YEC capacitor question
  • nkeck72
    Enthusiast
    • Oct 2015
    • 21
    I have recently gotten my hands on a rated 6 Farad, 2.7 volt YEC capacitor. With its small size and rather low voltage rating, I question whether this is a legit 6F cap or yet another fake. The only problem is that I don't have any testing equipment, only a D battery and some wire. (My cheapo DMM finally broke and I have nothing to test capacitance, ESR, etc.) My question is, is there any way to test the legitimacy of the cap?
    I just have that inkling of a feeling that tells me that the cap may indeed be fake. I have attached pics of the cap and datasheet.
    Capacitor: http://imgur.com/wytnfHo
    Datasheet: http://imgur.com/6OXk35R
    Notice that it isn't bulged, and although the legs are bent a little, that was me, when I got the thing it was new. I have only put it through a single charge/discharge cycle to see if it would blow like all those fakes I have seen before.
    I have taken notice that people have put the YEC brand caps on their "avoid" list. Why exactly? Are YEC caps like the one I have typically fake and/or have a short life?
    Cheers!
    "It won't take long if you take it one byte at a time." - me
    "WHOSE IDEA WAS THIS?" - too many people to count
    "Go back to the depths of SourceForge from whence ye came."
    All my software crap: https://www.github.com/nkeck720
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: YEC capacitor question
    Yec caps are pure trash best way to test is with an Esr meter or an Lcr capacitance meter.
    • mariushm
      • May 2011
      • 3799
      That's a SUPERcapacitor, it has 6 farads at 2.7v , not uF.
      Supercapacitors have different chemicals inside, so there's no way of knowing if these supercapacitors will behave like their regular capacitors. Could be different factories, different materials, different anything.
      As for measuring, you could do it with an oscilloscope, see this guide: https://www.youtube.com/watch?v=VylC8JFoiBo
      Though for supercapacitors, you don't care about low esr and whatever, you use them for the huge amount of energy they hold (like, use them as replacement for a backup battery or something).
      Careful about heating the leads for too long, these supercapacitors are only rated for up to about 65c. Shouldn't heat the insides too much by accidentaly keeping the solder iron on the leads.
      • nkeck72
        Enthusiast
        • Oct 2015
        • 21
        Is there a way to tell if this is a fake other than with the measuring equipment?
        Also, I noticed the part number on the cap is PL6051020 but the datasheet says the format should be WPL2R76051020. Could this mean something significant or is it probably an outdated datasheet?
        Cheers!
        • MORETTIGIAN
          Capacitor detached from PCB – RTX 2070 Super Founders Edition
          by MORETTIGIAN
          Title:
          Description:
          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
          I did not notice it detaching, so I am unsure of its original location on the PCB.
          Procedure performed:
          - Removed backplate
          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
          - Reapplied thermal compound
          - Reassembled card
          Observed behavior after reassembly:
          - GPU powers on and operates normally under...
          09-18-2025, 12:14 PM
        • Prolog
          RTX 3080 FE Identifying capacitor
          by Prolog
          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
          I hope these photos make it clear which component I am referring to:
          (yes, the soldering is a bit botched from removing the blown one, I know)
          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
          12-01-2024, 08:27 PM
        • Agent24
          Dick Smith Q-1760 linear power supply filter capacitor question
          by Agent24
          I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
          It has at least one problem.
          The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
          I have already ordered a replacement potentiometer, so that's not an issue.
          Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
          All are CapXon...
          10-21-2025, 05:39 PM
        • chth96
          If I replace with inferior capacitor, Is it No harm to other IC components at all?
          by chth96
          I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
          Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
          It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
          So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
          I know that these capacitor will not last as long as nichicon capacitor...
          12-22-2023, 04:34 AM
        • chth96
          How can I test non-polarized capacitor?
          by chth96
          I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
          I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
          And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
          I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
          06-02-2024, 07:31 PM
