Replace bad caps with Panasonic caps
  • liukuohao
    • Oct 2013
    • 63
    • Malaysia
    Hi there,
    I have some Chemi-con KZG 820uf 6.3v 8mm diameter are leaking badly.
    I wonder if I replace the following Panasonic cap:
    http://my.rs-online.com/web/p/alumin...itors/7083447/
    would pose any problem later on my motherboard.
    The reason, I choose this FR series capacitors because the endurance is
    longer than the others = 10,000hrs!!!!
    But it does not specified the ESR value???
    Thank you for any guidance / feeback given.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Replace bad caps with Panasonic caps
    Fr isnt the correct esr for motherboards unfortunately.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Try using rubycon mbz, or mcz they are great for motherboards and correct esr I use them in most of my repairs. If you cant find then have a look at nichicon hm, hz they are also motherboard grade.
      • mariushm
        • May 2011
        • 3799
        The ESR of the capacitor is specified in the datasheet, which you can find here:
        The ESR is a bit high compared to the ESR of the KZG series, you should use capacitors with a bit lower ESR even if the lifetime rating is not as high.
        You can get a lower esr by using a capacitor that's rated for higher voltage and/or for slightly higher capacitance. There is a relation between the volume of a capacitor and the ESR (among many other things) and as a capacitor rated for higher voltage will usually be slightly taller, that also means the ESR will be a bit lower.
        So for example, while 820uF 6.3v Panasonic FR is advertised as having 56mOhm ESR, an 1200uF 6.3v or a 1000uF 10v Panasonic FR capacitor will have an esr of about 41mOhm, which brings the ESR much closer to 36mOhm (the one KZG has).
        Panasonic FM series should behave about the same, maybe even a bit lower ESR, but the lifetime is probably a bit smaller. 1200uF 6.3v and 1000uF 10v have 30 mOhm esr but they're 20mm tall (if there's heatsinks, coolers close by, make sure the height isn't a problem)
        Now, 1000uF is close enough to 820uF that the circuit will be fine (95% sure), 1200 uF is a bit of a stretch but it may work just fine.
        So now you can just go on RS-Online and pick the ones that are 8mm in diameter, because these capacitors are available in both 8mm and 10mm diameters.
        Panasonic FM 1000uF 10v 8 x 20mm : http://my.rs-online.com/web/p/alumin...itors/5261115/
        Panasonic FR 1000uF 10v 8 x 15 mm : http://my.rs-online.com/web/p/alumin...itors/7083548/
        This should also work (just a bit weaker than Panasonic FR performance wise) :
        Rubycon ZL 1000uF 10v 8 x 20mm : http://my.rs-online.com/web/p/alumin...itors/7037239/
          • 31293
          or use poly's
          • c_hegge
            • Sep 2009
            • 5219
            That's what I would do. I have a few Nichicon L8 (or S8, can't remember for sure which) 820uF 6.3V in 8mm dia. It doesn't look as though RS has them, so you could try element14. The ESR there is only 7 or 8 mOhm.
            You could also use 820uF 16V to get the ESR down a bit.
            • mockingbird
              • Dec 2008
              • 5488
              In my opinion, this is the only suitable replacement:
              http://my.rs-online.com/web/p/alumin...itors/7083642/
              It matches KZG ESR of 0.030, but it is 8x20mm instead of 8x11.5, so you will have to account for the extra height.
              • liukuohao
                • Oct 2013
                • 63
                • Malaysia
                Hi All!
                Thank you very much for your advice!!
                Q1) Why does it necessary to match the ESR /impedance value of a
                capacitor which I am about to replace?
                Q2) Does this Nichicon polymer / solid capacitor works on my capacitor
                replacement:
                http://my.rs-online.com/web/p/tantal...itors/0541491/?
                I saw the the ESR value is very low = 0.009 ohms but it does not match the
                UCC KZG series capacitor
                Q3) I have recently bought a desoldering gun workstation.
                What is the right temperature to have gun heat up. What is the Celsius ????
                • mariushm
                  • May 2011
                  • 3799
                  ESR is a characteristic and Impedance is another thing.
                  However, when capacitors are used on motherboards or power supplies in a specific way (high frequency switching power supplies or voltage regulators for CPU or RAM for example), the impedance value is almost the same as the ESR value. So, it's safe to consider the Impedance value listed in the datasheet (the one measured at 100kHz) as ESR.
                  The ESR should be as close as possible to the capacitors you replace. It's acceptable to be a bit below or a bit above (let's say 10-20%) but if the value is much different there can be problems (motherboard acting up, instability, premature death of capacitors etc).
                  So if your old capacitors had about 30 mOhm ESR and these new ones have 9 mOhm, there is a small risk, they're not quite a good match.
                  Those KZG capacitors probably had about 30 mOhm when they came out of the factory, but as they aged and started to go bad, the value changed (usually increases).
                  Before the motherboard started to show signs of problems, the capacitors probably had much higher ESR for months but the circuits on the motherboard tolerated that and still worked OK. So there is a bit of room when choosing replacement capacitors.
                  The temperature depends on what you want to desolder and where it's installed. Solder melts at 180-220 degrees Celsius, depending on what type of solder it's used.
                  However, when you put the gun on solder, the solder and the copper in the circuit board where the component is installed will pull heat away from the gun so the gun tip will cool down. That's why it's normal to configure the temperature higher than 220-250c, usually 300-320C is a normal temperature.
                  Basically, you want to keep temperature low because you don't want to damage components or the circuit board but at the same time, it has to be high enough to actually start melting the solder.
                  Motherboards have large surfaces of copper in the circuit board, they will act as a heatsink and it could be a bit harder to use a gun on them. You may need to increase the temperature.
                  Another tip ... add a bit of solder to the leads of the capacitors that are already soldered, then use the desoldering gun if needed.
                  Learn how to use the desoldering gun, search youtube for videos that show how to use it.
                  • mockingbird
                    • Dec 2008
                    • 5488
                    replacement:
                    Yes, that is an excellent replacement. I don't know why I couldn't find it when I made the search.
                    • c_hegge
                      • Sep 2009
                      • 5219
                      It's listed as a tantalum capacitor. It should really have been listed as an electrolytic (like most of the other polies on RS).
                      • liukuohao
                        • Oct 2013
                        • 63
                        • Malaysia
                        Thank for your informative advice.
                        But I am getting conflicting advices from the forum members.
                        As you are advising me to stick to a capacitor that can MATCH the previous
                        capacitor's ESR value as CLOSE as possible. Yet I am hearing others that get
                        a LOW ESR will work fine provided you are getting a same capacitance of
                        820uf, 6.3v(or higher 10v). Sigh..... which side do I follow??
                        • liukuohao
                          • Oct 2013
                          • 63
                          • Malaysia
                          Ok, then can you vouch that there is no problem with the motherboard
                          stability in the long term usage?
                          In my preference, I like the polymer/ solid capacitor better than the standard
                          electrolytic ones
                          • liukuohao
                            • Oct 2013
                            • 63
                            • Malaysia
                            I wonder why it is listed as Tantalum + electrolytic, must be a typing error??
                              master hoarder
                              • May 2008
                              • 12175
                              Here's a simpler rule of thumb (and I say rule of thumb because I break rules and experiment all the time ).
                              ESR of new capacitor should be the same or lower than the original caps.
                              Capacitance should be the same or higher than the original caps
                              Ripple Current should be the same or higher than the original caps.
                              Working Voltage (or simply the Voltage) should be same or higher. Lower IS possible if you know the capacitor you are replacing will not go above a certain voltage. But if you are new to recapping, don't lower the voltage on caps just yet.
                              • liukuohao
                                • Oct 2013
                                • 63
                                • Malaysia
                                Ok, then...Momaka, thanks for the advice. The air quality is much more better
                                now then before, I can see the path straight ahead of me.
                                I will go ahead and order some of this Nichicon polyer capacitor from RS:
                                http://my.rs-online.com/web/p/tantal...itors/0541491/ and see
                                how it work out.
                                Hopefully your advice of rule of thumb is rock solid
                                • liukuohao
                                  • Oct 2013
                                  • 63
                                  • Malaysia
                                  Is there a website or any information that teach you how to read the
                                  information printed on the polymer /solid capacitors?
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    Maybe, but I don't know of any. Capacitorweb, perhaps.
                                    That said, I think you are misled into thinking that all sleeveless caps are polymers and vice versa. For example, the shiny silver sleeveless FZ capacitors in the picture below are NOT polymers, they are standard electrolytics:
                                    https://www.badcaps.net/forum/attach...9&d=1421341284
                                    Likewise, the yellow caps on the motherboard in the picture below are not electrolytics, even though they have sleeves and vent stamps. They are polymers - Fujitsu FPCAP RE series.
                                    https://www.badcaps.net/forum/attach...8&d=1351481371
                                    So how does that answer your question? Well, there is no special way to read those sleeveless caps. You just look at the numbers on the top and that is usually enough to tell at least what voltage and capacitance they are.
                                    Generally, it looks like this:
                                    Line 1: Cap series, cap manufacturing code, and/or company logo
                                    Line 2: capacitance (either in standard or multiplier format*)
                                    Line 3: voltage (again, either in standard or special coding format**)
                                    These lines may appear in a different order, though (i.e. line 2 before 1, and etc.)
                                    * : here is an example of multiplier format: 821. The first two numbers (82) are part of the capacitances number, and the last number (1) is the multiplier.
                                    1 = 10
                                    2 = 100
                                    3 = 1000
                                    and so on
                                    So "821" translates to 82 x 10 = 820 uF
                                    If you have the number 152, then that could be 15 x 100 = 1500 uF
                                    ** : as for the voltage coding format, this tends to vary between manufacturers and is not standard as far as I know. But these coding formats are not used that often.
                                    • liukuohao
                                      • Oct 2013
                                      • 63
                                      • Malaysia
                                      1 = 10
                                      2 = 100
                                      3 = 1000
                                      and so on
                                      Hi momaka,
                                      Yes, I did notice that some polymer capacitors look like polymer but in actual
                                      fact they are not........when I read the link below:
                                      http://www.capacitorlab.com/capacitor-types-polymer/
                                      But I never realized that those Fujitsu yellow capacitors are really polymer
                                      even you can clearly see the vent sleeves on top of them:
                                      So wonder why they made them to have sleeves????
                                      Most appreciated for giving your information about reading the polymer
                                      capacitor's value. I am going to have to write this information down
                                      on a note book.
                                      I wonder why polymer capacitor can't have printed uf + voltage just like the
                                      older generation electrolytic capacitors, may be the printing cost will be high?
                                      I just wish someone can gather all information and write all in 1 sticky for
                                      easy reference.
                                      I just can't not thank enough to people who contribute their advice on my post.
                                      Again. Thanks a million in helping out!!!! Give yourself a pad on your back!!!!
                                      • mariushm
                                        • May 2011
                                        • 3799
                                        My thoughts...
                                        1. Removing the plastic cover saves money.
                                        2. Polymer capacitors don't need vents so there's a flat top where it's convenient to print stuff and make clear notation of the negative side. Electrolytic capacitors needed to have the top clear of everything, for safety. Regular paint probably had little adherence on the sides and since it's curved, the printing process was probably difficult, hence the need for plastic wrap.
                                        3. Printing on top is beneficial, it makes it easy for machines that automatically check how parts are placed to detect the negative strip and to optionally read the characters (making sure the machine or person inserted the proper capacitor in the proper position)
                                        4. A majority of the manufacturing process can be reused to create surface mount capacitors, which are like regular capacitors but with a rubber square on the bottom instead of leads.
                                        5. With some polymer capacitors, the height is too small to fit everything needed (capacitance, voltage, series, temperature, polarity).
                                        Some polymer capacitors have diameters so small that you just can't fit all information on top in a long way.
                                        For example, you probably can't fit 1000uF and 2.5v on a capacitor that's only 8mm in diameter, so you write 102 instead of 1000 ( 10 x 10^2 = 10x 100 = 1000uF) and they use the code "0E" to represent 2.5v. See datasheet and the chart for such a series of capacitors:
                                          by momaka
                                          03-12-2025, 03:42 PM
                                        • Paxman_Swede
                                          by Paxman_Swede
                                          Hello!
                                          01-14-2025, 09:51 AM
                                        • Foetuss
                                          Gigabyte GA-6OXT :: caps question
                                          by Foetuss
                                          Good evening
                                          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                          But I was also suprised about the bigger boys, which are 330µF 25V.
                                          Could it be they used 25V caps because they were cheaper / available at that time?...
                                          02-11-2025, 12:22 PM
                                        • edith
                                          Caps and how to find one to replace
                                          by edith
                                          Hello everyone I have a question. I have a laptop and his schematic. Can anyone tell me how to measure or any way to understand specific of caps so i can buy new one?
                                          Also in case how can I understand if some caps of some dead Mobo i have, are ok to be replaced in my new motherboard which im trying to fix?
                                          Thank you!
                                          06-11-2023, 05:00 PM
                                        • captain150
                                          by captain150
                                          03-16-2025, 07:34 PM
