Capacitor Advice
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    Capacitor Advice
    Are the following capacitors considered good/bad...?
    Nippon Chemi-con SME series 470uF 16V.
    Are these the same as United Chemicon?
    Yageo 6.3V 1500uF - don't know series.
    Any help. insight and advice greatly appreciated
  • JEWilson
    • Sep 2007
    • 369
    Re: Capacitor Advice
    To add to this list as they are not in the good caps list are;
    Rubycon 1uF 50V M334 RS-300
    So far as badcap advice refers to any cap value over and above
    470uF, are these for general purpose use or do they have any
    other specific usage?
    Can't find them on the Rubycon series chart
    • Kaine
      • Mar 2007
      • 55
      Rubycon and Nippon Chemi-Con are good brands, never heard of Yageo. Check the list of good capacitors and list of bad capacitors threads.
      • linuxguru
        • Apr 2005
        • 1564
        Yageo is owned by the Teapo, and makes of a lot of SMD ceramics and other passives, mostly for RF applications. Those are mostly high quality. The quality of their electrolytics isn't well known, but they haven't been seen in mobo applications for almost a decade. I guess they've chosen not to compete on price, like Elna, for the volume motherboard market.
        • PeteS in CA
          • Aug 2005
          • 3581
          • USA, Unsure of Planet
          NCC = UCC. The SME series is a high quality GP part. That Rubycon part sounds like it might be a GP part also.
          PeteS in CA
          • Tom41
            • Oct 2005
            • 336
            • England
            I understand that both Nippon Chemi-Con and United Chemi-Con are the same brand - the only difference is whether they were manufactured inside or outside Japan. Am I right?
            Both Rubycon and Chemi-con are good brands; not too sure about Yageo though.
            You know there's something wrong when you open your PC and it has vented Rubycons...
            • JEWilson
              • Sep 2007
              • 369
              Has anybody seen or heard of
              NKNC brand?
              I have two of these with an ESR of 2.6 and 2.7 respectively?
              They are 50V 10uF and are not s/c - replace?
              • Krankshaft
                • Jan 2007
                • 2328
                I have mostly seen Teapos on PSUs and there they should stay because for the most part they fare well.
                But on mobos like Epox they are horrible.
                As a Pixl called them on mobos T-blows .
                • MORETTIGIAN
                  Capacitor detached from PCB – RTX 2070 Super Founders Edition
                  by MORETTIGIAN
                  Title:
                  Description:
                  During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                  I did not notice it detaching, so I am unsure of its original location on the PCB.
                  Procedure performed:
                  - Removed backplate
                  - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                  - Reapplied thermal compound
                  - Reassembled card
                  Observed behavior after reassembly:
                  - GPU powers on and operates normally under...
                  09-18-2025, 12:14 PM
                • Prolog
                  RTX 3080 FE Identifying capacitor
                  by Prolog
                  Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                  I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                  I hope these photos make it clear which component I am referring to:
                  (yes, the soldering is a bit botched from removing the blown one, I know)
                  I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                  12-01-2024, 08:27 PM
                • chth96
                  If I replace with inferior capacitor, Is it No harm to other IC components at all?
                  by chth96
                  I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                  Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                  It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                  So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                  I know that these capacitor will not last as long as nichicon capacitor...
                  12-22-2023, 04:34 AM
                • chth96
                  How can I test non-polarized capacitor?
                  by chth96
                  I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                  I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                  And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                  I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                  06-02-2024, 07:31 PM
                • chth96
                  Is it no harm to replace with capacitor without ripple current rating?
                  by chth96
                  When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                  Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                  But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                  Rubycon YK DataSheet (b...
                  04-19-2024, 05:19 AM
