weird caps from a broken car radio
  • RukyCon
    A Fake Rubycon
    • Jan 2017
    • 816
    hello
    i opened up a broken sony car radio which i'm going to be using for parts and i'm wondering what caps i should salvage from it
    now i am going to save the rubycon and nichicon caps from it but there are 2 other brands that i need to know if they are good or not
    brands
    Rpe [the R is it a box kanda like the M on the panny caps and i've seen them in some DVD players]
    DRIVE.S [looks a lot like a UCC cap]
    i will try to take photos sometime soon
    I'm not a expert, I'm just doing my best.
  • RukyCon
    A Fake Rubycon
    • Jan 2017
    • 816
    Re: weird caps from a broken car radio
    forgot to fix some typos and i did some edits aswell
    hello
    picture of the board
    brands
    Rpe [the R is in a box kanda like the M on the panny caps and i've seen them in some DVD players and VCR's]
    DRIVE.S [looks a lot like a UCC cap. it has a brown heatshrink with gold colored text and neg stripe seen here]
    • Stefan Payne
      • 1267
      It's possible that that's some custom sleeve for Sony.
      If you order enough caps, you can ask the cap manufacturer to do some custom sleeves, as does in some lower end Super Flower designs with reddish/brownish Teapo sleeved caps or CapXon GF....
      • petehall347
        • Jan 2015
        • 4426
        • United Kingdom
        i would just buy new ones .. then save the old ones from that job .. saves work and get a pile of old caps to throw on a fire .
        • dmill89
          • Dec 2011
          • 2534
          ^This, I would suspect it is a Chemi-Con based on the vent, sleeve color, and the fact that I've seen custom sleeved Chemi-Cons in Sony receivers before (and I've seen custom sleeved Panasonics in Kenwood receivers/amps, custom sleeving appears to be fairly common for audio caps).
          • Agent24
            I see dead caps
            • Oct 2007
            • 4958
            • New Zealand
            I wonder if it's one certified for automotive use, considering the name.
            -David VanHorn
            • RukyCon
              A Fake Rubycon
              • Jan 2017
              • 816
              ok so the DRIVE.S cap could be a NCC/UCC cap
              but i still don't know if the Rpe caps are good or if they are a bad brand
              i've seen the Rpe caps it some DVD players and some VCR's tho i've never seen a dead one nor have i seen one over 220uf
              they could be a cheap chinese cap
              tho i've never seen chinese caps in any sony product i've mostly see brands like rubycon UCC and nichicon [and in older sony product's i've seen some elna caps]
              • RukyCon
                A Fake Rubycon
                • Jan 2017
                • 816
                here is a Rpe cap
                • Wester547
                  • Nov 2011
                  • 1268
                  • USA.
                  R = Tiny Rubycon. See here. That tiny 85ºC cap was made in Indonesia, during the 52nd week of 2009 (December 2009). Newer Sony products are known to have Lelon in them, in "less" critical areas. The font on that "DRIVE.S" capacitor, beneath the logo, matches that of a Chemi-con.
                  • Heihachi_73
                    • 713
                    Yep, genuine Rubycon caps have an R in a square as the logo on the really small caps, where Rubycon wouldn't fit.
                    • RukyCon
                      A Fake Rubycon
                      • Jan 2017
                      • 816
                      so the Rpe caps are rubycon ok cool
                      now i'm more likely to save them
                      and i did not know sony now uses Lelon cap sometime in less critical areas
                      so now i may get to desoldering tonight and maybe do a few dead PSU's
                      thank you
                      • dmill89
                        • Dec 2011
                        • 2534
                        Yep, at least Sony still sticks to the good stuff for the most part in "critical areas" (power supply and audio path) of their audio equipment, Yamaha uses Jamicons all over in their cheaper receivers/amps, and polk has been using crap like Jun-Fu in their powered subwoofers for over a decade, and conductive glue as well (I had a now dead Polk PSW, though it was the conductive glue and not the crap caps that killed it).
                        • RukyCon
                          A Fake Rubycon
                          • Jan 2017
                          • 816
                          some of the dead PSU's i have use that conductive glue to hold some parts down
                            by momaka
                            03-12-2025, 03:42 PM
                          • shelby5041
                            clock radio / radio lifespan?
                            by shelby5041
                            hi
                            ive got a modern digital clock radio approx 15yrs old
                            my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                            since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                            the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                            it uses very little power just a few watts i would imagine that may have something...
                            09-14-2024, 03:30 AM
                          • eryjus
                            by eryjus
                            05-10-2023, 11:21 AM
                          • Paxman_Swede
                            by Paxman_Swede
                            Hello!
                            01-14-2025, 09:51 AM
                          • UserXP
                            Vintage SONY Digital Clock Radio ICF-C12W no audio
                            by UserXP
                            Dear all,
                            I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                            i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                            My question is, do you know of this brand of capacitors and how bad are...
                            07-21-2025, 08:35 AM
