Sorry if this is a duplicate. I searched this forum a bit and didn't see this capacitor specifically in my searches. Anyone know the manufacturer of the capacitor on this board? Usually Gigabyte says all Japanese capacitors but this board did not specify.
Manufacturer of these caps?
Re: Manufacturer of these caps?
They're polymer capacitors, so it really matters very little if they're Japanese or not. Polymer capacitors are way more reliable compared to electrolytic capacitors and they don't have as many ways to fail as electrolytics.
Apaq is used heavily by lots of motherboard makers, Asus for example used them a lot.
They don't fail more or less than other brands so no need to worry.Comment
Hi.
Any tip if can be fake/real panasonic?
http://www.ebay.com/itm/171193345673...%3AMEBIDX%3AIT
I measured it and cap is about 980u, ESR (AVR tester) showed 0,00R while Nippon LXZ 1000/10 showed 0,08R..
I tried to find DS, no way - somebody mentioned that is limited for MTB supplier.
Thanks!Comment
Hi.
Thanks!
If the LXZ cap you have is the 8mm diameter, then yes, that is correct. The datasheet actually says 0.08 ohms for the 8mm diameter one! :P
The FL are low ESR electrolytic caps, I think this is one of the series with the elusive datasheet. So I don't know what ESR it should measure. But it should be quite low.
-BenMuh-soggy-kneeComment
As a general rule, if you find good-looking counterfeits on eBay, check if the seller is also listing obvious counterfeits. If this is the case, the genuine-looking parts are fake too.
I would say yours are fake. In fact, I would say -all- Panasonic FJ/FL on eBay are fake.Comment
I just had an idea.
Why don't you cut open a genuine Panasonic FL and these, and compare the insides.
With polymer caps, the difference between quality and secon-tier ones is night and day. It might not be so apparent with electrolytics, but you might try sniffing the elctrolyte, if you can't see any difference in the foil.Comment
by eryjusHello,
Channel: General Capacitor Questions & Issues
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
by momakaI did it again – I had to fulfill my inner desire to fix yet another old piece of hardware. This one is actually kind of worthwhile, too – it’s an EVGA e-GeForce 7600 GS AGP video card, model P/N: 256-A8-N542-T2. With the popularity of “retro” PCs from the Win9x to XP era going up, and the diminishing supply of decent AGP cards, it is expected their prices will go up. Or is it? I bought the this video card rather on the cheap side (~$9 USD shipped to my door), because the eBay seller listed it for parts or repair (and correctly noted the bad capacitors.)
So, here is the... - Loading...
