Lathe digital readout
  • crosswinds
    • Oct 2016
    • 30
    • Europe
    Hello!
    Im trying to help a friend with a digital readout "headunit".
    It reads scales from two axis and displays on LED segments.
    One of the axis, gets a "error" message at random times (getting worse).
    So the first thought is that it is the scale, but we have shifted the scales, and it still gets on the same axis on the DRO.
    So i opened up the unit, to have a Quick look.
    I pulled out my ESR-meter, and started to check the caps on the small PSU-board inside the unit..
    I did find Three that is a bit off from specs in the datasheet(total of 7 on the psu-card):
    Chemi-con SXE
    35v 220uF 0.51 ohm
    35v 220uF 1.1 ohm
    10v 470uf 1.2 ohm.
    These are placed on the secondary side of the PSU..
    My question is, are these ESR values "bad enough" to be able to cause any interference with the Circuits after it? I seem to remember ESR-values in the datasheet for the SXE to be esr at around 0.18.
    The DRO is probably very very picky with its signal from the scales, to make sure of no faults in the Readings. and the scales seem to be directly fed from the psu.
    The problem occurance Changes with the units temperature. Cold seem to make it worse.
  • junktv
    • Nov 2010
    • 3065
    Re: Lathe digital readout
    Pics model of the dro? Glass or mag?
    • crosswinds
      • Oct 2016
      • 30
      • Europe
      Thanks for your reply
      Sorry, no pics at hand right now.
      Its a Sony LH 32 and its magnetic
      • junktv
        • Nov 2010
        • 3065
        I was looking into this as a hobby/start if i found a smaller vmc cheap and planned to go glass and mach3 instead of a dro. That isn't a hobby level dro you have but may check wires and connectors also. Scales and limit switches needed to be shielded from what i remember. If the cables are older you may try replacing those and see if it goes away. It's cheap and if older they are more than likely broken down. A machine shop is a rather harsh environment.
        The fact you have a esr meter tells me you know more than i do on the board level stuff. I didn't know if it was diy shumatech? dro or something. Although i doubt they are used much any more. These nerds are getting fancy in the home cnc world.
          • 31015
          just replace every cap with low esr like panasonic FR,
          you need better than average caps in these type of applications because of the electrical noise when the motors are driven.
          • rievax_60
            • May 2012
            • 897
            • australia
            Look for a backup battery that might be leaking.
            • crosswinds
              • Oct 2016
              • 30
              • Europe
              Thanks for your reply!
              My regular supplier does have the FR series.
              This is the list for all of the unit:
              400V 68uF TSNH 1x
              35v 220uF SXE 2x
              25v 47uF Nichicon PL(M) 2x
              10v 1000uF SXE 2x
              10v 470uF SXE 4x
              50v 4.7uF H9401 Nichicon 1x
              16v 120uF Nichicon PF(M) 6x
              10v 470uF Nichicon PF(M) 1x
              10v 82uF SXE 1x
              Do you think everyone of these are safe to be replaced with Panasonic FR?
              The unit does not seem to have a backup battery.
                • 31015
                SXE sounds seriously old!
                btw, you need to include diameter & height (unless height is not an issue)
                • crosswinds
                  • Oct 2016
                  • 30
                  • Europe
                  Hehe yes! The unit is from the first half of 1990´s
                  The height and diameter is about right on those i can find.
                  But can i replace them all with the FR series? (some they reffer to FM)
                  What do you Think about the measured ESR and the problem at hand? Might we be on to something?
                    • 31015
                    well the 400v one you can leave - that's a panasonic part and a good one.
                    the others i would go for - nothing to lose.
                    • crosswinds
                      • Oct 2016
                      • 30
                      • Europe
                      Alright! And the nichicon ones is compatible with FR/FM series?
                        • 31015
                        probably.
                        no better answer without a schematic
                        • crosswinds
                          • Oct 2016
                          • 30
                          • Europe
                          No schematic available, sorry.
                          Well all Panasonic FR is on order, so i hope Everything goes well
                          : Nichicon PF seem to be low impedence, and PL is "extremely low impedance" ..
                          According to the datasheet the Panasonic ones is of impedence, but hopefully thats a good thing?
                          • delaware74b
                            • Apr 2009
                            • 628
                            First week of 1994, H9401 is the plant(H), 94=1994 01= first week
                            Definitely a '94 build, time for a recap....
                            Stupidity should be a crime, especially for drivers. I have NO patience for them.
                            • kc8adu
                              • Nov 2003
                              • 8832
                              • U.S.A!
                              yes replace ALL lytics.these units are often left on 24/7 and the caps are done.
                              have not seen further glitches after a total recap.and thats after servicing hundreds of these.
                              • crosswinds
                                • Oct 2016
                                • 30
                                • Europe
                                Hello everyone.
                                Thanks for your input.
                                I have now replaced them all(except one that im still waiting on, ofcourse)
                                And ALL of the Nichicon 16v 120uF on the "sensor board" have leaked from the bottom. Very small amounts, so not visible Before i lifted them.. One of them directly connected with the problematic axis, actually have leaked bad and eaten the traces. So that was probably the cause of the failure. So i had to bridge that trace. thats never fun, but had to be done.
                                Some of the SXE on the PSU also had leaked from the bottom, but no traces on that side..
                                Will let you know how it works after i recieve the last one!
                                • kc8adu
                                  • Nov 2003
                                  • 8832
                                  • U.S.A!
                                  it will.
                                  the 2 in my boneyard are lightning kills.
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    Nice work crosswinds! Do post pictures if possible, always fun to see the object in question
                                    • crosswinds
                                      • Oct 2016
                                      • 30
                                      • Europe
                                      Hello again!
                                      Success! The unit is now working great again.
                                      Thank you all for your help and input.
                                      Sorry, i do not have any picture of the unit.
                                      • Dannyx
                                        Repairing digital scales (readout not stablizing)
                                        by Dannyx
                                        Good day folks. Some of you may know that this place where I work at gets its hands on all sorts of crap, from your usual stuff like TVs and PCs to fairly niche stuff like audio mixers and to downright junk like VCRs and CD players.
                                        The device I currently have on hand falls in the second category, niche stuff, which is a set of digital scales which you'd find in a small supermarket. It's not a cash register, it just weighs stuff and displays it. It turns on alright but the problem is the readout never stabilizes: it fluctuates up/down by roughly 5 grams and it seems it tends to...
                                        03-20-2019, 11:24 AM
                                      • wolf1976
                                        is there any univarsal wifi motherboard that supports and digital tvs ?
                                        by wolf1976
                                        hi i want to convert my simple digital tv because the motherboard is dead to wifi motherboard but with the ability has and tuner for digital channels DVB-T compatible in europe
                                        is there ?
                                        do you have to suggest me one ?
                                        thanks on advance...
                                        01-05-2025, 04:29 PM
                                      • sbt123
                                        charnwood w821 mini wood lathe motor problem
                                        by sbt123
                                        hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                                        10-27-2024, 03:43 AM
                                      • Bektronics
                                        Schematic Digital Audio mixer RCF type M18
                                        by Bektronics
                                        Hello dear audio friends.
                                        I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
                                        The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
                                        I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
                                        Thanks in advance if anyone can help me with this schematic.
                                        Of course, all information about this digital mixer and possibly references...
                                        07-24-2023, 06:40 AM
                                      • bohaboha
                                        ADVICE FOR BUYING A DIGITAL MICROSCOPE
                                        by bohaboha
                                        Hi I'm thinking of buying this :1080P 4K HD Industrial Microscope 150X C-Mount Lens 48MP/13MP Digital Camera HDMI USB-C VGA Measurement For PCB Soldering DIY it's on ALiExpress : https://www.aliexpress.com/item/1005...av-description
                                        the one i choose is the D full Set
                                        maybe you can advise me or maybe someone who has similar who can give feedback on it very grateful for...
                                        02-24-2025, 07:13 PM
