Capacitor Advice
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    Capacitor Advice
    Are the following capacitors considered good/bad...?
    Nippon Chemi-con SME series 470uF 16V.
    Are these the same as United Chemicon?
    Yageo 6.3V 1500uF - don't know series.
    Any help. insight and advice greatly appreciated
  • JEWilson
    • Sep 2007
    • 369
    Re: Capacitor Advice
    To add to this list as they are not in the good caps list are;
    Rubycon 1uF 50V M334 RS-300
    So far as badcap advice refers to any cap value over and above
    470uF, are these for general purpose use or do they have any
    other specific usage?
    Can't find them on the Rubycon series chart
    • Kaine
      • Mar 2007
      • 55
      Rubycon and Nippon Chemi-Con are good brands, never heard of Yageo. Check the list of good capacitors and list of bad capacitors threads.
      • linuxguru
        • Apr 2005
        • 1564
        Yageo is owned by the Teapo, and makes of a lot of SMD ceramics and other passives, mostly for RF applications. Those are mostly high quality. The quality of their electrolytics isn't well known, but they haven't been seen in mobo applications for almost a decade. I guess they've chosen not to compete on price, like Elna, for the volume motherboard market.
        • PeteS in CA
          • Aug 2005
          • 3578
          • USA, Unsure of Planet
          NCC = UCC. The SME series is a high quality GP part. That Rubycon part sounds like it might be a GP part also.
          PeteS in CA
          • Tom41
            • Oct 2005
            • 336
            • England
            I understand that both Nippon Chemi-Con and United Chemi-Con are the same brand - the only difference is whether they were manufactured inside or outside Japan. Am I right?
            Both Rubycon and Chemi-con are good brands; not too sure about Yageo though.
            You know there's something wrong when you open your PC and it has vented Rubycons...
            • JEWilson
              • Sep 2007
              • 369
              Has anybody seen or heard of
              NKNC brand?
              I have two of these with an ESR of 2.6 and 2.7 respectively?
              They are 50V 10uF and are not s/c - replace?
              • Krankshaft
                • Jan 2007
                • 2328
                I have mostly seen Teapos on PSUs and there they should stay because for the most part they fare well.
                But on mobos like Epox they are horrible.
                As a Pixl called them on mobos T-blows .
                • Prolog
                  by Prolog
                  12-01-2024, 08:27 PM
                • chth96
                  by chth96
                  12-22-2023, 04:34 AM
                • chth96
                  by chth96
                  06-02-2024, 07:31 PM
                • chth96
                  Is it no harm to replace with capacitor without ripple current rating?
                  by chth96
                  When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                  Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                  But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                  Rubycon YK DataSheet (b...
                  04-19-2024, 05:19 AM
                • chth96
                  Should I replace polymer capacitor?
                  by chth96
                  a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                  I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                  Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                  Is this ESR value of polymer capacitor correct?...
                  11-18-2022, 04:22 AM
