old capacitor
  • onex
    • Dec 2013
    • 17
    • australia
    old capacitor
    trying to identify this old thing from the 50s to replace with a new one .i dont know how to read the values to match with a new one and the local shops have no idea. not much info on the web either .
    • 30930
    Re: old capacitor
    worn print, but: probably 82uF 350v axial electrolytic.
    or it could be 32uF - but 82 is unlikely to harm it.
    i would use an 82uF 400v radial electrolytic - they are very easy to find.
    they are used in psu's in everything from dvd players to set-top boxes.
    • onex
      • Dec 2013
      • 17
      • australia
      Re: old capacitor
      yeh the numbers are,
      top row MFD VW VP
      lower---32 300 350
      and TYPE ET5B
        • 30930
        Re: old capacitor
        then i would get a 47uF 400v radial electrolytic - preferably rated for 105' temperatures
        btw, radial = both wires at the same end.
        axial = one wire each end - pretty costly unusual these days.
        MFD = Micro-Farads (uF)
        VW = Working Voltage(maximum)
        VP = Pulse Voltage(maximum)
          • 30930
          Re: old capacitor
          you can get 33uF 400v too, but they are less common.
          • R_J
            • 9515
            Re: old capacitor
            Would this help? looks like a 32uf 300vdc
            • onex
              • Dec 2013
              • 17
              • australia
              Re: old capacitor
              legend
              thats perfect thanks
              • cloudff7
                Electrolytic capacitor leak in storage?
                by cloudff7
                there a risk of this aluminum electrolytic capacitor of electronic device long term storage opening and leaking acid and corroding the PCB board?
                07-22-2024, 06:27 AM
              • AleXis6
                Manufacturing Date of Electrolytic capacitor
                by AleXis6
                Guys. could you help me please to decode some codes of main capacitor's producers.
                I would like to know the manufacturing date.
                Based on the information from capacitors I have - it seems easy to decode manufacturing date for Rubycon, Nichicon.
                If I understood correctly:
                1. Nichicons marks date of production as (see the attached pictures) H2116
                I don't understand the meaning of first letter - may be it is code of factory.
                21 -year
                16 week
                I bought this capacitor recently.
                another one-
                2....
                10-11-2021, 02:20 PM
              • Prolog
                RTX 3080 FE Identifying capacitor
                by Prolog
                Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                I hope these photos make it clear which component I am referring to:
                (yes, the soldering is a bit botched from removing the blown one, I know)
                I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                12-01-2024, 08:27 PM
              • beogeek
                Need replacement advice for surface mount electrolytic capacitor
                by beogeek
                I have a faulty monitor, the surface mount electrolytic capacitor 33uF 100V needs to be replaced, now I can't seem to source them locally, so my question is can I replace it with a through-hole electrolytic capacitor of the same value? Or has someone got a better suggestion?
                Cheerio...
                03-17-2022, 01:43 PM
              • eccerr0r
                solid polymer electrolytic capacitor go boom?
                by eccerr0r
                Anyone had a solid polymer capacitor fail for whatever reason?
                How do they fail? Do they explode, go open, short out, ?
                How about for different reasons: forcing excessive ripple current, overheating, voltage too high, reverse voltage?
                Just wondering about the causes for a potential shorted solid polymer capacitor... trying to debug a board that has a ~4Ω "short" on a track... it may or may not be a capacitor but was wondering what if it were...
                07-25-2022, 07:12 AM
