Interpretation of capacitor ohms reading
    • 31289
    Re: Interpretation of capacitor ohms reading
    i just thought of something.
    maybe the original track you fixed got burned because of the short - see if that track connects to either of those cap pads.
    • cind12
      GTX 1080 TI Gigabyte Aorus low resistance on vmem
      by cind12
      Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
      Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
      The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
      Resistance on 12V 4K ohms (Power present when on)
      Resistance on 12V PEX 4K ohms...
      12-08-2023, 09:09 AM
    • novice1
      Acer Aspire E5-574G - Not Powering On
      by novice1
      Laptop name Acer Aspire E5-574G. Processor = i7-6500u. GPU = NVIDIA GEFORCE 940M. Motherboard Model = DA0ZRWMB6G0
      This laptop was not powering on at all so I started investigating. The blue light would come on for a second, and then disappear. Fan would sometimes turn on for a second and then shut off immediately, and at other times would not turn on at all.
      To start with, about 3 months ago I had no clue about soldering, motherboard schematics, board view, and then I stumbled about this forum and other stuff online. I have never done any of those before. But to ask...
      11-03-2023, 05:53 PM
    • lezsimply
      Low resistance reading on 3v line, Asus Prime H310M-A R2.0 desktop motherboard
      by lezsimply
      Hello Everyone and Good Day,
      I've got an issue with this desktop motherboard. It does not power on, Asus Prime H310M-A R2.0. I tested 33ohms reading on 3v line on the ATX connector. It beeps on continuity mode. I tried injecting voltage from 0.9v at 1.5amps and no current being drawn. I raised the voltage to 3v @ 4amps and now I only get 22mA on current. I checked with thermal camera and there is no part heating up. I'm afraid of going further the safe voltage. What could possibly causing the line to be shorted. 5vsb has no short. I get 0.9v on positive pin of power switch. There's...
      11-22-2024, 03:14 AM
    • ezenia
      ASUS PRIME B450 PLUS (rev 1.02) USB Overcurrent issue
      by ezenia
      So I bought a faulty ASUS PRIME B450 PLUS motherboard off eBay. They said it was water damaged and they cleaned it. The PC POSTs and displays a message that it's detected USB overcurrent and will shut off in 15 seconds. I verified this myself. So I did some checks at the ATX connector 1st to see if the resistance readings looked OK. I found the 3.3V rail measures just 179Ohms which seems way too low. It's been much higher on other AM4 boards I've worked on.
      So I did some Googling to see what the potential culprits are. It varies from bad protection diodes, bad...
      10-18-2025, 05:06 PM
    • applejuice95
      A2485 - No Backlight - 820-02100
      by applejuice95
      Have functional A2485 unit, all things work but backlight is out.
      There was some liquid corrosion around UP800's Caps and Res(s) - Cleaned all well . No change.
      I measured resistance to ground of all UP800s surrounding components on another working board.
      The components that are not correct on this board, with backlight out are:
      CP810 - should have 250K resistance at Pin 1, its reading 80 Ohms
      CP811 - Should have 25K at Pin 1, its reading 80 Ohms
      RP805 - Should be 30K on both Pin 1 & 2 - Pin 1 is 50Ohms and Pin 2 is 200ohms...
      02-24-2025, 11:49 AM
