PSU bad capacitor 1000microF 16V
  • 250gto
    • May 2016
    • 6
    • Italy
    I am trying to resurrect some PSU:
    In one of these I found a bulging GL (?) 1000microfarad 16V capacitor, in another PSU I found an identical in these specs and dimensions CS capacitor in visually good shape, you can see in the attached photos.
    I don't have an ESR tester, can I try to solder the CS capacitor in place of the GL one?
    Thanks for the help
    Leonardo
    • 31298
    Re: PSU bad capacitor 1000microF 16V
    the GL is RK series.
    https://cdn.badcaps-static.com/pdfs/...baf605f4b2.pdf
    the CS should have a 2 letter code on it somewhere.
    find it and then get the correct datasheet
    http://www.paullinebarger.net/DS/CS%...uang%20Jin%5d/
    • 250gto
      • May 2016
      • 6
      • Italy
      I didn't find any code on the CS capacitor, but I bought an equivalent capacitor at a local store and I soldered to the PSU:
      it is functioning again.
      I spent a fraction of what I could spend to buy a new PSU and I also made a fraction of garbage that I could produce.
      I am very satisfied.
      • MORETTIGIAN
        Capacitor detached from PCB – RTX 2070 Super Founders Edition
        by MORETTIGIAN
        Title:
        Description:
        During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
        I did not notice it detaching, so I am unsure of its original location on the PCB.
        Procedure performed:
        - Removed backplate
        - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
        - Reapplied thermal compound
        - Reassembled card
        Observed behavior after reassembly:
        - GPU powers on and operates normally under...
        09-18-2025, 12:14 PM
      • Prolog
        RTX 3080 FE Identifying capacitor
        by Prolog
        Hi people, I hope this is the correct spot to post this, I'm new to the forum.
        I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
        I hope these photos make it clear which component I am referring to:
        (yes, the soldering is a bit botched from removing the blown one, I know)
        I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
        12-01-2024, 08:27 PM
      • Agent24
        Dick Smith Q-1760 linear power supply filter capacitor question
        by Agent24
        I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
        It has at least one problem.
        The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
        I have already ordered a replacement potentiometer, so that's not an issue.
        Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
        All are CapXon...
        10-21-2025, 05:39 PM
      • chth96
        If I replace with inferior capacitor, Is it No harm to other IC components at all?
        by chth96
        I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
        Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
        It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
        So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
        I know that these capacitor will not last as long as nichicon capacitor...
        12-22-2023, 04:34 AM
      • chth96
        How can I test non-polarized capacitor?
        by chth96
        I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
        I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
        And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
        I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
        06-02-2024, 07:31 PM
