Caps above 25 V?
  • Behemot
    • 4845
    • CZ
    Caps above 25 V?
    OK, at this moment I got most of the caps I need for my own use (ATX PSUs, displays, UPS, some mtherboards). So I'd like to stock some more, but after my previous experiences, I don't want to end with something I will be selling a piece per month.
    What are the most common other caps starting from say 25 V ppl use? Got some tips? Capacities, or mabye more like maximum dimensions and voltage would be good, than I'll see what I can get in those.
  • WeaselXP
    • Oct 2015
    • 107
    Re: Caps above 25 V?
    Having trouble finding 390uf 400v snap in caps with D25 and H42-H45, however, I don't need many.
    • Behemot
      • 4845
      • CZ
      There are KMR, KMW, KMZ (2000 hour) or LXS (5000 hour) available, maybe I can get a few as one-time sample…how many would you like? But in future only full box of the same kind. I have the feeling MOQ for these big ones is not that tragic, 200 pcs. In such case I'd still like ppl to pre-order at least 50 before I'd order such thing, it will still be many hundred dollars which would otherwise lay on shelf for only a few pcs I would sell immediatelly.
      Anything in the range of 35-63 V you use often?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Most common 25v ones for me I mainly use Low esr type for power supplies and inverters:
        1000uf 25v 10mm Di
        220uf 25v 8mm Di
        2200uf 25v 12.5mm Di
        100uf 25v 6.3mm Di
        470uf 25v 10mm and 8mm Di
        680uf 25v 10mm Di
        • Behemot
          • 4845
          • CZ
          Got most of those, the only ones I do not have are 470/25 and 2200/25. Got 680/35 D10.
          I replace most of the 25V with 16V caps in displays. and so on with 16 and 10V original caps, just rarely there is 24 V which is still good to replace with 35V caps. But things like 14 V rail, 1500/16 are just OK for that. You got much higher capacity and quality caps have no problem with that, just crapxons which rated 16 V can actually be anything between 14 and 16 V capacitors.
          I know there are high capacities like 2200/25 or 1000/35 often used in bigger displays and especially TVs, but I only rarely repair those. If some ppl here with reasonable demand for those use them, I can definitelly stock some…e. g. KYB 2200/25 D12.5x25 and 1500/35 same size, 10000 hours @105 °C.
          • WeaselXP
            • Oct 2015
            • 107
            Do you know the ripple current rating on those? I only one I found here was a Nichicon that was rated at 1.23 which seems low. The ones that were out of stock were 1.6 - 2.0. I like those better. I would only buy about 4. Also, some of them are expecting to restock in a month, so if it's too much trouble, don't worry with it.
            • Behemot
              • 4845
              • CZ
              KMR is 1.55 A, KMW 1.67 A, KMZ 1.64 A (those are actually 420V, not just 400V) and LXS 1.63 A.
              Generally there is combination of few parameters while at least one is always missing. So it will be very difficult to find a capacitor which is small, has long life time, high ripple current, 105°C rated and also has high capacity. Almost always one parameter is worse…
              • WeaselXP
                • Oct 2015
                • 107
                They all sound acceptable. If the LXS or KMZ are available, let me know.
                • mockingbird
                  • Dec 2008
                  • 5488
                  How about stocking some high-endurance small caps?
                  I'm always getting stuck with FC or PW 5mm caps when I'd prefer something like HE or KY. You know the usual values:
                  0.1uF
                  1uF
                  2.2uF
                  4.7uF
                  10uF
                  22uF
                  47uF (You already have this)
                  Maybe also some high-endurance miniaturized caps, all the above values in 4mm. Always use them for modular boards in FSP PSUs.
                  • Behemot
                    • 4845
                    • CZ
                    I don't think there are really any low-ESR 1uF caps from NCC but I got all the rest. Check again
                    WeaselXP: I'll ask for them and let you know. Maybe colleague of mine can take them to US next time.
                    • mockingbird
                      • Dec 2008
                      • 5488
                      No, not low ESR small value caps, but high-endurance small value caps.
                      What you got is general-purpose VZ series... 1000 hours only.
                      • Behemot
                        • 4845
                        • CZ
                        There is nothing besides maybe some old and obscure series with high endurance which is not also low-ESR. You just won't make GP cap handle 5000 hours.
                        KY with 4000 hours not good enough? I am slowly replacing them with KYA, they are cheaper, otherwise same for these small values.
                        KY 2,2 50 D5x11,5
                        KY 4,7 50 D5x11,5
                        KYA 10 50 D5x11
                        KY 22 50 D5x11
                        • mockingbird
                          • Dec 2008
                          • 5488
                          Yes, KY class are high endurance for 5mm (but KYA and KYB are also 4000 hour for 5mm).
                          But it's not the case that there are no high endurance GP caps. Panasonic EB is a good example (5000 hour for 5mm).
                          More high-endurance GP-class caps are Nichicon MV, SV, TS, TT and PV (PV is PW with an epoxy bunge AFAIK).
                          And your stock of KY is pretty low. Are there any inexpensive small caps with high endurance?
                          • japlytic
                            • Oct 2005
                            • 2086
                            Chemi-Con KZN Series (my preferred low-ESR series and recommended for new applications at the time of posting) have a life of 6000-10000 hours under worst possible conditions (maximum temperature, voltage, and ripple current applied) and come in voltages from 6.3V to 100V.
                            • Behemot
                              • 4845
                              • CZ
                              The EB series is interesting, it seems to me like older series for high voltage, just that they also made them for smaller voltages. Seems that few of them will be EoL'd by the end of march and more may follow soon…
                              • Behemot
                                • 4845
                                • CZ
                                I found some long-life automotive series from NCC, LE, that one has life of 10000 hours for D5 caps. It may have somewhat higher ESR, but judging from the ripple current, the difference compared to low-ESR will be small. So I would still not count them as GP…
                                • mockingbird
                                  • Dec 2008
                                  • 5488
                                  LE is very nice...
                                  Only stock of anything I could find is this:
                                  http://www.digikey.com/product-detai...766-ND/4726035
                                  But something like Rubycon YXM should cost a lot less and is also rated at 10,000 hours. YXF and YXJ are also pretty decent @ 5000 hours. Digikey is taking something like 10 cents a piece for 5mm YXM in quantities of 50.
                                  For high-endurance 0.1uF caps, I have a source for some NOS parts in large quantities.
                                  • Behemot
                                    • 4845
                                    • CZ
                                    Rubycon is, well…in future maybe. There are some brand new things I'd like from them, but…the distributor wants some damned papers, than money in advance etc. It'll take time to get through the process. Though it's true that at least some of those YXx are on the higher side of what's considered as low-ESR.
                                    • Behemot
                                      • 4845
                                      • CZ
                                      I got this ESR/impedance value curve (check attachment), these are measured values for LE 3.3/50. To compare with KY 3.3/50, the LE has about 15 % higher ESR and slightly lower RC.
                                      They said something about comparing typical and calculated worst-case value - which I do not understand, besides this curve I got no other values. (there is nothing in DS regarding ESR/impedance, what's why I asked for it) If they mean like generaly the actual value is much better than the catalogue'd, in that case the real ESR difference is even larger compared to KY. But it's still not "general purpose".
                                      Anybody interested? I've been told that generaly, the price is about 50 % higher than for KY. That means my estimated price for LE would be that of KY from those big-ass sellers. With twice the lifetime.
                                      • mockingbird
                                        • Dec 2008
                                        • 5488
                                        Not worth it if you ask me...
                                        Here's my logic:
                                        Higher ESR means higher temperature. So take that 10,000 hour rating and compare it to KY (4,000 hour IIRC), but then compensate for the lower temperature. Definitely not worth 50% more considering YXM is equivalent in price to KY but also has a 10,000 hour rating.
                                        So my guess is that LE has an expensive but unecessary for our purposes stabilizer in the electrolyte... Since it's an automotive series, the stabilizer is probably formulated to hold up better in the long run throughout repeated extreme environmental shifts due to the climate.
                                          by momaka
                                          03-12-2025, 03:42 PM
                                        • eryjus
                                          by eryjus
                                          05-10-2023, 11:21 AM
                                        • Paxman_Swede
                                          by Paxman_Swede
                                          Hello!
                                          01-14-2025, 09:51 AM
                                        • Foetuss
                                          Gigabyte GA-6OXT :: caps question
                                          by Foetuss
                                          Good evening
                                          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                          But I was also suprised about the bigger boys, which are 330µF 25V.
                                          Could it be they used 25V caps because they were cheaper / available at that time?...
                                          02-11-2025, 12:22 PM
                                        • madscientist750
                                          Replacing electrolytic caps by solid caps on old motherboards
                                          by madscientist750
                                          I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                                          I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                                          I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                                          10-19-2025, 06:10 AM
