Monitor Replacment
  • snake0007
    • Jan 2017
    Monitor Replacment
    My monitor was acting up, so upon investigating I found a cap I suspected to be bad. It was a 1000uf 10v. According to the manual it was used to smooth the current waves. It is C818 if you want to check, here is the manual:
    After looking everywhere for a capacitor with the same specs, all I could find was a 1500uf 10v. I put it in and the monitor seems to be repaired.
    So my question is just one of general safety. Do you think a difference in uf such as this capacitors application is a risk of fire or electrical shock?
    any help is appreciated!
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: Monitor Replacment
    It's better to change the whole bunch of capacitors on the power supply board , won't cost more than 10 dollars . It's Better to respect schema specifications , cause any messing with , will only put stress on other components , and probably reveal some unexpected weird symptoms .
    • Behemot
      • 4845
      • CZ
      Increasing capacitance in output filters is generally a good thing. What is important is to also not decrease the ESR too much.
      It is also generally good to replace ALL caps as where one is bad, more will follow, unless they are quality series from good brand.
      • snake0007
        • Jan 2017
        thanks for the input. so you recommend to replace all electrolytic caps and no matter the size?
        thanks
        • Behemot
          • 4845
          • CZ
          All non-quality ones for suitable replacements.
            by momaka
            03-15-2023, 10:17 PM
          • keepread
            Dell monitor PSU vs Dell laptop PSU
            by keepread
            Hi there!
            Someone gave me their old monitor, it's Dell S2715ht.
            The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
            Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
            10-30-2025, 04:45 PM
          • wattage
            by wattage
            Hello Badcaps Community,
            07-13-2025, 04:41 PM
          • ant3202
            HP 27es - LED monitor - Monitor Flashing On - Off
            by ant3202
            Hi Everyone
            Lately I am experiencing the deja-vu incident on one of the led monitor like this.
            https://www.badcaps.net/forum/troubl...lashing-on-off
            The monitor is HP 27es LED Monitor
            https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
            The monitor will randomly blackout and display no signal and will recover again.
            Sometimes need to power and off again to restore the display but...
            03-20-2025, 07:30 PM
          • Rick_1234
            by Rick_1234
            Good evening, gentlemen.
            Things I tried
            06-22-2024, 04:44 PM
