bad links lead to virus
  • mnrdtl
    • Oct 2016
    • 20
    • usa
    Right after i started on this site and following links my PC is now infected with virus's. Anyone else have problems?
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: bad links lead to virus
    I have been using this site for quite awhile and never had a problem. The people who do the software for this site are very good at what they do. If you have a problem with a link you should let them know what link. When you go to a link that means you have left this site and they do not have control over that site the only thing is they can remove the link on this site.
    • diif
      • Feb 2014
      • 6978
      • England
      Which links did you follow ?
      If visiting a webpage is getting you infected, i suggest ensuring you're patched and up to date with your OS , web browser and addons such as Flash.
      • RJARRRPCGP
        • Jul 2004
        • 6304
        wcax.com is unsafe to visit right now, due to a code injection. You can expect to get scam scareware there! That one telling you to call and it bleeps.
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
          master hoarder
          • May 2008
          • 12175
          It would help to know in which thread you found the links.
          I've been on badcaps.net for close to 8 years now. Most links that people post are safe. But like keeney123 said, these are external sites, so badcaps.net has no control over the content that is posted there. The links could be fine today and infected tomorrow. So you should exercise caution not just on badcaps.net, but anywhere on the internet really.
          Like Diff said, make sure your OS and software is patched up properly. Better yet, use a HOSTS file (if using a Windows OS). That will cut down on probably 90% of the bad stuff that can infect your computer, if not more. AdBlock Plus may also help you avoid clicking on click-bait advertisements.
          Lastly, don't rely on anti-virus software only (in fact, don't rely on it at all). Common sense is by far the best method to keep your PC clean. Always verify that the links posted match the links shown in your status bar of your browser. And avoid external image hosts if possible (like imageshack and photobucket) - they've been known to have malicious ads from time to time. There was just a thread here not too long ago that had that and Topcat (the site admin) had to remove them.
          • mnrdtl
            • Oct 2016
            • 20
            • usa
            My OS has always been up to date as well as AdBlock and others. There was a link or 2 to photobucket.
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Did you get one with a message on a web page saying that you're compromised
              and the PC bleeps... That's the kind of scareware that computer noobs are falling prey to...
              Arc A770 16 GB
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16959
                this site is clean/clear. off-site links, we are not responsible for. if you can tell me where the link was, I'll be glad to remove it.
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • ChaosLegionnaire
                  HC Overclocker
                  • Jul 2012
                  • 3266
                  • Singapore
                  yupp, if u find a post with a malicious link or content, the proper way on a forum to do it is to use the report post button on the lower left corner of the post to report the offending post to a mod/admin.
                  • mon2
                    Hunting down a virus in an office
                    by mon2
                    Hi. We have an office client who has been contacted by the local internet provider that one of the office Windows PCs is infected with a virus. The report has been confirmed. Apparently through a remote outside trigger, this virus is performing brute force attacks around the world from this local IP address at varying times. Aside from low level formatting each PC, what is the recommended approach for this case? Running F-prot (suggested by the internet supplier) has come up empty. We are planning to run hijack this. At this time, we do not know which PC is creating this issue. Internet provider...
                    01-09-2025, 09:42 PM
                  • chj4591
                    gddr5 ball lead?
                    by chj4591
                    gddr5 memory ball lead size?
                    0.4mm 0.45mm 0.5mm​
                    05-05-2025, 10:42 PM
                  • Eh546
                    Beginner, practicing to unsolder on a lead free xbox 360 board, it is hell.
                    by Eh546
                    Don't hesitate to tell me what i do wrong and if you have any tips and tricks, because i want to learn and improve.
                    I have a 60w iron that can go up to 450c, cone tip, i usually set it at 400. I applied flux on solder, tinning the tip then applying new lead solder to the joint so that it can mix with the lead free and lower the melting point, then i tried to suck up the melted solder with the solder sucker. But that didn't work since the lead solder doesn't seems to mix with the lead free one. I also tried applying flux to a wick and the board, then tinning the tip of the iron and...
                    05-24-2020, 06:59 PM
                  • Stanley1843
                    BEST 505 Vs Mechanic Brand Reballing Balls with Lead
                    by Stanley1843
                    has anyone use these Brands of solder balls? The brand BEST writes on the label of the jar the specs of the solder balls instead of the Mechanic brand. I beleive that BEST brand must be more professional (in labeling at least) but I have never try one of them so I would like your opinion. By the way I hardly can I find the Mechanic brand in aliexpress (the only where I found was lead free solder balls) and on ebay these that I found are approximately15USD per jar. If you know any other trusted brand of solder balls please tell me.
                    06-22-2024, 11:06 AM
                    FNIRSI HRM-10 Internal Resistance Detector AC Lead Acid Lithium Battery Tester Review on some testing of device
                    https://www.ebay.com/itm/405035016711
                    I got this device yesterday and did some testing on some tabbing and some incandescent light bulbs and it seems to work very well from what I can tell but how do I know how accurate the m-ohms section is what can I use to verify it accurately I also tested some li-ion battery cells and this seems to be fairly accurate because I have another tester and they seem to agree with each other
                    I also checked some capacitors with it that were brand new and seem to show about what I expected to see with my blue capacitor tester so I think it...
                    04-13-2025, 08:17 PM
