About replacing caps on a monitor where some caps look ok
  • Yamashiro
    • Sep 2015
    • 19
    • Israel
    Just opened up a monitor, and I see 2 out of a 4 array caps are bad, should I replace all 4 or just the 2 bloated ones?
    What about other caps on the board that look ok?
    PS the monitor was turning on for a second and then off.
    • 31289
    Re: About replacing caps on a monitor where some caps look ok
    if the 4 are the same value then replace all of them - is that a 5th one near it?
    • Yamashiro
      • Sep 2015
      • 19
      • Israel
      The two upper ones (the bulging ones) are 1000uF 16V and the lower two are 470uF 35V, the one to the upper left of them is also 1000uF.
        • 31289
        replace the 1000uf ones.
        the reason for doing all of them is incase there is a poor batch or something - saves opening it again in a month just to do another one!
        you probably have to buy them in 5's anyway.
        • Yamashiro
          • Sep 2015
          • 19
          • Israel
          Alright, thank you stj.
          • Behemot
            • 4845
            • CZ
            I can see six of them plus two vacant spots.
            If you need I got NCC KYA or KYB (1000 hours) 1000/25, 1500/16 are not available ATM.
            • madscientist750
              Replacing electrolytic caps by solid caps on old motherboards
              by madscientist750
              I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
              I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
              I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
              10-19-2025, 06:10 AM
            • black6host
              Replacement caps for Samson Resolv studio monitor 65A Amp board.
              by black6host
              Good day!
              I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
              I'm going to replace the caps and I'll be the first...
              02-06-2024, 08:22 PM
              by momaka
              03-15-2023, 10:17 PM
              by momaka
              03-12-2025, 03:42 PM
            • keepread
              Dell monitor PSU vs Dell laptop PSU
              by keepread
              Hi there!
              Someone gave me their old monitor, it's Dell S2715ht.
              The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
              Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
              10-30-2025, 04:45 PM
