E. Capacitor withstanding high altitude or vacuum environment.
  • agtrbt
    • Sep 2015
    • Taiwan
    I am building a device with some 25V 3300uf that will be used high up the atmosphere (15km+).
    Will the seal of the capacitor and electrolyte tend to break off and get sucked out under low atmospheric pressure? Assume a 25 degrees temperature due to device heat and cold surrounding.
    (also the batteries which may be off topic for this forum)
    • 31289
    Re: E. Capacitor withstanding high altitude or vacuum environment.
    cold surrounding at night, in the day once your above the clouds the sun is going to bake it.
    it would probably be better to use poly's and cover them in a thermal insulating material to slow any heating or cooling effect.
    think carefully about the type of battery you use too for the same reason.
    you can test it on the ground anyway.
    btw, make sure it wont be effected by ionising radiation.
    once you get high enough, there is everything still up there from the trinity tests all the way to fukushima!
    • agtrbt
      • Sep 2015
      • Taiwan
      There is hardly any polys for 25V 3300uf
      The radiation should not be a big issue since many people can survive a high alt. balloon ride etc.
      Also, not equipped to do a really de-pressurised test here.
      So I am asking here has anyone put a traditional electrolytic capacitor in a near vacuum?
      • SteveNielsen
        Retired Tech
        • Jun 2012
        • 2327
        See attached.
        • mariushm
          • May 2011
          • 3799
          Could you explain the need for such high capacitance on a device that's supposed to go 15 Km up in the air?
          3300uF 25v capacitors will take up a lot of volume and won't be exactly lightweight. Perhaps you could lower the capacitance by using better ICs or some other methods.. maybe you could share some more info about how you use those capacitors with us?
          Cold isn't such a big deal if you have the energy to warm the circuit up in some way... keep in mind that some capacitors (some tantalum in particular) can have as much as -70% capacitance at -55c .. -40c
            • 31289
            i suspect this is something interesting, and not just the usual "camera on a parachute"
            maybe it's a radio repeater or a drone?
              • 31289
              Originally posted by agtrbt
              There is hardly any polys for 25V 3300ufSo I am asking here has anyone put a traditional electrolytic capacitor in a near vacuum?
              space is not a vacuum, it's a low pressure mixture of gasses.
              when i refered to a ground test, i meant a thermal test using a coldroom or oven.
              • MORETTIGIAN
                by MORETTIGIAN
                Title:
                Description:
                Procedure performed:
                - Removed backplate
                - Reapplied thermal compound
                - Reassembled card
                09-18-2025, 12:14 PM
              • Prolog
                by Prolog
                12-01-2024, 08:27 PM
              • flat-earther
                Hoover FM216LI cordless vacuum refuses to charge
                by flat-earther
                I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                06-06-2025, 03:14 AM
              • martyb
                capacitor value too high
                by martyb
                so when 1000 uf caps red at 1150 uf does this mean capacitor should not be used and is this signs of a deteriorating capacitor or has it simply been made that way
                02-24-2023, 11:10 PM
              • chth96
                by chth96
                06-02-2024, 07:31 PM
