ESR Mania
  • Mint Waxed
    • Aug 2016
    • 35
    ESR Mania
    I recently repaired some power & video boards found in Gateway monitors (built by Samsung) suffering with the capacitor plague of 2005. I had purchased a number of these years ago when they were being liquidated on eBay. Well, I guess "dumped" would be a better phrase since sellers who had no knowledge of electronics were in a panic to get rid of them since warranties had run out.
    There has been some talk of capacitor ESR so just for grins, I included some of the Panasonic FR series in my last parts order to replenish my parts cabinets. The majority of electrolytics I use are the NHG standard series but wanted to recap one machine in particular with low ESR. As expected, there was no noticeable difference visually or when taking voltage readings. Probably due to the fact that my application is not mil spec or some specialized device. The price difference is not significant so I see nothing wrong with seeking out low ESR caps when available.
    But here lies the crux of the problem. It's been my experience that foreign manufactures are only interested in selling products with no attention given to essential items like schematic diagrams, pictorial drawings, parts lists, and trouble shooting flow charts & procedures. Further, when you look at the side of an existing capacitor, you typically only see the capacitance, voltage rating, and temperature. If lucky, some have a logo & series stamped on them and can be found during a lookup. I estimate few electronics enthusiasts even bother with this. If it walks like a capacitor and quacks like a capacitor, we'll just grab an 85 degree from Radio Shack.
    Which leads to expensive ESR meters. Quite the expensive tool for a one time use in my opinion. Capacitors have a finite life span and their age should be taken into consideration before using. I always buy new ones of the correct series for repair projects then check them on the capacitance meter to see if within tolerance. Perhaps someday there will be a more dependable yet affordable replacement for the annoying and problematic electrolytic.
    I notice higher end computer motherboards designed for over-clocking are completely void of electrolytic types. Too bad the same can't be said for computer power supplies.
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Re: ESR Mania
    I know, right!? You'd think that we'd go almost ALL polymer caps nowadays!!
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
      • 31278
      Re: ESR Mania
      they dont last forever,
      i have pulled old sanyo purple-sleeve poly's and unknown printed-can types from stuff and found the leakage rising and capacitance dropping.
      ESR seems stable though.
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3266
        • Singapore
        Re: ESR Mania
        and the culprit? usually the psu imo and ime (in my experience). have a gigabyte mobo with fujitsu fpcaps that was killed by a fuh-joo-yoo psu. even if polys have high ripple current handling capability, dont push your luck!
        power supplies cant use polys because they dont come in high capacitance. psus need 2200-3300uF caps for some of the rails. hard to make a poly with that high capacitance. the esr may also be too low for polys and the switching regulator doesnt like it. it wants normal low esr not ultra low esr.
        • TechGeek
          Computer Geek
          • Jan 2015
          • 2254
          Re: ESR Mania
          well couldn't some engineers make a normal low ESR poly formula above 5000uF? Or is that way too impractical?
          sigpic
          • Mint Waxed
            • Aug 2016
            • 35
            Re: ESR Mania
            Well maybe some day. I hear the Japanese have invented radios without tubes.
            • jjne
              • Mar 2013
              • 47
              • uk
              Re: ESR Mania
              "Foreign" manufacturers?
              Name me one manufacturer of monitors (or pretty much anything) from the USA.
              Why are you using foreign Panasonic capacitors by the way? No attention to detail.
              Competent ESR meters can be bought for less than the price of a decent soldering iron.
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Re: ESR Mania
                ^^^ I second this, even though I don't have a proper ESR meter yet. I've gone looking around and found good/decent ones for a decent price.
                Heck, if you repair lots of stuff, even spending $100 on a good ESR meter is well worth it!
                I'm not a capacitor engineer, but I suspect that there might be issues related to internal temperature, ESR and inductance with large value polys. With a fat capacitor, the heat can build up in the middle, where it is sort of thermally insulated from the rest of the can by the outer windings.
                2.5milliohms ESR is not much resistance (but for high currents, it still matters!).
                A solid core 22AWG wire, about 5cm long, is close to 2.5milliohms.
                (I think ... lol)
                -Ben
                Muh-soggy-knee
                • Mint Waxed
                  • Aug 2016
                  • 35
                  Re: ESR Mania
                  I don't think anyone can name a capacitor manufactured in Europe or North America since the end of the tube era unless the Russians are making their own over in Moscow. You see, household wages have gotten so high with both men & women in the job market that low wage foreign competition from Asia has taken over. As for using Panasonic capacitors, the Japanese have a reputation for having quality control vs. poor or nonexistent in China. I've just noticed AliExpress has the Maste MS5308 for those seeking an inexpensive LCR/ESR meter.
                  • Mint Waxed
                    • Aug 2016
                    • 35
                    Re: ESR Mania
                    (I think ... lol)
                    -Ben
                    Your opinion well taken. Here at the shop which has been in operation for the past 45 years, we stock the parts cabinets with items known to come from quality sources. That way, you don't have to dig in the junk box and test some used, old, dehydrated, or ONS part that might be twenty years old. I'd rather put my money into fresh stock than mickey mouse with an ESR meter. For applications that genuinely require low ESR units, the Panasonic FR series as opposed to NHG can easily be obtained.
                    • jjne
                      • Mar 2013
                      • 47
                      • uk
                      Re: ESR Mania
                      But Panasonic are foreign (unless you're Japanese). So I don't understand your point about foreign manufacturers.
                        • 31278
                        Re: ESR Mania
                        no, panasonic make most caps in malaysia!!
                        • TechGeek
                          Computer Geek
                          • Jan 2015
                          • 2254
                          Re: ESR Mania
                          sigpic
                          • Behemot
                            • 4845
                            • CZ
                            Re: ESR Mania
                            You can get lots of those garage-made LCR testers, clones of that german open-source design. Good for basic use but hardly ideal.
                            If you want proper ESR meter with warranty and support, I can supply ya with ESR Micro v4.0si. Just getting another batch on monday or so. No problem shipping to US, or a colleague of mine can take them with him to Fermilab from time to time and ship using local mail.
                            • Mint Waxed
                              • Aug 2016
                              • 35
                              Re: ESR Mania
                              You are right. Foreign or domestic, the main issue would be quality control. With the huge disparity of wages and standards of living around the world, many manufacturers have turned to cheap labor markets hoping their brand name will make it all transparent.
                              • PeteS in CA
                                • Aug 2005
                                • 3583
                                • USA, Unsure of Planet
                                Re: ESR Mania
                                Many modern server PSUs use polymer caps. And since modern lytics are much lower ESR than the UCC RX & RZ and Nichicon PA & PB series low ESR caps in common use in the early 80s, compensation can accommodate lower and lower ESRs.
                                Desktop PSUs are VERY dense, and cost sensitive. I think those are the current barriers to using polymer caps in desktop PSUs.
                                PeteS in CA
                                • MORETTIGIAN
                                  by MORETTIGIAN
                                  Title:
                                  Description:
                                  Procedure performed:
                                  - Removed backplate
                                  - Reapplied thermal compound
                                  - Reassembled card
                                  09-18-2025, 12:14 PM
                                • Prolog
                                  by Prolog
                                  12-01-2024, 08:27 PM
                                • Sparklingx
                                  SMD ceramic capacitor capacitance & voltage
                                  by Sparklingx
                                  what is the easiest way to measure the capacitance of SMD ceramic capacitors and its rated voltage?...
                                  09-12-2024, 01:04 AM
                                • Agent24
                                  Dick Smith Q-1760 linear power supply filter capacitor question
                                  by Agent24
                                  I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                                  It has at least one problem.
                                  The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                                  I have already ordered a replacement potentiometer, so that's not an issue.
                                  Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                                  All are CapXon...
                                  10-21-2025, 05:39 PM
                                • chth96
                                  by chth96
                                  12-22-2023, 04:34 AM
