bad batch of ncc lxf in xycom industrial pc's?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    i have been seeing a bunch of these boxes come in for service.
    mostly bad hard drives and lcd problems.
    but any that have these ncc lxf in the psu have at least 1 shorted and the others quite leaky electricly.
    some of these boxes have very few hours as they are in a qc lab.used a few hours a month.
    the ones with rubycon yxg are always ok.
    bad lot?counterfiet?
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: bad batch of ncc lxf in xycom industrial pc's?
    Xycom VME provides equipment manufacturers with board-level microcomputers and input/output solutions used in machine control, test and data acquisition, medical equipment, automotive test and assembly, robots, scanning equipment, semiconductor manufacturing, military systems, industrial welders, power generation and high-speed packaging applications.
    whats that unit do anyway?
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      its a measurement device for checking parts.
      • gdement
        • Jan 2007
        • 690
        I couldn't find a datasheet for the LXF, but they do list the LXY as it's modern replacement.
        For the LXY, the 2200uF 16V caps come in 2 sizes with different specs:
        12.5x30 30mO 1950mA (maxripple @ 105C,100khz)
        16x20 38mO 1630mA
        I'm not sure which diameter matches your original, but since this is a recommended replacement I'd assume that the specs on the LXF must be no better than these, and possibly worse.
        For Rubycon YXG:
        12.5x25 27mO 2230mA
        18x16 43mO 2210mA
        In either case, they have higher ripple current ratings than the LXY, and so presumably also better than the LXF. Over time, this might be why they've held up better.
        • toastygoodness
          • Jul 2005
          • 813
          remember that it's also in an industrial setting, so things die faster.
          • linuxguru
            • Apr 2005
            • 1564
            Some larger LXFs had an issue in the past with electrolyte leaking out of the bottom bung. AFAIK, the cause hasn't been pinpointed conclusively - it could have been a bad batch, but it could just as well have been improperly bent/inserted leads during assembly which damaged the bottom seal. The issue was noticed by a high-end audio company - possibly Bryston (I could be wrong).
            I still use LXFs for PSU recapping, and haven't run into any leakage yet, but in most cases the ATX PSU is oriented in such a way that the caps are hanging suspended from the PCB - so this issue may never show up. What I like about the LXF is the claimed 15k hour endurance number - we'll see how it goes.
            The dimensions on my 2200/16 LXFs are 12.5 x 29 mm, brown sleeve, Japanese thin/narrow vent scoring, straight leads. Yours look shorter and stouter, but they may be a custom series.
            • linuxguru
              • Apr 2005
              • 1564
              Addendum, Edit time limit expired:
              Apart from the dimensions, the vent scores on your LXFs are wider, deeper lines more characteristic of Korea Chemicon/Samyoung. The bottom bung marks appear to be accurate. The font/legend on the sleeve is similar to mine, but the exact locations of some letters differ. My verdict: yours are not Japanese-manufactured LXFs.
              • BigTroll
                • Sep 2010
                • 1317
                • LAMBDA SOND
                Trying to fix a Dyna Corp DCF 704 Performa 6200 PSU, the LXFs in the 12mm size leaked from the bung FYI
                My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
                • brethin
                  • Dec 2008
                  • 1907
                  Holly Necro a 14 year old thread!
                  • BigTroll
                    • Sep 2010
                    • 1317
                    • LAMBDA SOND
                    yikes sorry,hopefully these panasonic FR I ordered will be fine for replacing LXF
                    • PeteS in CA
                      • Aug 2005
                      • 3581
                      • USA, Unsure of Planet
                      If still available, Chemicon LXV series would be a closer match, or maybe Nichicon PS series.
                      PeteS in CA
                      • BigTroll
                        • Sep 2010
                        • 1317
                        • LAMBDA SOND
                        I couldn't get the FR in all the sizes but Chemicon LXY's came in the same size. then I will use panasonic FC to replace the Chemicon SME.
                        • bojc
                          industrial PC, CPU, BIOS
                          by bojc
                          Hello all
                          i have industrial pc which doesn't power on, it has ATOM cpu on it
                          the voltages are ok, but the system is frozen, doesn't post
                          if i dump BIOS is there a way to checked it if it's OK? or should i just order new CPU?
                          BR and thanks for answers
                          Bojan...
                          02-19-2024, 05:02 AM
                        • techpointhull
                          NO POST Nightmare - DFI G7L330-B Industrial Motherboard Socket 775
                          by techpointhull
                          Hi Guys,
                          Newbie here to board repair so bare with me. I have a bunch of Socket 775 motherboards from arcade gaming machines. The brand is DFI, and it's their industrial motherboard range model number G7L330-B
                          All boards have the same issue, no POST. I've re-capped the boards completely, can't see any shorts across the 12V rail and I've removed all MOSFETS from the board to test them. The boards have been ultrasonic cleaned as well as an alcohol bath, doesn't seem to have made a difference
                          BIOS is also correct, I do have a working board for reference...
                          11-21-2023, 10:57 AM
                        • mnciks11
                          BA-0901RA-SON P/N: 17-146-089103 Industrial motherboard bios
                          by mnciks11
                          Hello guys
                          I'm working on the BA-0901RA-SON P/N: 17-146-089103 Industrial motherboard
                          For a spec factory, they are in need of this board, their motherboard is turning on but nothing on the screen after the faulty PSU , please I really need assistance with cleaning, modifying their current bios bin file…The vcore, Cpu is the only power supply not working, 0v on the CPU VCORE.
                          BA-0901RA-SON P/N: 17-146-089103 Industrial motherboard can't find this bios at all I've searched all over the net, I need assistance cleaning the old one ☝️...
                          01-08-2022, 03:20 AM
                        • Ziomal92
                          Need bios batch Medion e6240t (c15m rev 2.0)
                          by Ziomal92
                          Hello, I'm looking for bios batch for Medion e6240t (c15m rev 2.0). I tried use batch from c15m rev 2.1 but did not work. Thanks in advance for helping.
                          11-05-2021, 01:29 AM
                        • mholin
                          Beckman Industrial/(later Wavetek) Digital Multimeter DM27XT Repair
                          by mholin
                          Was testing to see if a bug zapper grid voltage (=< 2800VDC) had discharged yet. Set meter to highest range (1000 VDC) and probed across the grid. Heard an audible arc so voltage must have discharged into something in the front end of the meter. Now all functions that use the V-Ohm/Com input just reads "OL" (over range). Even the continuity test with the probes shorted reads OL with no beep. Opened it up and found input resistor R31 47 ohms, completely open. Replaced with new resistor but meter still reads "OL". The low battery icon on the display is visible even...
                          08-18-2024, 12:58 PM
