malfunctioning GDRom Board a Cap has blown on it , how to test with a DDM ?
  • s8n
    • May 2008
    hi scene , i have a Dreamcast with a malfunctioning GDRom Board a Cap has blown on it. I want to test each one and replace the dead culprit. How do i test them with a DDM ?
    pic of GDRom Board
    any info helps
    s8n
  • s8n
    • May 2008
    Re: malfunctioning GDRom Board a Cap has blown on it , how to test with a DDM ?
    hi again , i found some info Googling and tried that. 3 of 10 Caps wouldnt charge and am going to replace them.
    thanx for all pending posts
    s8n
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • sfernandes
      Sega Dreamcast NTSC-U Revision 0 Launch Unit GD ROM PCB Board Short
      by sfernandes
      Symptom: When I press the power button the power LED lights up for a second and the fan etc spins for a second then the unit turns itself off and will not do the same thing again unless I unplug the power cable for a few minutes then plug it back in otherwise if I just turn the power switch off and back on right after it comes on for a second it will not come on again unless like I said unplug the power cord for a few minutes then plug it back in.
      What I have done to try to isolate the issue so far:
      The system powers on and stays on with...
      01-23-2023, 06:03 PM
    • odtech
      Asus UX490U laptop blown (caps?) on power board.
      by odtech
      Greetings friends.
      I was given this nice little laptop and would like to revive it if possible but i'm stuck identifying blown components. I'm very new to the repair game so i'm proceeding very cautiously.
      I don't know the history of this laptop and the donator didn't elaborate what happened but it seems some moisture got into the USB C charge port and the result was what looks like some blown caps. The tell is some gunk inside the USB C port and corrosion on the outside as well as what looks like corrosion around the blown components.
      Any guidance...
      08-06-2023, 10:29 AM
