Lg 49uf6400...leave it to lg to put in some stupid backlight connector
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    LG 49UF6400....LEAVE IT TO LG TO PUT SOME STUPID BACKLIGHT CONNECTOR on the LED strips that TAKES A MENSA CERTIFIED GENIUS to figure out how to detach.
    Can anyone tell me how these connectors detach from the LED strips?
    Thanks for your help folks!
    They call me......."threadkiller"
  • ramondo
    Confused Member
    • Jun 2015
    • 39
    Re: Lg 49uf6400...leave it to lg to put in some stupid backlight connector
    Google LG Led image, looks like squeeze and lift. Not exact but close.
    Thanks to all for being__WAR_KITTENS____!
    • neilc6
      • Nov 2015
      • 1550
      It pops up like the LB strips.
      • DXseekerMO
        • Feb 2018
        • 1119
        • US
        I was able to lift the connector and detach it. THANKS!
        • Tomylee
          No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
          by Tomylee
          Sorry for the person who’s going to read all this !
          I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
          While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
          During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
          07-11-2025, 11:52 AM
        • 5mall5nail5
          Help identifying connector for ASUS 4090 Strix RGB LED connector
          by 5mall5nail5
          Hi All -
          I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
          Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
          05-04-2025, 07:47 AM
        • bussincaps
          MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
          by bussincaps
          Hello All,
          tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
          Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
          eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
          Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
          I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
          08-03-2023, 12:57 PM
        • michhak
          Toshiba Satellite M50-A keyboard connector on LA-A481P motherboard
          by michhak
          Hi guys,
          i have a damaged keyboard connector on my older Toshiba Satellite M50-A laptop. I know there is LA-A481P motherboard. In attachment pictures there is a real looking connector and i also found a schematic to the connector. But i need help with finding a real electronic part to replace the damaged connector. e.g. on aliexpress (or different page).
          It is 34pin connector and the length from pin n.1 to pin n.34 is 26mm. So it means a pitch length is 0.764 mm. I have seen connectors with 0.5mm , 0.7mm , 0.8mm and 1mm pitch length. But not with 0.75. Is it some special custom connector...
          11-17-2021, 05:45 AM
