Help needed
  • UNCLE BUTCH
    • Dec 2015
    • 7
    • UNITED STATES
    Help needed
    Hello to everybody. I am from Illinois. I am an oldtimer with a small amount of computer knowledge. I have a HP Pavilion that went from bad to worse, hanging up to not posting. When searching the internet for information I came across your site. I am going to try to repair it myself.
    The motherboard is an Asus M2N78-LA '' PEGATRON ". It has 12 capacitors that are bulging, all of them are TK 6.3v 820uf. The rest look ok. My first question is: do i replace all or just the bad ones. The capacitors range from 100uf to 1800uf. The second question is, when ordering new ones, what information do i need besides the voltage, UF and temperature? I am sure i will have more questions later.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Help needed
    Replace all the Tk ones buddy, what caps you planning on using ?
    • UNCLE BUTCH
      • Dec 2015
      • 7
      • UNITED STATES
      Re: Help needed
      I would like to get the rubycon from Top Cat.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        Re: Help needed
        replace all the caps 680uF and up. Post a list, and I can point you in the right direction with what to order.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
          • 31214
          Re: Help needed
          before you do that, check in the psu
          bad motherboard caps can be caused by poor power from a psu with bad caps.
          • UNCLE BUTCH
            • Dec 2015
            • 7
            • UNITED STATES
            Re: Help needed
            Thank you, It might take a day or two but I will post a list and will check power supply.
            • UNCLE BUTCH
              • Dec 2015
              • 7
              • UNITED STATES
              Re: Help needed
              Here is a list of capacitors on my Asus M2N78-LA motherboard.
              8 very small 25v no uf markings 105 C
              8 KMA 16v 100uf 105 C
              3 Sanyo 16v 100uf 105 C
              3 "Polymer" 16v 270uf
              1 KZE 6.3 330uf 105 C
              1 KZG 16v 470uf 105 C
              1 "Polymer" 2.5v 820uf
              12 TK 6.3v 820uf 105 C
              10 Panasonic? 6.3v 1500uf
              3 Panasonic? 6.3v 1800uf 105 C
              The only ones that I could see with varying degrees of bulging were 11 of the 12 TK 6.3v 820uf, from slight bulge to one with crud on top.
              I removed all 12 TK 820. The desoldering went well. I also removed 2 Sanyo 16v 100uf and 1 KZG 16v 470uf because I thought they looked suspicious [tilting and maybe bulging]
              I have a Pay pal account or my credit card. I would like replace what ever you think is best with quality capacitors. Also, STI mentioned checking the PSU. I looked on you tube but did not find anything that could be a good way to test. I do not have any tools other than basic multi meter and am open for suggestions on checking the PSU
              Thank you
                • 31214
                Re: Help needed
                just open the psu and look at the top of the caps for bulging / leaking
                • UNCLE BUTCH
                  • Dec 2015
                  • 7
                  • UNITED STATES
                  Re: Help needed
                  I did that. When I opened the case [the psu had not been turned on for at least two or three weeks] I did not see any thing abnormal. I did smell a very very faint smell of burnt electrical. I do not think any thing was burnt however. The psu was and upgrade from the original. It is 450 Thermaltake asnd about 5 years old.
                    • 31214
                    Re: Help needed
                    leaking caps smell like cat-piss, you wouldnt miss it!
                    • UNCLE BUTCH
                      • Dec 2015
                      • 7
                      • UNITED STATES
                      Re: Help needed
                      Did not smell any cat piss.
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16958
                        Re: Help needed
                        Thank you
                        These are the only ones that really need to be replaced:
                        https://www.badcaps.net/store/produc...roducts_id=148
                        https://www.badcaps.net/store/produc...products_id=49
                        The panasonics shouldn't give you any trouble, but feel free to replace them anyway. the 100uF sanyo won't be bad.
                        Team : 49813
                        Join in!!
                        Team Stats
