PLACE TO GET CAPS
  • cwdesign
    • Jan 2005
    PLACE TO GET CAPS
    I have found a place to get the CAPS needed for most motherboards. If you go to www.mouser.com/nichicon here you can find the 6.3v 3300uf 10MM caps.
    The part number for the 3300uf 6.3v is: 647-UVZ0J332MPD .72 each or .53 each in quantity of 10.
    These are rated at 105 C
  • bushytails
    Moderator
    • Dec 2004
    • 217
    VZ series is not low-esr...
    --Randy
    • cwdesign
      • Jan 2005
      Not Low ESR
      I have used these to replace some badcaps that I had on a P4 motherboard and its been running for about 7 months with no problems.
      • Al
        • Jan 2005
        • 5
        --Randy
        what about the UPW series? They say "low impedance", but not "low ESR". Might they work anyway?
        [P.S. After posting this, I see that quoting isn't working. Also, I just had a devil of a time during every attempt at posting: I'd be asked to login, although I was already logged in. But it would reject my password. Then, the problem suddenly cleared up.]
        • bushytails
          Moderator
          • Dec 2004
          • 217
          Low impedance implies low ESR, as a high series resistance would raise the impedance.
          --Randy
            by momaka
            03-12-2025, 03:42 PM
          • tony359
            Best tool to place electrolytic SMD caps on a board
            by tony359
            HI all,
            I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
            When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
            The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because...
            01-28-2024, 06:23 AM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
