Failed Recap -New capacitor very hot to the touch
  • powrslave007
    • Sep 2008
    • 4
    Hi all - I just attempted my 2nd recap - this time without success. I replaced a bad Rubycon MBZ 6.3v 1000u with a Rubycon MCZ 6.3v 820u (all I have at the moment) -at first I thought the recap was successful, but the PC soon rebooted and I can hear a slight crackling/popping sound coming from the motherboard. Has anyone seen something similar? The new cap got very hot to the touch and FAST - the PC was probably on for less than 1 minute.
    FYI, the Motherboard I'm doing the recap on is a IBM Barbados 915G/GV
    Thanks!
  • gdement
    • Jan 2007
    • 690
    Re: Failed Recap -New capacitor very hot to the touch
    Make sure you didn't put it in backwards. Also look for shorts.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      post a pic of the board and the area of this cap.
      • powrslave007
        • Sep 2008
        • 4
        Here is a pic - the replacement Cap is in the middle - notice the black heatsink looking item placed close to this cap - it also gets VERY hot VERY fast. That area of the board appears to be slightly discolored - scorched? -
        • linuxguru
          • Apr 2005
          • 1564
          That FET (Q190?) below the cap is probably cooked (shorted), and the rail that is powered by that VRM may have had an overvoltage as a result. If that has happened, a lot of mobo components could have gone south (CPU, Northbridge, memory, ...). Just pray that the FET shorted to ground rather than from the input to inductor junction.
          The only course is to replace the FET (maybe two FETs on that rail), check the inductor and replace if necessary, and try again. Look for shorts on every rail before powering up again. If you're lucky, only Vcore may have had an overvoltage - the CPU may have fried, but your Northbridge and Southbridge may have survived. If you're unlucky, lots of things may have fried.
          • bgavin
            • Jan 2007
            • 1355
            I see the coloration difference in the phot.
            LG, how difficult is changing it out? Never done one, don't have the parts, but could probably scrounge off a dead board. Just curious
            • linuxguru
              • Apr 2005
              • 1564
              Replacing FETs soldered to large copper planes is painful, but it can be attempted with suitable tools - hot-air gun, some kind of metal stencils to protect adjacent plastics, and a pair of hemostats to dislodge the FET when the solder softens. It may not be worth the effort unless the rest of the board is believed to be functional.
              • severach
                • Aug 2007
                • 1055
                I've done it with a Weller 140w heating the large pad and backing plate and a small iron heating the other pads. It takes two people and the person helping me was a bit drunk and we didn't have the proper grabber tools so the quality wasn't very good.
                sig files are for morons
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4976
                  • New Zealand
                  I imagine the overheating did not occur before you did the recap?
                  Perhaps you shorted something when you did the soldering?
                  -David VanHorn
                  • wtimber
                    • Dec 2011
                    I have 10 of these systems with these failed boards, FRU 39J6196. I called IBM and they want $1866.00 for the replacement board FRU 41T3044. We have 32 more of these systems in service until they also fry. They are failing at a rate of about two a week now. I tried replacing the caps and had the same result as above. Has anyone replaced the FET on these boards yet?
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      In my experience those FETs aren't that hard to replace. All you need is a fat iron (60W plus) with a wide chisel tip, and a finer one.
                      With the fine iron heat the legs, use braid to get as much solder out as possible, and then carefully lift one leg at a time with a pair of tweezers or a small screwdriver. Then heat up the fat iron, keep it on the tab of the FET for 30 seconds or so, and push it a little. If the FET moves easily when you push on it with the iron then it means the solder has melted - just use a pair of pliers to grab it and lift it off the board.
                      To put a new one in just do the steps in reverse - align it, solder the legs first so that it doesn't move, then keep the big iron on the tab of the FET and push on it until you feel it sink into the solder. Lift the iron, let the board cool, and it's job done.
                      A working TV? How boring!
                      • Evil Lurker
                        Warranty Voider
                        • Feb 2011
                        • 454
                        Also the magnet wire trick works too, just take some magnet wire (easily salvaged from an old transformer, its coated so it won't stick to the solder), wrap it thru in between the body and pins, heat up the pin and pull the wire. If you properly desoldered the pin with a wick first it should pop right loose. Then you can take your iron and work on removing the back pad.
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          watch out for reversed markings on your board.
                          look at other caps to see the marking.most have a half circle for neg but a few(asus,asrock,asus oem,)have it positive.
                          iirc some of these are asus oem.
                          • trepachka
                            Converting HP EliteBook 840 G7 non-touch to touch if possible
                            by trepachka
                            I am trying to convert a HP EliteBook 840 G7 notebook from a non-touch to a touchscreen. I purchased a complete touch LCD assembly with a screen/back cover/bezel/video cable and swapped it out with the original non-touch LCD assembly.
                            The screen works but the touch does not. I know the new LCD assembly is completely functional because we tried it on a similar touchscreen EliteBook 840 G7 and the touch works there.
                            I contacted the seller and he said screen conversion like this will not work due some difference in the motherboard for non-touch and touch capable EliteBook 840 G7.
                            04-27-2024, 11:15 PM
                          • Prott
                            Surface Pro 4/5 - no touch after LCD change
                            by Prott
                            I have a question that's driving me a bit nuts recently.
                            Is the touch board on Surface Pro 4/5 somehow married to the motherboard? I have a few Surfaces that, after the touch board change, lost all touch functionality.
                            - I tried flashing the bios (simple ME clean from a known good bios, previous bios didn't have an intergrated hub enabled), reinstalling firmware, reinstalling windows and even new touch boards.
                            - In one instance, after I tried to troubleshoot by using a known good screen + touch pcb combo on a Surface that lost touch, the touch board...
                            01-25-2023, 12:42 PM
                          • Prolog
                            RTX 3080 FE Identifying capacitor
                            by Prolog
                            Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                            I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                            I hope these photos make it clear which component I am referring to:
                            (yes, the soldering is a bit botched from removing the blown one, I know)
                            I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                            12-01-2024, 08:27 PM
                          • chth96
                            If I replace with inferior capacitor, Is it No harm to other IC components at all?
                            by chth96
                            I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                            Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                            It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                            So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                            I know that these capacitor will not last as long as nichicon capacitor...
                            12-22-2023, 04:34 AM
                            Dynabook Portege X40-K, i7-1260P, 14" FHD TOUCH, 16GB, 512GB SSD, T/BOLT, W11P, 3YR Notebook Specification for Upgrade or Repair
                            This specification for the Dynabook Portege X40-K, i7-1260P, 14" FHD TOUCH, 16GB, 512GB SSD, T/BOLT, W11P, 3YR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X40-K, i7-1260P, 14" FHD TOUCH, 16GB, 512GB SSD, T/BOLT, W11P, 3YR boardview and X40-K, i7-1260P, 14" FHD TOUCH, 16GB, 512GB SSD, T/BOLT, W11P, 3YR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                            09-07-2024, 05:50 AM
