2 Seconds to black monitor problem, Replacement cap help
  • MisterHandy
    • Dec 2015
    • 3
    Hi all, My dell monitor SP2208WFP was having intermittent issues where after being turned on, it would show the image then turn into a black screen 2 seconds later with the power light being the same. I could unplug all cords but power and it would do the same. Switching imputs would reset the 2 second timer, but then it would go back again always after 2 seconds.
    I google'd and it brought me to this very helpful website. I learned about a lot of useful things already. I opened up my monitor and found that (3) Capxon 330 p746 kf 105c capacitors were bulging on top on the board with the main power. This is my first time ever opening one up. They appear to be 9.6m by 17.8mm, so i assume they are 10mm/16mm. Upon looking at a chart found here, I found these Panasonic FM 330uF 35v 105c 10/16mm's. I noticed capxon was on the bad caps list, and panasonic is on the good caps list. I found 4 of them for $5.
    I just wanted to ask and see if these would work, and also is that probably the problem? I've never done any of this stuff before but i'm a huge DIY guy and willing to learn just about anything. Have pictures if necessary. Thanks
  • cruzinforit
    Rin is my waifu
    • Apr 2015
    • 22
    Re: 2 Seconds to black monitor problem, Replacement cap help
    Is that probably the problem: I will almost garuntee you that it is.
    Will they work: You don't list the voltage of the capxons, but assuming it is equal to or less than 35V, yes.
    Go for it.
    • MisterHandy
      • Dec 2015
      • 3
      Yes they are 35V. Thanks for the imput, just don't want to be out of money lol.
      • sew333
        Pc shutdown, monitor flickered with no signal after 10 seconds
        by sew333
        My pc:
        10850K stock 4800mhz stock Kraken X73 good temps
        2x16 GB DDR4 GSKILL 3000mhz XMP
        Seasonic Tx-850 Ultra Titanium
        Gigabyte Rtx 3090 Gaming OC
        Aorus Z490 Pro Gaming
        1 TB SSD
        4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
        Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
        Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
        Power...
        02-22-2022, 10:27 AM
      • ttmi100x
        HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
        by ttmi100x
        Greetings everyone,
        I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
        The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
        Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
        Upon closer inspection...
        07-31-2024, 06:36 PM
      • wattage
        AOC AG493UCX 49-inch monitor - Firmware request
        by wattage
        Hello Badcaps Community,
        The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
        07-13-2025, 04:41 PM
      • keepread
        Dell monitor PSU vs Dell laptop PSU
        by keepread
        Hi there!
        Someone gave me their old monitor, it's Dell S2715ht.
        The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
        Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
        10-30-2025, 04:45 PM
