Rubycon MBZ leaks in storage!
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    I removed some good caps from a Dell Optiplex GX260 mb 4 years ago.
    Past from visual inspection, I also tested them with esr micro and their ESR and uF were good.
    Yesterday I noticed one of them was leaking and bulging.
    Its current esr is 0.85 ohm and the capacity 824uF.
    Those caps have been stored in a dry place and the temperature varied from 15°C to no more than 25°C
    The other cap is still good. I don't know for how much though..
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Rubycon MBZ leaks in storage!
    even in storage a used cap is a used cap, sometimes this happens
    • Wester547
      • Nov 2011
      • 1268
      • USA.
      Well, that's scary...
      Even scarier, it's an 8x16 1000uF 10V MBZ, the same kind of MBZ Topcat pulled from those Thinkcentres three years ago, and most of them failed without any signs. I chalked that up to a bad run of bungs at the time (or someone who abused the leads whilst installing them), but now I'm not so sure... from what I can see, the capacitor was manufactured during the 13th week of 2002, in Singapore (March 2002... I think "A" means Singapore because I've seen 1000uF 6.3v 8x11.5 YXGs in a sealed bag before with "A" codes, and the label on the bag said that it came from Rubycon's Singapore factory). They are well over 13 years old at this point, though, so it might just be their time (even non-aqueous lytics have about a 20-30 year shelf life). Sometimes defects in the electrolyte take many years to cause issues and MBZ is only a 2,000 hour @ 105*C rated capacitor.
      Did it come out of a SFF GX260? Perhaps it was exposed to an excess of heat for too long and hence the bulging is the long-term effect (like what happens when you reflow Xbox 360 motherboards with the lytics still on). Also note that no capacitor is impeccable. When you produce millions of them, some are bound to be bad even from the factory. Another explanation is that once you get to MBZ-grade capacitors that lytics are no longer completely reliable. Think about how unreliable HMs once were and how unreliable KZGs are. Sometimes even FJs and WGs fail for no reason.... there is a reason why lytics don't go lower than HZ grade. It is very difficult to increase the conductivity of the electrolyte by way of ions. The increase in the H2O in the electrolyte necessary to improve conductivity makes all capacitors more sensitive to heat and that kind of electrolyte has a tendency to aggressively assault the dielectric until it's gone and hydrogen gas forms, which the proper neutralizers will reduce the likelihood of (which is why polymers exist - conduction by way of electrons, hence the solid state terminology). And that kind of electrolyte in a high concentration dries up faster than lytics with "conventional" electrolyte as well.
      There is also a possibility that the electrolyte completely broke down after the capacitors just sat there for four years. The aluminum oxide layer thins as long as the capacitor sits in storage with no voltage across the plates and no current going through it. That's not good for any capacitor. I think Panasonic recommends that 1 year be the maximum time lytics sit in storage without reforming. But maybe the simplest solution to come to is, don't trust those 8x16 1000uF 10V MBZs.
        • 31161
        i'v seen pana FC's leak around the leads,
        you have to remember that rubber goes hard with age.
        *any* cap with a rubber bung will have it's seal comromised eventually.
        interestingly i'v had old soviet caps that probably dont have this problem,
        the bung is plastic and is inserted with a rubber seal at the crimp-point - so it cant leak around the pins.
        i'v also seen old american caps from the late 70's and early 80's where the bung has an epoxy cap over it to prevent leaks. ( "T.I." branded)
        • TechGeek
          Computer Geek
          • Jan 2015
          • 2254
          Those were the good days. Made in America, high quality, not the Chinese junk we have today.
          Permanently Retired Systems:
          Kooky and Kool Systems
          sigpic
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            I'd give the thing a break. It's 13 years old now. It probably got quite a bit of use, and then 4 years is a long time to sit for an already almost decade old capacitor. This is why I'm always a little skeptical about reusing caps.
            • mockingbird
              • Dec 2008
              • 5484
              I've got some Rubycon MBZ/MCZ, specifically:
              MBZ
              6.3v 2200uF:
              0340
              0227
              0202
              0202
              16v 1800uF:
              0333
              0333
              0333
              16v 1500uF:
              0227
              MCZ
              6.3v 1500uF
              0542
              0542
              0542
              6.3v 820uF
              0521
              0521
              None of them look defective, nor do I have any reason to believe they are.
              All the datecodes are prefixed with "T".
              I think Wester547 is on to something when he mentioned the Singapore factory (datecode prefixed with "A").
              • Wester547
                • Nov 2011
                • 1268
                • USA.
                ^ I don't think that's it because if you look at Topcat's thread of failed MBZs, the 8x16 1000uF 10V ones, that failed without showing it, had "T" prefixes (Japan). I agree with P4. There is a reason why manufactures recommend against reusing old capacitors. And I have a hunch that as the dielectric thins on the shelf, the neutralizers lose their effectualness in protecting the dielectric from the aggressiveness of the hugely water-based electrolyte (they can't really protect something that just thins and thins). That could as well be what happened.
                And IMO, the factory from which they came really isn't a way to gauge at the quality of certain series. I've seen KZGs and KZJs fail prematurely from almost every factory I've ever seen labeled on Chemi-con sleeves, for an example... "(k)" - Indonesia. "(T)" - Japan. "(2)" - probably Japan. "(3)", "(7)", etc...
                Also agree with P4 with respect to the age of the capacitors. 2,000 hours @ 105*C capacitors just don't last long as series with superior endurance and I don't think they're meant to (even though some are obviously better than others).
                • mockingbird
                  • Dec 2008
                  • 5484
                  Would you say reforming these types of caps would prevent failure then, no matter the age?
                  Also, consider that in P4 machines which often had terrible PSUs and poor ventilation, MBZ rarely or never bloated in them, even while KZG/KZJ spewed their guts. This 2006'ish Foxconn board is a good example (MBZ on VRM high, KZG on VRM low).
                  With regards to Topcat's thread, For some reason I've always had a suspicion in the back of my head that Rubycon either intentionally or otherwise produced some inferior batches, which went out to Lenovo and Dell.
                  Hopefully I'll have the means soon to measure these caps (With a host of a whole bunch of others) to confirm that they're still good, with a product I expect to receive from our great forum member Behemot.
                    • 31161
                    it could just be down to how they ran before being salvaged.
                    • Wester547
                      • Nov 2011
                      • 1268
                      • USA.
                      I couldn't tell you. I don't think goodpsusearch's findings reflect well on Rubycon MBZ, because bloating some time after being pulled is the kind of thing KZGs and KZJs do.... and bad HMs and HNs. And Fuhjyyus and CapXons. On the other hand, those MBZs could have had a rough life and are over 13 years old, so I wouldn't rail Rubycon on for it. Most of the time, MBZ is a very reliable series and handles heat quite a bit better than MCZ.
                      Looks to me like it has KZJ in the VRM output, but I doubt KZG would do any better - maybe even worse. Those 3300uF 6.3V KZGs are really the worst of them all. Interesting thing about VRM in/out failures.... most of the time the failed KZGs and KZJs, or the ones that failed the fastest, are on the lower voltage rails and not the higher voltages one unless they run too hot for too long, even though KZGs do have a tendency to silently fail. That's because (I think) the higher voltages rebuild the oxide layer faster and prolongs failure (though it consumes more electrolyte in the process since those KZGs/Js are working closer to their maximum voltage rating).
                      Makes me wonder if KZG and KZJ are intentionally bad! But I honestly think those "good" companies have better standards than that. In the case of those MBZs, since most of them failed without showing it, it was either A) a bad run of bungs or B) someone didn't treat the capacitor leads with much care, compromising the quality of the seals. Or.... C) 1000uf 10V Rubycon MBZs of the 8x16 dimensions might have some chemistry issues are are best avoided.
                      • mockingbird
                        • Dec 2008
                        • 5484
                        Oops. Yup, that's my board... Outlasted the re-capped fleamarket SP-450 PSU, decided to repurpose it as a server in a school, after I upgraded to my poor man's quad-core.
                        I must say fascinating theory on the behaviour of failure on KZG/KZJ... Kudos for that.
                        The better question is, did UCC ever actually find out a suitable electrolyte formula for ultra-low ESR caps. Someone put forward recently in a thread here that it's even possible until the very end of the series' run that UCC never even knew about the premature failures. Considering Japanese culture, I can imagine a company like UCC being very stubborn about the quality of their product, given their track record. Foolish of them though if you ask me, because they've had several dud series before.
                        Then again, it could have been intentional, as you said. Planned obsolescence and all that.
                        To be fair to them, UCC is the only Japanese company I can think of that didn't outright buy another polymer cap manufacturer like Panasonic buying Sanyo's polymer division or Nichicon buying Fujicap. You gotta give props to them for that.
                        • Wester547
                          • Nov 2011
                          • 1268
                          • USA.
                          I don't know if that's really correct, but I think it's just simple logic. I have noticed that behavior with many bad cap series - the bad HMs, and even Teapo, etc.
                          The baffling thing about that is that if you look at UCC's KZG datasheet (the one by UCC and not NCC), it is said that KZE use the same electrolyte technology as KZG and KZJ! And KY's datasheet further says that KZE and KY use the same electrolyte too. So it must not be inherently bad electrolyte, but using it (their foray into water-base electrolyte) in greater concentration must cause the electrolyte to break down and attack the aluminum foil, which makes sense to me. KZE and KY have an extremely good track record compared to KZG and KZJ, so I don't know what else to make of it.
                          I don't consider those old series bad at all. The fact that they almost never bulge and that the bungs almost always give away and allow for electrolyte to leak quite simply means that the bungs hardened and decomposed over time, like stj said. Those capacitors do not have bad electrolyte by a long shot. The fact that the bungs decomposed first goes to show you how good the electrolyte is, and I think Rubycon, Nichicon, Chemicon, and Panasonic have improved upon the quality of their seals over time, but as stj said, the rubber bungs do eventually decompose and end the life of the capacitor.
                          No, but UCC bought Marcon's divison of lytics many years ago, 1995 IIRC.
                          I think Rubycon had an advantage over UCC and some Nichicon in terms of ultra low ESR lytics because of something theOracle said some time ago. He said that a friend, in the know as an engineer at Sony, had noticed that Rubycon's primary plant in Japan borders on a spring of incredible purity. Rubycon must have a special kind of water-base electrolyte that yields much better conductivity so they can make ultra low ESR lytics with less of it, which means they don't fail as much and have better stability characteristics. Just a theory, I don't know if it's really true. Similar may be true of Panasonic - their capacitors are expensive for a reason so they must use very expensive materials, electrolyte included, and that electrolyte probably has better conductivity than their peers, giving them another edge over the competition. Again, just a theory.
                          This thread though is proof that even Rubycon MBZ isn't invincible, and in that sense all electrolytics will eventually fail, even the good ones.
                          • goodpsusearch
                            • Oct 2009
                            • 2850
                            • Greece
                            I reuse caps all the time with no issues till now.
                            On the other hand I have seen several caps fail in storage, mainly KZG, KZJ, and bad caps. It's like capacitors prefer getting some use every now and then (ripple, DC voltage and heat) rather than staying for months unused.
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              I think I have a few 1800uF 16V (10mm dia) rubycon MBZ with the A on the datecode and they are from 2002 if I recall correctly. Will have to check later today.
                              Uh, keep in mind, they (KZG) are only rated for 2000 hours. Even if the caps last less than a year, as long as they have lasted over 2000 hours, then I don't really see any issue. Obviously, the 2000 hour rating doesn't mean that they won't work at 2001 hours ... it's nice to have them last longer than 2000 hours, which some capacitor series will.
                              Muh-soggy-knee
                                • 31161
                                that's 2000 hours at 105'
                                the life increases as you decrease the temp.
                                • Wester547
                                  • Nov 2011
                                  • 1268
                                  • USA.
                                  The very first version of NCC KZG's datasheet that I posted in the "What pisses you off?" thread rates the 10mm 16V KZGs (10x12.5 680uF 16V, 10x16 1000uF 16V, 10x20 1500uF 16V, 10x25 1800uF 16V) for 3,000 hours.
                                  Well, at 65*C, they are supposed to last 32,000 hours and at 60*C, 45,200 hours according to the "10*C decrease doubles the life" rule. Most of the time, they don't last anywhere near that long at lower temperatures. I think bad capacitors are too unpredictable to follow that particular ruling. Furthermore, I've seen 2,000 hour @ 85*C and 1,000 hour @ 105*C GP capacitors outlast 2,000 hour @ 105*C KZGs and KZJs, even in storage. So something is definitely wrong with them. I don't really think it's about the endurance rating, though, it's about the individual solution each capacitor uses. And this thread makes me think twice about knocking them (KZGs) - I guess all ultra low ESR capacitors have the same issue, but that for some it just takes longer for those issues to surface, even if it's many years...
                                  We all know that if capacitors hate anything the most, it's heat. Heat is the ultimate enemy of all lytics and greatly expedites any chemistry issues any capacitor may have. I think they'd be more likely to fail if you heated them right up than if you let them sit. That said, it's probably a better bet to use them and keep them cool above all else.
                                  • mockingbird
                                    • Dec 2008
                                    • 5484
                                    Tne very first version of NCC KZG's datasheet that I posted in the "What pisses you off?" thread rates the 10mm 16V KZGs (10x12.5 680uF 16V, 10x16 1000uF 16V, 10x20 1500uF 16V, 10x25 1800uF 16V) for 3,000 hours.
                                    Interesting. I did a double-take when I read this, and looked my own KZG datasheet. I found the one you were refering to in this post. So now I have three of them:
                                    What do you think about Panasonic ultra low ESR? I've never seen reports of defective Samxon GC/GD/GA either (Though I think they bought their electrolyte from one of the Japanese vendors). What about Sanyo WG?
                                      • 31161
                                      pana dont make ultra-low esr caps, FR is the lowest they have.
                                      (i'm not including FL because you cant buy them, and there is no official datasheet)
                                      • Wester547
                                        • Nov 2011
                                        • 1268
                                        • USA.
                                        Panasonic do make ultra low ESR capacitors, they just sell them directly to OEMs. FJ (and FJS/FJZ I think) are equal to HM, the datasheet for FJ does exist (you can find it if you Google it). Don't know about FL but in accordance to an old post by PCBONEZ, they should be equal to FJ, according to an old ad he saw by Panasonic.
                                        Actually, premature failures of Samxon GC/GD definitely exist...
                                        https://www.badcaps.net/forum/showpo...&postcount=164
                                        https://www.badcaps.net/forum/showpo...29&postcount=3
                                        https://www.badcaps.net/forum/showpo...9&postcount=42
                                        https://www.badcaps.net/forum/showpo...&postcount=167
                                        https://www.badcaps.net/forum/showpo...&postcount=172
                                        And a few posts in this thread:
                                        https://www.badcaps.net/forum/showth...=gc#post414522
                                        Haven't seen a GA fail prematurely yet, but it's hard to say. And we all know how unreliable Samxon GF and GK are, and they are equal to HE and HD respectively, so I don't think that can bode well for them either. Panasonic ultra low ESR capacitors are great, in my experience - no complaints. Sanyo WG are also good, though I've found them more resistant to heat than the WX series (equal to HD) which always bewildered me. WF (equal to HN), not so good, but Sanyo capacitors, at least on Intel/Foxconn/Dell motherboards, are seldom seen compared to the other brands so it's hard for me to form a conclusive opinion about them, so I won't call them out because they haven't caused the premature death of millions of motherboards like KZG have.
                                        • bjs59
                                          Infamous Rubycon MFZ... Current recommended replacements???
                                          by bjs59
                                          What we have here today is an Intel DG33FB motherboard, circa 2007... I need to replace some of the caps on this board... From what I have found, one of these caps was sort of well known here back in the day as they were used in XBoxes and XBox 360s as well....They are the Rubycon MFZ series, in particular the 6.3 v 3300uf 10mm X 20mm... I have found a seller on Amazon, The Capacitor Store, that has them listed but I have a hard time believing these are genuine pieces... The original recommendation was to replace any bad ones with Nichicon HZ series since the Rubycon MFZ's were a custom product,...
                                          12-10-2020, 10:47 AM
                                        • triplefour
                                          JVC LT-55UE76 has bulged cap on power supply, spilled electrolyte.
                                          by triplefour
                                          got this tv from a friend who got a new one and didnt want to bother repairing this one.
                                          he said it sometimes would just flash color patterns.
                                          and sometimes it would just work
                                          i figured it had some intermittent mainboard issue.
                                          i stored it at home for a while before looking at it
                                          when i plugged it in for the first time, i heard some popping noises
                                          and then a big cloud of white smoke came out of the back of the tv!
                                          i noticed the smoke didnt actually smell like anything. not like when an IC blows.
                                          i unplugged it and took the back off and discovered...
                                          12-18-2022, 12:38 AM
                                        • SwedishDiesel
                                          Panasonic caps - dried electrolyte on leads/bung from factory?
                                          by SwedishDiesel
                                          I just bought these from Mouser and upon closer inspection the area where the bung and leads meet has some dried green substance on it, presumably dried electrolyte. Is this normal?...
                                          03-03-2022, 06:06 PM
                                        • DXseekerMO
                                          Failed UCC and Rubycon replacement on a Dell XPS410, equivalent?
                                          by DXseekerMO
                                          Hello, I'm working on an old Dell XPS410 with burst capacitors. I'm trying to source either an equivalent replacement, or a replacement that will work. It's been suggested to me to use Poly caps as a replacement, but I have no idea what to order or what will work.
                                          If anyone has a link to where I can buy what I need that would be even better.
                                          These are the caps that have burst:
                                          Board location: C8BV, C26BV, C43BV
                                          Brand: United Chemi Con
                                          Series: KZG
                                          Size: 10mm dia X 25mm height
                                          Impedance: (ohms max/20c, 100kHz) .012
                                          Ripple: 2800...
                                          02-04-2022, 04:48 PM
                                        • SwedishDiesel
                                          Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
                                          by SwedishDiesel
                                          Howdy folks,
                                          I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
                                          10-30-2021, 12:47 AM
