Audigy 2 ZS audio quality problem
  • machlo
    • Feb 2008
    • 5
    Hi. I've got Audigy 2 ZS and there is one annoying problem. Front output sounds strange, because left channel is louder than right. Additionally when I mute rear and center/sub outputs I still can hear the music in these outputs, while front isn't muted and vice versa, front is muted and center/sub, rear isn't - still can hear music in front output. I have looked at the card, but I can't see anything suspicious with caps. I tried to measure them(unfortunately my multmeter measure only to 20 uF) and I found that one capacitor(10uF) has over 20uF(measurement is over the range, so "1" is shown on screen). There is some more capacitors that i can't tell if they are good, because they are >20uF. I wonder if the problem is caused by the only one capacitor. I attach image with pointed suspicious cap. The card in the photo looks identically like mine. Audigy 2 ZS Thanks in advance for helping me
  • zandrax
    Hit and miss
    • Dec 2007
    • 1157
    • Italy
    Re: Audigy 2 ZS audio quality problem
    Still nobody replies you, so I'll try to.
    First: are you sure volume issue and channel interference are due to caps? As a first move I'd try to update sound drivers and change the pci slot, just to exclude any driver, pci timings or irq conflict which Creative cards are prone to manifest.
    Second point: detach any cdrom cable from the Audigy, try avoiding any radio interference near your computer (remove phones, radios, tv sets and so on) and try plugging an headphone instead of your pc speakers. Power supply's noise can [unfortunately] make sound board noisier: if you have a spare psu, try swapping it.
    If problems persist, then you can rule out the card is defective: did you buy an brand new Audigy or an used one? In the first case you should ask your seller a replacement, in the latter lets continue.
    Capacitance means how much charge the caps can accumulate before suppling it to the device: if you think caps are bad you shouldn't look for mismatched capacitances but for high Esr readings. Esr means the resistance the capacitor opposes to current flow: a good capacitor should have an esr value around tenths of Ohm, while Low esr caps have values of hundredths of Ohm. There is no way to detect caps' Esr with a multimeter, you can do it with an Esr meter (see the Test equipment thread for some hints).
    I can't help more: good luck and keep us updated.
    Zandrax
    Have an happy life.
    • machlo
      • Feb 2008
      • 5
      It's definitely not a matter of a software, because I tested the card in the linux and windows with original creative's drivers and kx drivers. PSU should be all right, because it's Chietec and it's quite new. It's about one year old. Every sound quality test I performed on headphones(Philips SHP8900). I will check tomorow if changing a pci slot makes any difference. In my opinion it's something wrong only with the card, but I can't tell what. It would be a real problem to check cap's esr - I don't know where to find Esr meter :|
      • machlo
        • Feb 2008
        • 5
        I changed pci slot and it makes no difference. I make photos of suspected bad cap - photo 1 photo 2
        • zandrax
          Hit and miss
          • Dec 2007
          • 1157
          • Italy
          You may be right machlo: those caps are Jamicons and are considered bad caps (see X-Fi Fatal1ty full of Jamicons thread). Trodas replaced some caps and was pleasant to discover he got rid of all noises and crashes he had experienced while playing games.
          Fizzycapola recapped an Audigy 2 ZS, so you can ask some hints to him.
          Keep us updated
          Zandrax
          Have an happy life.
          • Fizzycapola
            • Oct 2006
            • 423
            Actually it was Audigy 2 ( I'm not sure of the difference, it has Non-Polar capacitors at the connections end)
            I can't think how this cap would cause left audio to be louder than right. This is usually Volumeter Wave balance solvable or to do with faulty jack or cable kinks.
            The general 1 easy solution technique on these cards is replace the plus 100uF with good caps, maybe Rubycon ZL, Panasonic FM, most popularly Panasonic FC, but perhaps Sanyo Oscon SP (SP is audio grade Oscon) would be ideal, cheaply for lower capacitors Panasonic ECA (for audio) could be used for experimenting as they're 1/10th price the others.
            If you can't be bothered with expensive test equipment, one could randomly bypass capacitors with temporary soldering caps to the reverse to see if anything has an effect. This is how I have deducted things, eventually bypassing a certain capacitor solved my issue and then it was clear to replace that capacitor.
            Trodas and logistics should know alot more than me, they use bypass capacitors and things like that quite complicated. Although I wish they'd take more photo's and make easier guides with total novices like myself in mind.
            A benefit of these cards is they're plentiful, replacements can be bought for under $20 with good bidding. Virtually same sound quality as mid range Xi-Fi and low CPU resources when playing sound. Because of their low replacement cost but high performance, they're definately worth experimenting on.
            Replacing that single Jamicon should be easy enough I see no reason not to try it anyway.
            I wouldn't panic too much of Jamicon, I doubt they're as imminent issue as say GSC, Hermei or Fuhhyiu they're used by many top companies, Sony chose to install them in the audio part of my Television next to Rubycon and Nichicon.
            Rubycon Rubycon Rubycon
            • machlo
              • Feb 2008
              • 5
              I talked with academic(I study electronics at Warsaw University of Technology) and he said he will help me solving this problem. We'll check this card at the university on Tuesday.
              • machlo
                • Feb 2008
                • 5
                I checked cap's ESR using oscilloscope and simple pulse generator. The method is described here. It's written in polish, but pictures and schemes should explain everything. All caps have ESR=2,5 ohms(approximately) at freq. of 1kHz. I really don't know if this value is too hight. If not what's wrong with the card? :|
                • theone111
                  by theone111
                  3. Problem: TV shuts down
                  07-22-2024, 10:36 AM
                • Zeonalbasta
                  Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                  by Zeonalbasta
                  i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                  The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                  09-13-2024, 01:17 PM
                • Gibon378
                  Problem with stopping audio and video for no reason
                  by Gibon378
                  PC Specs:
                  • CPU: Ryzen 5 1600
                  • GPU: GTX 1080 Palit JetStream
                  • MOBO: ASRock ab350 PRO4
                  • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                  • PSU: XFX 650W (don't remember what model)
                  • OS SSD: ADATA SP920
                  • OS: Windows 10 21H2
                  Problem description:
                  Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                  11-19-2022, 09:41 AM
                • perzyk23
                  Lenovo T580 - LCD Panel problem - error 0288
                  by perzyk23
                  Good morning,
                  I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                  10-25-2024, 12:42 AM
                • SDNarcia
                  Dell 15R-5521 keyboard problem (KBC?)
                  by SDNarcia
                  Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                  As additional information,...
                  07-20-2024, 10:47 PM
