APC smart-UPS's
  • xelectech
    retired tech
    • Nov 2014
    • 238
    APC smart-UPS's
    Haven't posted much here, but have been reading alot and picking up all kinds of great tidbits from most areas of the fora, thanks to all of you who keep this
    great font of info going...
    Anyway, I've got 4 Smart-UPS's, (one 1000, two 1400s and a 1500), all of which I've modified to run with external batteries. One of the units used to overheat its pair of batteries, until I applied a circuit modification found on badcaps.net to lower the float voltage (don't have the thread handy at the moment), which worked like a charm. However, of all the UPSs, this one has the longest cabling to the batteries, made from a scrounged pair of jumper cables, using about 8' or so of what is ,I think, 10 AWG fine strand wire.
    This is also the only UPS that ocassionally displays a row of blinking leds (the ones that show over the battery icon) - they will just occasionally start blinking, (all 5 of 'em) for no apparent reason, and for a varying length of time, kind of like what they do while doing a self test except no load is being supplied to the batteries (don't hear the inverter starting up and no other leds change state and the load leds show just a light load (only first led is lit). I quess I'll try shortening the cabling if I can't think of any thing else to try.
    Just wondering does this ring a bell with anyone?
    Just as a data point I thought I would mention that I've previously used wet storage batteries with my UPSs, but was cured of that when I had a pair of deep cycle batteries explode. I'd had them about a year and a half when one evening I heard a rather loud report from the computer room, and I found the top of the case cracked and the batteries low on electrolyte, so topped up with DW and figured that to be the reason; I used 'em another couple months, keeping an eye on the water level, until the evening when they exploded again; but, this time it was like a shotgun blast, it shook the whole house! Sprayed acid all around and this time the case was cracked down below the water level and leaking acid so I gave up on using wet batteries.
    I expect it was a defectively made battery with an intermittent connection inside, but the warranty was up on them, and of course the vendor said they're not responsible. So, just thought I'd suggest for anyone who's maybe using wet batteries that you may want to somehow ensure that the acid will be contained if something like that does happen; some guy has since warned me that dry- and gel-cell batteries can also make quite a mess if they get a direct lightning strike, but I've not really done a whole lot to protect against that, so far.
    Sorry to be so long-winded. Anyone else had batteries blow up on them?
  • xelectech
    retired tech
    • Nov 2014
    • 238
    Re: APC smart-UPS's
    After totally rearranging placement of batteries and computer gear and getting rid of the 8' of jumper cable, I found a brass screw (from one of the receptacles) rattling around inside the UPS, so I think that the odd behavior was most likely due to that - from the looks of the screw, I'm lucky there were no copious amounts of smoke released.
    • TechGeek
      Computer Geek
      • Jan 2015
      • 2254
      Re: APC smart-UPS's
      Battery exploded?? EPIC FAIL!!
      Permanently Retired Systems:
      Kooky and Kool Systems
      sigpic
      • xelectech
        retired tech
        • Nov 2014
        • 238
        Re: APC smart-UPS's
        Nothing very epic there, nobody was injured, no fire involved; just majorly inconvenient...YMMV
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Re: APC smart-UPS's
          Perhaps the UPS was over-charging the battery? Or maybe it was a faulty battery. Something had to have ignited the hydrogen gas. Sparks from a bad connection maybe?
          Muh-soggy-knee
          • xelectech
            retired tech
            • Nov 2014
            • 238
            Re: APC smart-UPS's
            I think the charging voltage was Ok, before the deep cycle batteries I had two regular car batteries that lasted 9 years or so (really low capacity towards the ends, though).
            So, I suspect an internal defect , which resulted in a spark inside the battery.
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              Re: APC smart-UPS's
              most likely a bad battery.
              trojan recalled a bunch of deep cycles for just this issue.
              i found out i had 4 dry charged that were subject to the recall.local dealer thanked me for checking rather than using them.i get all the cpsc notices and sometimes it catches things like this here.
              • xelectech
                retired tech
                • Nov 2014
                • 238
                Re: APC smart-UPS's
                Are you using them for UPS duty? Just curious if so what kind of life you get out of 'em,
                what capacity they are, etc.
                What are cpsc notices, sounds like a good thing to keep abreast of.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  Re: APC smart-UPS's
                  i have some 4d and 8d that are 14 years old now.
                  one is under my bench with an old best power 850va ups on it.
                  i test hf radios and boom car amps with it too.
                  setting the float to optimum and doing an occasional eq at around 16v for a few hours helps.
                  and the cpsc is a government safety agency.
                  http://www.cpsc.gov/en/Recalls/
                  • xelectech
                    retired tech
                    • Nov 2014
                    • 238
                    Re: APC smart-UPS's
                    Awesome battery life, kinda makes the initial price seem reasonable.
                    Thanks for the info and the link.
                    • carrzkiss
                      Cyberpower cps1500avr not charging batteries
                      by carrzkiss
                      Hello, all.
                      Cyberpower Battery Backup Unit.
                      I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                      When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                      In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                      Checking the voltage, it was down to 22v.
                      I quickly removed everything...
                      06-15-2024, 02:10 PM
                    • DanielCoffey
                      Bosch GRA53 36V Lawnmower - no motor
                      by DanielCoffey
                      Hi folks. I have a Bosch GRA53 36V lawnmower that has developed a fault and will not spin the blade.
                      I should say for the purposes of guiding what how you can explain things to me that that I have only modest knowledge of electronics, own a basic multimeter and soldering iron.
                      The mower is four years old, out of warranty, discontinued and the brand has been sold to Honda who have iterated on the design a couple of times and now sell their own 36V mower. My mower was effectively a prototype when Bosch tried the 36V Bosch Professional range of garden equipment which...
                      08-06-2023, 12:40 PM
                    • Pipolups
                      Corsair K70 LUX RGB dying LEDs
                      by Pipolups
                      Hi there !
                      I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                      Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                      10-08-2024, 11:58 AM
                    • howardc64
                      Where do repair shops buy MB replacement batteries?
                      by howardc64
                      Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
                      Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
                      BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
                      07-25-2024, 10:42 AM
                      Here is a good used source for 18650 batteries
                      by sam_sam_sam
                      Here is a website I have ordered from before and the results that they claim are correct from what I have seen from the batteries I have bought from them
                      BatteryHookUp.com
                      https://batteryhookup.com/collection...odem-batteries
                      I have test about 5 battery packs ( out of 15 battery packs I bought) and have had very good results and so far have not found any bad cells
                      I have also bought these battery packs before on EBay and they are a good source for a battery case that holds 18650 batteries however...
                      06-25-2021, 05:05 AM
