Marantz SR7500 burning output transistors - so far 2 channels are gone. Help!
  • Daniel Larsson
    • Feb 2025
    • 15
    • Sweden
    Will start with the question and the full story follows below.
    Can someone please let me know what voltage I should see per pin on the protection circut IC81, TA7317P?
    My voltages per pin with the IC removed, only measuring on the soldering pads now, are:
    1 -0.39
    2 0.0
    3 0.0
    4 0.0
    5 -12.5
    6 11.94
    7 0.0
    8 11.74
    9 11.74
    The full story is that my Marantz SR7500 shut down a couple of days ago stating "CHECK POW5".
    I checked the service manual to find out that the protection circut IC81, TA7317P, senses a power failiure on the amp board and is triggering shutdown to IC36 on the power board.
    I found that the SAP17 on the SR channel was shorted and probably burned so I removed that PNP/NPN pair and also the resistors and diodes that clearly burned.
    After stripping all the key components from SR channel I could start it again without any check pow5, and I was happy to enjoy music for roughly 20 seconds. Then again, smoke, shutdown and check pow5.
    This time it was the center channel.
    I have now removed the damaged SAP17 pair from the center channel as well but the check pow5 remains and I don't even dare to connect the BH+ and BH- as probably more will burn.
    While I only dare to hook the amp board up to the bench power supply I managed to find a faulty NJM2068, IC71, that was shorted to ground which I have now replaced and the short is gone.
    Any help or guidance is greatly appreciated to hopefully bring this one back to life.
  • petehall347
    • Jan 2015
    • 4448
    hope you didn't power it up as it is in the picture .
    • Daniel Larsson
      • Feb 2025
      • 15
      • Sweden
      It was powered up by the bench supply like that to measure the voltages. The current limiter was set to 0.5A and the card was not pulling nearly that, and showing stable voltages.
      Could you let me know how come you hope I did not?
      • petehall347
        • Jan 2015
        • 4448
        because it's very likely to burn up the output devices in little time ..they did extremely well to last 20 seconds without cooling .
        • Daniel Larsson
          • Feb 2025
          • 15
          • Sweden
          Oh you are refering to when it played for 20 seconds?
          I had the receiver fully assembled with proper cooling back then.
          At this point on the test bench (that the photo shows) there is no heat at all. No AC connected, I currently have it like this to troubleshoot the bias and the protection circut to try to figure out what is blowing the outputs when the AC is connected.
          Any ideas?
          • petehall347
            • Jan 2015
            • 4448
            firstly verify the power supply
            • sima112
              Marantz pm 6005 right channel not worknig
              by sima112
              Hi guys,
              I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
              01-30-2023, 12:11 PM
            • rustinjust
              Advice needed-Technika 32-207 works but sticks on channel,won’t change channels ok
              by rustinjust
              My tv will work for a while and change channels with the remote as it should but then it will stick on one channel only and work ok but it won't change channels. I have tried unplugging it for hours and whilst unplugged pressing the power button on the tv to reset it.
              The volume button on the remote still works but it just won't change channels once it decides to stick on one channel
              It has built in basic freeview tv here in the uk, I've tried doing an automatic search to reset the tv but nothing works.
              I have to turn the tv off and then on again with...
              09-28-2023, 12:23 PM
            • karatzdi
              Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
              by karatzdi
              I know some might say... just buy another one. Sell it as parts..!
              So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
              Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
              Spent some time downloading the Service...
              06-11-2024, 08:38 AM
            • acedogblast
              [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
              by acedogblast
              First off I would like to thank this community as it has provided me with great information that has helped me greatly on my repair for this Marantz SR5012 AV receiver. I am creating this new thread as the other 2 that I have created here has had their original question/problem solved and I plan that this is the final thread on my repair. Please note that this is my first time repairing audio amplifiers so I may not be aware of common issues and things to know.
              Lets start at what I have done so far. Random speaker popping on all channels is fixed by replacing the 2 large filter...
              03-01-2023, 08:24 PM
            • CDNBrewer
              Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
              by CDNBrewer
              Hello Everyone,
              I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
              Symptoms:
              • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
              • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
              • I swapped the Left and Right surround
              08-05-2025, 09:29 PM
