Blown Capacitor in Hammerhead XRT Device
  • Chaks
    • Sep 2015
    • 115
    • India
    I have a walkabout Hammerhead XRT Win XP Tablet PC with a blown capacitor on the motherboard. Can anyone help me to identify the value of this capacitor and also It will be very helpful if you can tell me if any other component it would have taken along with it.
    This happened when an induction motor was switched-on (connected to the same mains electrical/power line where the Hammerhead device was connected). Is there a possibility that it would have taken down other surrounding resistors/IC's along with it?
    Blown capacitor:
    https://drive.google.com/file/d/0Bxc...ew?usp=sharing
    Can somebody help me with the connector pin out of this connector on the back of Hammerhead XRT device. I want to connect it to LAN and but I don't have a dock with me. So the only way is to make a custom adapter for this connector to connect to network.
    Connector Details
    • 31028
    Re: Blown Capacitor in Hammerhead XRT Device
    dont use google.
    you need to remove the cap, clean the board,
    then see where that cap connected.
    if it goes into that chip, get a datasheet.
    because it may have an example circuit that shows the cap value.
    as for the dock, i dont see any magnetics, so you need more than a connector.
    • Chaks
      • Sep 2015
      • 115
      • India
      Does anyone have a picture of Hammerhead XRT Motherboard PCB?. That would help me to identify the capacitor that is blown in my device.
        • 31028
        so, this is the chip next to the cap.
        so if he cap is connected to pin1 and ground then it's c3 (100uf 35v)
        and if it's not connected to pin1 then you still need foto's
        • Chaks
          • Sep 2015
          • 115
          • India
          Thanks stj I will try to locate the PCb traces leading up to the blown cap
          • RJARRRPCGP
            • Jul 2004
            • 6304
            You may have a bad neutral line!
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • Chaks
              • Sep 2015
              • 115
              • India
              Thanks stj, it was the 100uf 35 volt cap that was replaced and the device is working perfectly (7 months months since it was fixed) and no issues what so ever.
              Sorry stj I should posted this in December 2015 itself when the device was fixed.
              Many thanks for your solution.
              • MeetingIncapable
                Blown capacitor repair on MSI Radeon RX 5700 XT MECH OC
                by MeetingIncapable
                I am new to repairing computer electronics, so excuse any mistakes I make.
                A friend of mine had a broken graphics card (MSI Radeon RX 5700 XT MECH OC) and gave it to me. It does not power on or show any signs of life.
                I identified what looks like the remains of a blown capacitor at the bottom of the board (see picture).
                I wanted to replace the capacitor, but I have two questions:
                • Does this repair have a chance of working? or is a blown capacitor a sign something else is wrong?
                • How do I determine the rating/value of this capacitor? or something
                05-04-2024, 09:56 AM
              • NuclearSpartan
                Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
                by NuclearSpartan
                I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
                The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
                I don't see any other visible damage anywhere else on the board....
                11-14-2024, 02:32 PM
              • Per Hansson
                Repair of Sign WiFi Smart Plug PCB: SA-P302A v1.2 due to bad caps - with schematic
                by Per Hansson
                I have repaired a Sign WiFi Smart Plug with model number: SNSM-WASINGLE sold by Spares Nordic AB in Sweden.
                The fault condition was that the device gave no signs of life: pressing the push button did not cycle the internal relay and the blue LED did not come on and it was not seen on the WiFi network.
                The fault was very simple, capacitor C3 on the PCB with writing "KSJ" and "LOWESR" had literally blown its top off, after replacing it the device works fine again!
                As I find linear high voltage regulator designs interesting I drew up the attached schematic...
                12-23-2023, 06:20 AM
              • Tomylee
                No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
                by Tomylee
                Sorry for the person who’s going to read all this !
                I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
                While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
                During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
                07-11-2025, 11:52 AM
              • valvashon
                Bob and Brad QL/MINI massage gun not charging
                by valvashon
                My (legitimate) massage therapist gave this to me to try to fix last time I saw here. Complaint was that it simply wouldn't turn on anymore. B&B have a rediculous return policy where you have to make a 3 minute video showing what the problem is, etc. Rather than mess with that Dana let me take it to try to fix it.
                Verified that it wouldn't turn on. Don't remember trying to charge it before I took it apart. Found that the motor turned freely. Pulled the battery connector apart to check the voltage and the battery voltage was good- fully charged in fact at 11.3 volts. Plugged battery...
                07-30-2024, 02:34 PM
