Should I worry about Polymer Capacitor higher leakage current
  • primetime
    • Oct 2014
    • 12
    A few electrolytic capacitors on my 300 watt subwoofer has blown. I was thinking of replacing them with polymer capacitors for their higher temperature and ripple current tolerance and low ESR. However, the leakage current is also sixty times higher. For example, I can get a Panasonic FR capacitor which has a 3uA max leakage current rating while a polymer capacitor will have a 200uA leakage current. Should I be concerned? Is the polymer capacitor a viable replacement or should I stick with regular capacitors?
    • 31170
    Re: Should I worry about Polymer Capacitor higher leakage current
    i would be more concerned with the esr being much lower.
    • Mint Waxed
      • Aug 2016
      • 35
      Wow! That's really a good question. My gut feeling is that the original design called for electrolytic either due to a technical factor or if not that, to cut costs. If it were my sub woofer, I think I would replace all the electrolytics using the same values but boost the temp rating to 105C. Unless you have some special smoke & mirrors design, I would use the Panasonic NHG standard series.
      • SwedishDiesel
        Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
        by SwedishDiesel
        Howdy folks,
        I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
        10-30-2021, 12:47 AM
        Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
        I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
        I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
        I tested the battery cells there are installed right now and they are testing good with no issues that I...
        02-04-2025, 08:08 PM
        ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
        Highly Integrated Narrow VDC Battery Charger for Notebook Computers
        The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
        for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
        Narrow VDC applications where the system power source is
        either the battery pack or the regulated output of the charger.
        This makes the max voltage to the system equal to the max
        battery voltage instead of the max adapter voltage. Operating
        at lower system voltage can improve...
        11-05-2024, 04:43 PM
        Diodes AP21X2SG-13 AP21X2MPG-13 Current Limited Power Switch for Laptop Computer Datasheet
        The AP2182 and AP2192 (AP21X2SG-13 AP21X2MPG-13) are integrated high-side power switches optimized for Universal Serial Bus (USB) and other hot-swap applications. The family of devices complies with USB 2.0 and available with both polarities of Enable input. They offer current and thermal limiting and short circuit protection as well as controlled rise time and under-voltage lockout functionality. A 7ms deglitch capability on the open-drain Flag output prevents false over-current reporting and does not require any external components.
        All AP21X2SG-13 AP21X2MPG-13 devices are available...
        10-23-2024, 03:33 AM
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
