Help with Capacitor
  • pllasma
    • Jun 2015
    • 16
    • US
    Help with Capacitor
    I have a capacitor from a subwoofer with the following info:
    Samxon
    3300uF80V
    LP (M)
    85C -NEG
    Or view my attachment..
    There is a brown/tag substance at the bottom, does that mean it is bad?
    Also, and more importantly, I cannot find this exact capacitor anywhere, how would I find the exact replacement or is there an alternative part I can get?
    Thank you,
    Dave
    Re: Help with Capacitor
    Bad glues that will turn brown and become conductive and also eat away traces and wires, if you see it any where on the boards you must remove them.
    • pllasma
      • Jun 2015
      • 16
      • US
      Can I remove the bad glue and salvage the capacitor? If so do I need to add new glue?
      • SteveNielsen
        Retired Tech
        • 2327
        It doesn't need glue. That was only to hold those parts in the board before it went through the soldering process. Test the cap if you can. It won't necessarily be bad because the glue was there.
        • pllasma
          • Jun 2015
          • 16
          • US
          Can I test it still attached or is it better to remove the capacitor first?
          • SteveNielsen
            Retired Tech
            • 2327
            Better to test it removed so no other parts of the circuit it's in will affect the measurements. What do you have to test it with?
            • pllasma
              • Jun 2015
              • 16
              • US
              I was able to test both capacitors. Here is their behavior. Please excuse my lingo I am NOT an expert at circuit boards. The first capacitor went up to 20 ohms then I reversed the voltmeter leads it went down to 0 ohms then up to 2 ohms and stopped.
              The second capacitor went up to 10 ohms, when I reverse the leads on the voltmeter it went to 0 ohms and only up to 2 ohms before it stopped
              Both capacitors have the same exact specs on the outside.
              Does that sound like normal behavior for those?
              • SteveNielsen
                Retired Tech
                • 2327
                A DC ohms check like that is not a reliable test. All that tells you is that the cap charges up to some degree and isn't a dead short or open circuit but nothing about the actual capacitance. You need a capacitance meter capable of measuring that high of a capacitance and preferably tests ESR too. Then you can get an idea of the caps condition.
                  Is the sub woofer still working?
                  • pllasma
                    • Jun 2015
                    • 16
                    • US
                    For about six months, it was working, but making either high chirps or a low hum. 2 weeks ago it stopped working but still makes the noises.
                      • 31214
                      show us the rest of the board - both sides.
                      • pllasma
                        • Jun 2015
                        • 16
                        • US
                        I will once I get home later today..
                        • pllasma
                          • Jun 2015
                          • 16
                          • US
                          Had a meter at work that tests for capacitance. For the 3300 uF capacitor, it's reading 2940. Is that an indication that it could be bad or is that within normal range?
                          also hooked up a 1.5 V batter to charge the cap and it's staying pretty much at 1.5 draining very very slowly
                          • MORETTIGIAN
                            Capacitor detached from PCB – RTX 2070 Super Founders Edition
                            by MORETTIGIAN
                            Title:
                            Description:
                            During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                            I did not notice it detaching, so I am unsure of its original location on the PCB.
                            Procedure performed:
                            - Removed backplate
                            - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                            - Reapplied thermal compound
                            - Reassembled card
                            Observed behavior after reassembly:
                            - GPU powers on and operates normally under...
                            09-18-2025, 12:14 PM
                          • Prolog
                            RTX 3080 FE Identifying capacitor
                            by Prolog
                            Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                            I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                            I hope these photos make it clear which component I am referring to:
                            (yes, the soldering is a bit botched from removing the blown one, I know)
                            I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                            12-01-2024, 08:27 PM
                          • chth96
                            If I replace with inferior capacitor, Is it No harm to other IC components at all?
                            by chth96
                            I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                            Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                            It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                            So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                            I know that these capacitor will not last as long as nichicon capacitor...
                            12-22-2023, 04:34 AM
                          • chth96
                            How can I test non-polarized capacitor?
                            by chth96
                            I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                            I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                            And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                            I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                            06-02-2024, 07:31 PM
                          • chth96
                            Is it no harm to replace with capacitor without ripple current rating?
                            by chth96
                            When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                            Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                            But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                            Rubycon YK DataSheet (b...
                            04-19-2024, 05:19 AM
