Sony 2800W PSU out of a Cisco Catalyst POE Switch
  • cruzinforit
    Rin is my waifu
    • Apr 2015
    • 22
    I made the thread over at JG,don't feel like reposting all the pics here. Feel free to discuss
    http://www.jonnyguru.com/forums/showthread.php?t=12803
    • 31289
    Re: Sony 2800W PSU out of a Cisco Catalyst POE Switch
    those caps are Hitachi
      Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
      This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
      09-06-2024, 05:30 AM
    • madan1
      cisco poe switch PSU issue
      by madan1
      Hello everyone.
      I'm troubleshooting a cisco switch, which seems to have an issue with the PSU.
      The psu has the following power rails - +12v, -53.5V and +3.3V
      When connected to power, the +12 and -53.5 seem to work fine, but the +3.3 starts at ~3v and then goes down to ~0 (I guess this is the cap discharging). This happens both when the cable is connected and not to the switch board.
      Any ideas what might be causing this behavior?
      04-23-2024, 01:58 PM
    • fuxxy
      Cisco C2960CX managed switch - Won't provide POE
      by fuxxy
      Hey guys, I have 4 of these switches.
      One switch works as intended - Boots, Accepts configuration, Provides POE. However, after about 3 days the switch stops responding. Won't recognize console USB cable inserted, TX/RX lights stay lit when cables unplugged. Works again after power cycle.
      The other three will boot, accept configuration, and will uplink to the network. However they won't provide power to connected POE devices. I've ruled out configuration issue, as I have cloned the configuration from the 'working' switch to all 3 of these non-working switches....
      03-07-2022, 10:26 PM
    • madan1
      Cisco catalyst 2960c POE
      by madan1
      Hello everyone.
      Got a catalyst 2960 from the usual scrapyard - ebay.
      It is stuck in bootloop and the power supply is missing the 3.3v rail. (+12V, -53V, +3.3V)
      Some green moisture crystallization on mainboard, which cleared very well with IPA and visually there is nothing rusted or gone.
      Still working on the PSU to get the 3.3v rail back (waiting for parts), but for now I'm using an external buck converter board hooked up to the 12V rail ( by the way, the switch seems to be working with only 12V ).
      The switch fails to boot due to the following POST error:...
      12-19-2024, 09:34 AM
    • grimacelord
      NEC TurboExpress On/Off Power Switch Replacement Help
      by grimacelord
      I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
      I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
      I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
      11-09-2023, 09:49 AM
