Is that capacitor OK? Thank you.
  • Leung Kai-yan
    • Apr 2006
    • 32
    Dear Friends,
    I have a capacitance meter. When I use it to test a capacitor of 220 uf., 16 V. and 105 degrees C. The reading is first at 4XX uf. and goes back to 23X uf. at the end. Is that capacitor OK? Thank you.
  • linuxguru
    • Apr 2005
    • 1564
    Re: Is that capacitor OK? Thank you.
    Yes, the capacitance is what the meter reads when it settles - in this case, the ending stable value. In any event, electrolytics have a very wide tolerance, typically +/- 20% or higher.
    • Leung Kai-yan
      • Apr 2006
      • 32
      Dear Friend,
      Thank you for your help.
      Thank you.
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • chth96
        by chth96
        03-09-2024, 10:03 PM
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • Sparklingx
        SMD ceramic capacitor capacitance & voltage
        by Sparklingx
        what is the easiest way to measure the capacitance of SMD ceramic capacitors and its rated voltage?...
        09-12-2024, 01:04 AM
      • chth96
        by chth96
        06-02-2024, 07:31 PM
