Loose Cap causing 2 dead USB ports?
  • t3chb0y
    • Jan 2008
    I got a ECS board from ebay and I noticed that one of the caps near the rear IO had its "-" negative side detached...Could this be responsible for 2 dead USB ports in the rear IO? Would they work if I got a new capacitor (with the same ratings) and soldered it back together?
    Or would the 2 dead USB ports be caused by something else?
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Loose Cap causing 2 dead USB ports?
    Yes and Yes.
    Cap could be it. Could be something else.
    One way to find out.
    Mann-Made Global Warming.
    - Dr Seuss
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Usually USB ports go dead because someone pulled too much power through it and fried the USB chip. (They are only rated for 500 milliamps.)
      A bad (effectively missing) cap could be affecting the power to the chip or it might be a coupling cap that the USB signal passes through.
      - Dr Seuss
      • t3chb0y
        • Jan 2008
        with that said...does that mean the 2 USB ports aren't receiving power due to the loose cap since I get absolutely no signal plugging virtually anything that's USB in.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          I don't know where the cap is in the circuit.
          I can't tell you anything for sure without tracing the circuit.
          Yes, if the chip is not powered it can't pass the signal.
          Same-same.
          If you modem chip or LAN chip isn't getting powered it can't pass a signal.
          - Dr Seuss
          • t3chb0y
            • Jan 2008
            it's the most upper-left cap on the board (right next to the top left screw hole and beside the PS/2 ports)
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Ummm
              I don't see a picture.
              Nor do I know what model board it is to go find a picture. (If I had time.)
              Even still I can't trace a circuit by a picture.
              You should just re-attach or replace the cap and see if you get your port back.
              You are gonna have to do that anyway so,,,, Go for it!
              - Dr Seuss
              • tvtech
                • Oct 2006
                • 48
                Also look for miniature fuses near the usb ports,they come in all sizes and varieties,some look like SMD resistors some look like tantalum capacitors and some look like ceramic disc capacitors.I will post some pics of microfuses on a mobo tomorrow.Most boards have fuses protecting the +5v line for the usb.If you dont find any fuses and the cap replacement doesn't restore usb function you can always turn off the on board usb controllers and use a PCI usb 2.0 card.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  tvtech
                  Now that's an outstanding idea.
                  The start of the thread though is about detached caps.
                  Do you (or anyone) happen to have a schat for the USB section of a mobo that includes the IC and power to it?
                  - Dr Seuss
                  • yanz
                    • Nov 2004
                    • 910
                    please do so, thanks in advance.. i got several ecs mobo with dead usb port. recaping the caps wont fix the problem.
                    yep, for the time the only solution for me is to use addon pci usb card..
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      yanz
                      Did you check for those fuses tvtech mentioned?
                      Dead USB ports comes up all the time. It would be nice to find the fix for it.
                      Unfortunatly (umm.. sort of) I don't have any boards with dead USB ports to play with.
                      - Dr Seuss
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        yanz
                        Unfortunately (umm.. sort of) I don't have any boards with dead USB ports to play with.
                        - Dr Seuss
                        • tvtech
                          • Oct 2006
                          • 48
                          Sorry for the wait I WILL post pictures tomorrow,As for the schematic of the usb ports,you may have some luck getting a datasheet for the usb controller chip at www.datasheet4u.com and you could then trace the +5v line.Other that that I know that some early boards had the +5v rail feeding the ports directly and today most of the boards use the usb chip to switch the +5v off and on and some well desinged boards have seperate 5v regulators feeding each pair of usb ports
                          • yanz
                            • Nov 2004
                            • 910
                            To tell u the truth i dont know what is what So a pic would help...
                            • t3chb0y
                              • Jan 2008
                              my friend got one of the rubycon caps I ordered and soldered them on for me....apparently the USB ports are still dead.
                              • kc8adu
                                • Nov 2003
                                • 8832
                                • U.S.A!
                                carefully probe the ports and see if +5 is present.if not the fuse is blown.
                                most have polyfuses which reset after a short.
                                a busted port that is shorted is common too.
                                edit.
                                ecs is a cheapie board.
                                they may not even have fuses!
                                a short blows the foil to +5.
                                if they have fuses they may be one time which must be replaced.
                                • disorder
                                  ps5 edm-033 dead after hdmi/usb ports destroyed
                                  by disorder
                                  hello guys,
                                  i need help to repair a edm-033 ps2
                                  history : as always hdmi port and usb ports destroyed after unplugged
                                  after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                  so i changed it
                                  now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                  but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                  i don't see any projection of liquid metal on pcb.
                                  01-14-2025, 12:48 PM
                                • DynaxSC
                                  GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                                  by DynaxSC
                                  I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                                  There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                                  The board is generally working now, all PCIe ports are working, Windows installs normally.
                                  However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                                  The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                                  03-10-2025, 12:27 PM
                                  Lenovo ThinkPad P43s Mobile workstation P Specification for Upgrade or Repair
                                  This specification for the Lenovo ThinkPad P43s Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P43s boardview and P43s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                  09-06-2024, 09:40 AM
