmHi everyone
I have a 70mai Dash Cam A510 which failed after about 3 months of being installed in my car, likely due to heat, i got it from aliexpress so no point in trying to return it for warranty (and shipping it back would cost me almost the same as a new one from ali)
The camera would boot loop showing 70mai logo on the screen, sometimes it would boot fine then the live view would freeze or display purple lines
I already took it apart, and found out that the camera boots fine if i unplug the camera module from the main PCB, sometimes "playing" with the connector... - Loading...
