Recapped, now burning smell!! Need Guru!!
  • glutton4punishment
    • May 2013
    • 81
    Received a MB with 12 bad caps, all 820uf, 6.3v. The caps available to me were 1000uf, 6.3v. According to google search, that shouldn't have been a problem.
    It was a long royal pain in the ass to switch out the caps, but I got it done...not pretty soldering, but it's done!
    Started it up and to my utter astonishment, it worked!
    BUT....a overheating smell. I shut her down, and found out the culprit
    On the pic, transistor (?) # 1 is burning hot to the touch. #2 is hot, but not terrible. #3 and #4 are cool to the touch, as are the other transistors on the MB. BTW, the new caps are the black ones in the pic, and a lot of them are located physically next to the transistors.
    What should I do?
    What did I do wrong?
    Would the MB work if I didn't solder a cap on right?
    Is it the 1000uf vs. the 820uf values (shouldn't be...and please don't make me change them out!!)
    thanks a million!
    • 31059
    Re: Recapped, now burning smell!! Need Guru!!
    what make and series are the new caps?
    • Heihachi_73
      • 713
      I see NCC, Nichicon and Sanyo caps... I'd be more interested in finding out what the old caps were before determining the series.
      Those transistors were probably already fried by the ripple current caused by the twelve bad capacitors. If the PC still POSTed with two failed transistors, it most likely did with the bad caps intact too, just rebooting or freezing all the time. Of course, disregard this if they were still cool before replacing the caps; I can't see how 1000uF in place of 820uF could cause the start of a smoke show though, unless the ESR was way different (however, the ESR would have been through the roof with the failed caps). Nothing worse than swapping in new parts only to see them release the magic smoke seconds later (SMT transistors like those are also an absolute PITA to remove, but it looks like it will have to be done to make that board happy again).
        • May 2013
        • 81
        Thanks for the responses!
        The new caps are Nichichon.
        The old cap were TK.
        What's interesting is that the whole board was populated with the TK caps... ALL of the 820uf caps blew, but the rest are good. I figured it was a bad run for that value. -
        I have no idea if the MB worked before I got it, or if the transistors were cooler than now.
        I wasn't clear enough in my description. No smoke, just a burning smell. I immediately turned it off b/c after all that work, I didn't want to fry the board. I can see that the really hot transistor is starting to discolor the MB from green to brown on the side opposite the transistor, and if you look closely in the pic, the "glue" from the transistor to the plate of metal under it is turning brown.
        Right now I can get the computer to boot to windows and I've let it run for about 5 minutes before getting nervous and shutting it down again.
        Some questions:
        1. If I had screwed up one of the soldering of even one cap, would the computer still turn on?
        2. Is the transistor(s) running hot b/c of my lousy job of cap replacement, or something else going on?
        3. Since everything is working, should I try to ghetto rig a heat sink for the hot transistor, does it need to be replaced, or what??
          • 31059
          i'll ask again,
          what series of nichicon,
          and what series of Tk
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Ding Ding Ding.
            It very well could have been faulty from the beginning. Countless cases where faulty capacitors have caused inductors to overheat, and other bad stuff to happen.
            Test in using your meter.
            Check to see if it is shorted. If it seems partially shorted, either remove the CPU or desolder the transistor and then test it.
            -Ben
            Muh-soggy-knee
              • May 2013
              • 81
              Originally posted by stj
              i'll ask again,
              Since I don't know how to answer this, I'll just give your all the numbers:
              TK ATWY 909B
              Nichichon AD621 PET
              hope this is what you're asking for!
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                TK ATWY 909B
                Nichichon AD621 PET
                You've gotten the TK caps right, there is an ATWY series.
                On the nichicon caps, you have the date code and I think PET is the plastic the sleeve is made out of.
                On the nichicon caps, the series is printed right "under" the negative stripe. It might say something to the effect of "HM(M)" or "HD(M)".
                -Ben
                Muh-soggy-knee
                  • 31059
                  datasheet
                    • May 2013
                    • 81
                    Originally posted by ben7
                    Ding Ding Ding.
                    -Ben
                    This is not easy for me. There are two transistors with the same ID #'s on them, numbers 1 & 2 on the picture. Remember #1 is extremely hot.
                    So lets pretend that the legs sticking out of the bottom of the transistors are lableled ABC from left to right. Leg B is cut off, leaving only A and B soldered to the MB.
                    With DMM on diode mode, for transitor #1 I get:
                    With Red lead on leg A, Red lead on B, Red lead on C
                    Black lead on leg A-- NA , 0, .90
                    Black lead on leg B-- 0 ,NA, .50
                    Black lead on leg C-- .90, .60,NA
                    This is getting frustrating!
                      • May 2013
                      • 81
                      -Ben
                      my bad! the nichichon is HM(M)
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        Yes HM series is good for motherboard use.
                        Hm, seems like the gate is shorted to the drain (bins A and B, FYI B is also connected internally to the thermal tab). Remove the transistor and test it again, just to make sure it is actually the problem and not something else. Also FYI, the transistor is a MOSFET, not an BJT, so don't expect to get diode junction readings unless the FET is turned on or you are measuring the internal reverse protection diode. If you are confused, look up how to test a FET with a DMM.
                        -Ben
                        Muh-soggy-knee
                          • May 2013
                          • 81
                          thanks, Ben, glad you were able to understand my post. Well, I'm off to desolder the MF!
                          • howardc64
                            LG 65UQ8000AUB no backlight burning smell
                            by howardc64
                            Only 3 years old. Owner said backlight went out and burning smell. Didn't bother plugging in to check if had power LED. Just opened the TV rear and found shorted bridge rectifier diode on the backlight circuit on the PSU. SF26G (400V 2A super fast recovery rectifier link ) diode replace with SF26 (what I had on hand) Google AI said G = Green Components.
                            Burn looked pretty bad on the board but just was blackened carbon coating material. Scraped and cleaned off quite well and clean solder pad for the new diode.
                            06-07-2025, 10:38 PM
                          • Daniel Larsson
                            Marantz SR7500 burning output transistors - so far 2 channels are gone. Help!
                            by Daniel Larsson
                            Will start with the question and the full story follows below.
                            Can someone please let me know what voltage I should see per pin on the protection circut IC81, TA7317P?
                            My voltages per pin with the IC removed, only measuring on the soldering pads now, are:
                            1 -0.39
                            2 0.0
                            3 0.0
                            4 0.0
                            5 -12.5
                            6 11.94
                            7 0.0
                            8 11.74
                            9 11.74
                            The full story is that my Marantz SR7500 shut down a couple of days ago stating "CHECK POW5".
                            I checked the service manual to find out that the...
                            05-30-2025, 11:39 AM
                          • karatzdi
                            Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                            by karatzdi
                            I know some might say... just buy another one. Sell it as parts..!
                            So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                            Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                            Spent some time downloading the Service...
                            06-11-2024, 08:38 AM
                          • stormanimal83
                            Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                            by stormanimal83
                            Hey....
                            Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                            my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
                            01-18-2024, 02:15 PM
                          • Francesc V.
                            Onkyo A8200 - Not the right voltages in some transistors
                            by Francesc V.
                            Hi:
                            I am trying to repair this amplifier that I've bought as faulty. I've found some transistors damaged, the ones where I am drawing a red circle.
                            With the final transistors not yet installed (the expensive ones), I've started to measure some voltages:
                            Where I am supposed to have 1.12V (base Q524/Q523) I am reading -42V..................both channels don't seem ok.
                            Where I am supposed to have -1.12V (base Q526/Q525) I am reading -44V..................both channels don't seem ok.
                            I removed and tested Q514,Q516 & Q513,Q515 but the analyzer...
                            04-19-2025, 07:17 AM
