Why leave < 470 uf?
  • Computergeek1200
    • Sep 2006
    • 16
    Why leave < 470 uf?
    I have been recapping for a while now. However, I do not know much about the workings/chemistry of the capacitor. I have found that replacing the 10uf caps in mice can improve their performance. I am wondering why some people advise that you leave capacitors less than 470uf?
  • zandrax
    Hit and miss
    • Dec 2007
    • 1157
    • Italy
    Re: Why leave &lt; 470 uf?
    Because on motherboards caps of such or inferior capacity are minor ones, used in zones less stressed than a VRM.
    Zandrax
    Have an happy life.
    • linuxguru
      • Apr 2005
      • 1564
      It depends, if they're near the Southbridge or DIMM slots, it will probably help to replace them as well, if there are mysterious instability issues.
      • valvashon
        32" Philips PAL TV from India- should I get it or leave it for somebody else?
        by valvashon
        I know this isn't troubleshooting related but thought it was the best place to ask. There is a supposedly working 32" Philips flat screen originally from India for free near me on FB Marketplace. It's a PAL receiver but will do NTSC (?) from the HDMI inputs. Will add the model number later. I like quirky stuff but have plenty of TV's/monitors around so I don't really know what to do with it. Should I get it and see if there is a compatible NTSC/ATSC tuner board that could be swapped in?
        Val
        09-12-2025, 11:09 AM
      • hammi1
        Missing pad on 1080 Ti looks to be non connected...fine to leave it as is?
        by hammi1
        Hello! I'm replacing a RAM chip on my 1080 ti and may have taken the old one off too soon, as one pad seems to be missing.
        According to the Micron datasheet, it seems to be TDO (JTAG Test Data Out). On the PCB I don't see any connections (i.e. tracks) connected to that pad. Am I right in thinking I can leave it as it is when I put a new chip? (I might have to strategically remove the TDO solder ball on the chip so it doesn't try to flow anywhere else)
        Thank you...
        03-22-2022, 06:41 AM
      • DXseekerMO
        Lg 49uf6400...leave it to lg to put in some stupid backlight connector
        by DXseekerMO
        LG 49UF6400....LEAVE IT TO LG TO PUT SOME STUPID BACKLIGHT CONNECTOR on the LED strips that TAKES A MENSA CERTIFIED GENIUS to figure out how to detach.
        Can anyone tell me how these connectors detach from the LED strips?
        Thanks for your help folks!...
        09-29-2021, 01:23 PM
      • capwizard
        Leave me alone............. khufu's secret
        by capwizard
        Samsung UN50H5203AF screen is blinking, ( picture 1)TV has total 60 LEDs , 34 LEDs no good, best way is change all the LED strips but I am lazy.
        why tv is blinking, i think, over current power supply caused the blinking,
        34 leds should be shorted, takeout bad leds or led trips is lots of work. why not just leave leds alone, so i need to add 26 leds to the tv panel.
        Common Samsung UN series screen blinking problems. leave bad LEDs alone.....the easiest way is to add LEDs on. This is a good way if you are lazy.
        ( picture3) TV blacklight is working. What...
        02-01-2019, 09:22 PM
      • dougg3
        Faytech FT0150TM touchscreen turning on and off - fixed
        by dougg3
        I've been dealing with this 15" touchscreen monitor from the early 2010s. Over time, it has become more and more difficult to power on. As soon as a video signal comes in, the Faytech logo appears on the screen and then it goes black. Then a couple of seconds later the Faytech logo comes back up on the screen and it goes black again. This process repeats over and over again. Eventually if I leave it on long enough, the video display finally comes up and it works fine. The longer I leave it turned off, the longer it will boot loop before working correctly again. I tried a different AC adapter...
        02-03-2024, 03:04 PM
