3300uf 6.3V Rubycon caps on Ebay
  • Roadkill203
    • Oct 2008
    • 68
    I'm re-capping a board (first time), it's a VIA P4PB 400 Rev C2 (doing it for my sister), and I found these 3300uf 6.3V Rubycon caps on Ebay HERE, and I was wondering what the downside of getting them is (I know that there has to be a down side!); I would appreciate any info at all, I am totally a newbie at re-capping - Thanks!
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Re: 3300uf 6.3V Rubycon caps on Ebay
    I don't know any reason why you should not buying them but maybe they are old as I see a code T0344 and T0345 on them; it could be that 03 stand for 2003 and 44 and 45 is the week... so they have 5 years.
    I'm not sure it is in this way, hope some experienced member can confirm or clarify it.
    I'm writing you because I recap a P4PB 400 two months ago and I don't remember any 3300uF caps on it but 2200uF near CPU so you are going to increase the total capacity if you use bigger cap; it should be ok but once again wait feedback from other members.
    You need also some 1000uF 6.3V (10V) to completely recap this board, it is not enough to change only 6 caps.
    There are also 4 1000uF 16V if I remember well.
    I hope you succeed because the board I recapped had a lot of problem and was unreliable.
    Ciao
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
    • i4004
      • Oct 2006
      • 2029
      seller is "dementg", and on forum we have "gdement"...
      just wondering....
      • Roadkill203
        • Oct 2008
        • 68
        Ciao
        Gianni
        On my board, right by the processor, the caps are 3300uF. Every single one of them was bulging, and I was having problems, like the computer would freeze up after running for a few hours, and it wouldn't re-start until I turned of the power supply at least three or four times.
        Thanks for the advice Gianni, but I'm gonna change these seven and then see what happens. I know that I probably should be changing out all of the caps that you mentioned, but it's not my rig, and I want to do this as quick as possible; it took me three hours yesterday to de-solder the 7 bulging caps by the processor! I don't know if I fried the board in the process, but again, this is my first re-cap job, and I am a trial-by-fire kind of guy; that is to say that I don't learn my lesson until I fuck something up royally, and I always jump in way over my head into unknown waters, so this job seems right up my alley!
        I am an auto mechanic by trade, computer repair is a hobby of mine. When I started fixing cars, I don't remember pulling any engines on the first day, so 7 caps is a pretty good start! I don't plan on being an expert at re-capping for at least two, maybe three months...
        Thanks for the positive feedback, Gianni. Can anyone shed any more light on my misdoings?
        • Scenic
          o.O
          • Sep 2007
          • 2642
          http://stores.ebay.com/PC-MotherBoar...2QQlnsZ1QQtZkm
          my fav. ebay shop for smaller quantities..
          and of course one for having "a few" caps as spare..
          http://search.ebay.com/cap-audio-fil...2dpolyesterQ2a
          closest match: http://cgi.ebay.com/100PCS-3300uF-6-...QQcmdZViewItem
          but 100pcs would be a little overkill for 1 board *lol*
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            I did a cap swap with him for 500 caps.
            Some I got where those exact caps you linked to.
            They are fine.
            Mann-Made Global Warming.
            - Dr Seuss
            • Roadkill203
              • Oct 2008
              • 68
              Well, I bought those caps on Ebay, and I finished re-capping my board today, got it all back together and it started up (I was fucking amazed!), now I'll leave it on overnight to see if it freezes up anymore... Any more 'board testing' suggestions?
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                I like to run memtest for a few hours (and at least 5 or 6 passes) as the first check.
                - Dr Seuss
                • Wizard
                  • Mar 2008
                  • 2296
                  Run Prime95 torture test.
                  This will turn up any weak filtering circuits or incomplete cap job.
                  Cheers, Wizard
                    by momaka
                    03-12-2025, 03:42 PM
                  • eryjus
                    by eryjus
                    05-10-2023, 11:21 AM
                  • Paxman_Swede
                    by Paxman_Swede
                    Hello!
                    01-14-2025, 09:51 AM
                    by momaka
                    03-15-2023, 10:17 PM
                  • captain150
                    by captain150
                    03-16-2025, 07:34 PM
