Missing pad on 1080 Ti looks to be non connected...fine to leave it as is?
  • hammi1
    • Mar 2022
    Hello! I'm replacing a RAM chip on my 1080 ti and may have taken the old one off too soon, as one pad seems to be missing.
    According to the Micron datasheet, it seems to be TDO (JTAG Test Data Out). On the PCB I don't see any connections (i.e. tracks) connected to that pad. Am I right in thinking I can leave it as it is when I put a new chip? (I might have to strategically remove the TDO solder ball on the chip so it doesn't try to flow anywhere else)
    Thank you
  • DynaxSC
    • Apr 2021
    • 475
    • Poland
    Re: Missing pad on 1080 Ti looks to be non connected...fine to leave it as is?
    Had once same case, I checked at that time with a schematics and as far as I remember JTAG interface is 99% not used, I would not care about this pad. Unconnected pads tend to get off the PCB as they are not so strongly glued to the PCB due to the small pad area.
    • hammi1
      • Mar 2022
      Thanks for the reply, I couldn't find many sources online about whether the JTAG pads were used, so it makes sense that it'd not be connected. Luckily it looks like that's the only missing pad, so I might be able to restore this card to a fully functioning state
        NVIDIA GeForce GTX 1080 1080Ti Schematic & Board View
        The GeForce GTX 1080 was a high-end graphics card by NVIDIA, launched on May 27th, 2016. Built on the 16 nm process, and based on the GP104 graphics processor, in its GP104-400-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 1080. The GP104 graphics processor is a large chip with a die area of 314 mm² and 7,200 million transistors. It features 2560 shading units, 160 texture mapping units, and 64 ROPs. NVIDIA has paired 8 GB GDDR5X memory with the GeForce GTX 1080, which...
        10-02-2024, 07:37 AM
        ASUS ZenBook 14 Gun Grey FHD (1920 x 1080) 16:9 Intel Core i5-10210U Processor NVIDIA GeForce MX250 512GB M.2 NVMe PCIe SSD Hybrid (2-in-1) 14 Specification for Upgrade or Repair
        This specification for the ASUS ZenBook 14 Gun Grey FHD (1920 x 1080) 16:9 Intel Core i5-10210U Processor NVIDIA GeForce MX250 512GB M.2 NVMe PCIe SSD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 Gun Grey FHD (1920 x 1080) 16:9 Intel Core i5-10210U Processor NVIDIA GeForce MX250 512GB M.2 NVMe PCIe SSD boardview and 14 Gun Grey FHD (1920 x 1080) 16:9 Intel Core i5-10210U Processor NVIDIA GeForce MX250 512GB M.2 NVMe PCIe SSD schematic. Our users have donated over...
        09-06-2024, 05:30 PM
      • ugamazing
        820-02020 PPBUS_AON missing
        by ugamazing
        Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
        Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
        02-05-2025, 04:21 PM
      • jpreza
        Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
        by jpreza
        I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
        Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
        It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
        Looking at the card, it appears to be missing the following:
        1x 1.0uH inductor - orange square
        2x...
        11-01-2024, 10:54 PM
      • gurj1979
        Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
        by gurj1979
        Hey guys.
        Need help with this one.
        Fan not spinning due to missing PWN Fan signal.
        Also 5 seconds from powering up it freezes, unless in BIOS.
        But as soon as Windows starts to load, it will freeze.
        CPU is COLD / Room temp when it freezes.
        I've replaced the CPU, same problem.
        Replaced SIO/KBC IT8987e and reprogrammed - same problem.
        Replaced fan - same problem.
        Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
        Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
        08-19-2024, 05:22 PM
