YEC capacitor question
  • nkeck72
    Enthusiast
    • Oct 2015
    • 21
    I have recently gotten my hands on a rated 6 Farad, 2.7 volt YEC capacitor. With its small size and rather low voltage rating, I question whether this is a legit 6F cap or yet another fake. The only problem is that I don't have any testing equipment, only a D battery and some wire. (My cheapo DMM finally broke and I have nothing to test capacitance, ESR, etc.) My question is, is there any way to test the legitimacy of the cap?
    I just have that inkling of a feeling that tells me that the cap may indeed be fake. I have attached pics of the cap and datasheet.
    Capacitor: http://imgur.com/wytnfHo
    Datasheet: http://imgur.com/6OXk35R
    Notice that it isn't bulged, and although the legs are bent a little, that was me, when I got the thing it was new. I have only put it through a single charge/discharge cycle to see if it would blow like all those fakes I have seen before.
    I have taken notice that people have put the YEC brand caps on their "avoid" list. Why exactly? Are YEC caps like the one I have typically fake and/or have a short life?
    Cheers!
    "It won't take long if you take it one byte at a time." - me
    "WHOSE IDEA WAS THIS?" - too many people to count
    "Go back to the depths of SourceForge from whence ye came."
    All my software crap: https://www.github.com/nkeck720
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: YEC capacitor question
    Yec caps are pure trash best way to test is with an Esr meter or an Lcr capacitance meter.
    • mariushm
      • May 2011
      • 3799
      That's a SUPERcapacitor, it has 6 farads at 2.7v , not uF.
      Supercapacitors have different chemicals inside, so there's no way of knowing if these supercapacitors will behave like their regular capacitors. Could be different factories, different materials, different anything.
      As for measuring, you could do it with an oscilloscope, see this guide: https://www.youtube.com/watch?v=VylC8JFoiBo
      Though for supercapacitors, you don't care about low esr and whatever, you use them for the huge amount of energy they hold (like, use them as replacement for a backup battery or something).
      Careful about heating the leads for too long, these supercapacitors are only rated for up to about 65c. Shouldn't heat the insides too much by accidentaly keeping the solder iron on the leads.
      • nkeck72
        Enthusiast
        • Oct 2015
        • 21
        Is there a way to tell if this is a fake other than with the measuring equipment?
        Also, I noticed the part number on the cap is PL6051020 but the datasheet says the format should be WPL2R76051020. Could this mean something significant or is it probably an outdated datasheet?
        Cheers!
        • MORETTIGIAN
          by MORETTIGIAN
          Title:
          Description:
          Procedure performed:
          - Removed backplate
          - Reapplied thermal compound
          - Reassembled card
          09-18-2025, 12:14 PM
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • chth96
          by chth96
          12-22-2023, 04:34 AM
        • chth96
          by chth96
          06-02-2024, 07:31 PM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
