Caps above 25 V?
  • Behemot
    • 4845
    • CZ
    Re: Caps above 25 V?
    May be related to the temperature, there's quite hot in the engine compartment or dashboard…
    And I think the ESR difference is not that signifficant to be more than like 500 hours with regard to the temperature.
    I'll ask for the pricing in future, if it is still not that bad, I'll take them over the KY. I think I won't get YXM for better price, not in reasonable numbers. And it occurs to me they are corss-reference as the specs are the same!
    EDIT// just did the math. For example if the LE 4.7/50 will be 50 % more expensive than KY, it would cost 2 CZK a piece from me (8 US cent). Both the KY and YXM cost 6.25 CZK from Digi Key. Is it so bad?
    • mockingbird
      • Dec 2008
      • 5488
      No that's very good, if you can get them in small batches though...
      You'll have to work your charm with the supplier
      • Behemot
        • 4845
        • CZ
        Batches of 5x11 are 3000 pcs, that's reasonable.
        As the specs are rather similar, I'll take them instead of the KY next time…don't think it would matter for any circuit if the ESR will be 1.8, 2 or 2.2 ohm…
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          i replace lots of 35v caps in tv power supplies.1000@35 being very common.
          • Behemot
            • 4845
            • CZ
            What's the can size, D12.5x20 or 25?
            • Behemot
              • 4845
              • CZ
              #26
              Originally posted by WeaselXP
              They all sound acceptable. If the LXS or KMZ are available, let me know.
              I am getting the LXS 390/400 D25.4x45 mm about tomorrow or so, 4 pcs. How many of them would you like?
              • Behemot
                • 4845
                • CZ
                #27
                I also received 4 KMZ 390/420 D25.4x40 mm. These just have shorter life, 2000 hours only @105 °C. Weasel will take some four, the remaining ones will be available if anybody needs.
                If there would be demand I can stock 200 pcs. I can use some from time to time to upgrade units I review and have small primary capacity (especially when they have short hold-up time). But not so many and it goes expensive to let them rotting on the stock.
                  by momaka
                  03-12-2025, 03:42 PM
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • Foetuss
                  Gigabyte GA-6OXT :: caps question
                  by Foetuss
                  Good evening
                  I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                  Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                  But I was also suprised about the bigger boys, which are 330µF 25V.
                  Could it be they used 25V caps because they were cheaper / available at that time?...
                  02-11-2025, 12:22 PM
                • madscientist750
                  Replacing electrolytic caps by solid caps on old motherboards
                  by madscientist750
                  I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                  I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                  I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                  10-19-2025, 06:10 AM
