My OOMA died. There's no power-up so I'm thinking its the capacitor. I opened the device and and see the cap is a surface mount type. I want to try to replace it with a radial type one (after watching a guy on Youtube do it) but don't know which one to buy. The markings on the surface mount capacitor is "100 CFK B03". Can anyone tell me what this translates to?
OOMA Telo fix
Re: OOMA Telo fix
Follow the white rabbit.Comment
Re: OOMA Telo fix
goontron: exactly m8
Less jewellery, more gold into electrotech industry!
Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
by MORETTIGIANTitle:
Description:
Procedure performed:
- Removed backplate
- Reapplied thermal compound
- Reassembled card
- GPU powers on and operates normally under...11 Photos -
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... -
by Agent24I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
It has at least one problem.
The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
I have already ordered a replacement potentiometer, so that's not an issue.
Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
All are CapXon... -
TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...-
Channel: Common Parts Library - Datasheets
10-07-2024, 06:07 AM -
by chth96I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
I know that these capacitor will not last as long as nichicon capacitor...-
- Loading...
