Bent capacitor?
  • mikay786
    • Aug 2014
    • 765
    Bent capacitor?
    I accidently bent a couple of capacitors to the point where the fat point of the pin pulled out a little from the main body.
    Straighten it up and the fat bit has gone back into the body of the cap.
    Have I killed them or will they still work?
  • Sparkey55
    • Jan 2010
    • 1523
    Re: Bent capacitor?
    It's dead Jim. You possibly broke the peircing tabs on the lug away from the aluminum foil. It is more than likely an open cap now. No way to fix it.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Re: Bent capacitor?
      Might get lucky if ESR on that cap isn't important but it will eventually completely fail if it hasn't already.
      • Prolog
        RTX 3080 FE Identifying capacitor
        by Prolog
        Hi people, I hope this is the correct spot to post this, I'm new to the forum.
        I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
        I hope these photos make it clear which component I am referring to:
        (yes, the soldering is a bit botched from removing the blown one, I know)
        I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
        12-01-2024, 08:27 PM
      • chth96
        If I replace with inferior capacitor, Is it No harm to other IC components at all?
        by chth96
        I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
        Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
        It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
        So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
        I know that these capacitor will not last as long as nichicon capacitor...
        12-22-2023, 04:34 AM
        HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
        This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
        09-12-2024, 02:00 PM
      • chth96
        How can I test non-polarized capacitor?
        by chth96
        I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
        I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
        And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
        I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
        06-02-2024, 07:31 PM
      • chth96
        Is it no harm to replace with capacitor without ripple current rating?
        by chth96
        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
        Rubycon YK DataSheet (b...
        04-19-2024, 05:19 AM
