Need to replace a MSI Laptop capacitor! (Help)
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: Need to replace a MSI Laptop capacitor! (Help)
    Originally posted by jazzie366
    Hey, there's a problem with your victory, it's that that cap is a bad cap. It's a chinese unbranded generic cap. It might work for awhile, but with the heat of the laptop it's almost guaranteed to fail.
    Another this is we have no specs for the cap that you just put in there or what it's ESR is. The one you're replacing has an ESR rating for 13mOhms, that's an extremely low ESR. I can almost guarantee that china cap doesn't have a low ESR like that. You also replaced a polymer cap with an electrolytic. While this doesn't matter, the polymers are much more durable than electrolytics. Plus this is a cheap cap. I would've advised you spent an extra dollar or two on a good branded polymer cap, rather than a random one which might not last long.
    The other problem is if you put a cap that's got too high of an ESR in the place of where one that can't have that high of an ESR, you could potentially cause more problems down the road than just the cap failing.
    My advice is to replace that cap with a proper one, your choice.
    Fairly true , and i've already advised him the Panasonic ones , but he went for a lower cost , free shipping and faster delivery .. Well , we have also to include into the equation , that today , no Laptops under the 600$ barrier survive two or three years at maximum , due to poor designs and cheap components , not to mention the always defaults in South bridge or North bridge , or exploding chargers and defaulted batteries , etc.
    what's i'm sure of , this cap will survive longer ...
    • jazzie366
      • May 2016
      • 304
      Originally posted by Agent24
      They're not just more durable (apparently - time will tell), they have the much lower ESR to begin with. It certainly does matter if you replace a solid polymer with a wet electrolytic type, especially if the ESR values are wildly different.
      You can get an electrolytic down to polymer levels of low ESR, I've seen it before with Panasonic and Sanyo electrolytic capacitors, the SMD versions and regular can type.
      Popcorn.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4959
        • New Zealand
        But that isn't going to be the case with an unbranded one from eBay...
        -David VanHorn
        • Exras
          • Jan 2017
          • 7
          • Denmark
          Originally posted by jiroy
          I get your point Exras ; Here i used mf as a simple abbreviation for micro farads . I was taking for granted you won't find a 220 milli farads = 220 000 micro farads in a MSI laptop . right ? ...
          It's true that in the old days you could be pretty sure of size vs capacity, but with these super caps I feel its no longer totally obvious.
          1000mF 2,7V
          • Agent24
            I see dead caps
            • Oct 2007
            • 4959
            • New Zealand
            True, but they mark them with Farad not mF, probably for that reason.
            -David VanHorn
            • chth96
              Is it no harm to replace with capacitor without ripple current rating?
              by chth96
              When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
              Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
              But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
              Rubycon YK DataSheet (b...
              04-19-2024, 05:19 AM
            • rashidjafar
              Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
              by rashidjafar
              I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
              Values for :-
              PC43 : Capacitor [3x1.5mm]
              PL7 : Inductor [2x1mm]
              PC39 : Capacitor [1x0.5mm]
              Any ideas would be appreciated.
              I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
              08-07-2025, 05:10 PM
            • chth96
              what capacitor should I purchase for LCD display PCB?
              by chth96
              I want to fix Video door phone which works its doorbell but it is not able to display any screen.
              So I disassembled its plastic case and I detached FPC film cable from LCD display in order to inspect LCD display's PCB
              I measured ESR resistance of all smd capacitor on this PCB and I noticed that there is some SMD capacitor which has high ESR value(48ohm 50V 0.47uf,15 and 28 ohm 50v 3.3uf,10 and 8 ohm 35v 10uf)
              I desoldered this 5 suspicious SMD capacitor like below screenshot.
              images2.imgbox.com/51/b8/8WVZwDpV_o.jpg
              But I cannot identify specification of desoldered...
              05-24-2025, 09:25 PM
              Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
              This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
              09-06-2024, 09:30 PM
              Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
              This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
              09-06-2024, 08:47 AM
